Lighting HID/Xenon kits, Retrofits and Associated Topics
Just a question!
Old Nov 12, 2008 | 08:57 PM
demian22's Avatar
Default Just a question!
I just want to know what would happend if i take of the lil metal piece inside the headlight, would it make it better or no point, its the piece in front of the lightbulb, if anybody had tryed this let me know please!!
Old Nov 13, 2008 | 07:25 PM
bpr0422's Avatar
Default Re: Just a question! (demian22)
don't remove the glare shield you will only create glare...
Old Nov 13, 2008 | 07:58 PM
uniseriate's Avatar
From Daniel Stern on an old usenet post:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
It's called a bulb shield. The purpose is primarily to eliminate upward stray light (between 10 degrees up and 90 degrees up, relative to the headlamp axis) that would cause backdazzle in inclement weather. It also shields the filament from direct view by oncoming and preceeding drivers, minimising direct glare. Some headlamps don't use shields; direct glare and upward stray are controlled by other means (bulb positioning, lens optics and angle, etc.), OR direct glare and upward stray aren't really controlled much at all and you have a lousy headlamp. There's a lot of that going around.
So, no, removing the bulb shield won't do anything good for you or other drivers.
Old Nov 14, 2008 | 09:14 PM
ejLday's Avatar
the bulb shield is essential for light output. Deff leave it in
Old Nov 15, 2008 | 08:42 PM
demian22's Avatar
Default Re: Just a question! (ejLday)
Thanx to all for the answers!!
kixcrx
Jan 8, 2008 03:24 PM
pinoy2o9
Lighting
10
Sep 11, 2007 07:56 AM
paulab
Sep 7, 2006 12:26 PM
TurismoDreamin
Aug 17, 2005 01:14 AM
TruBlu
Jan 27, 2003 05:12 PM
