Lighting HID/Xenon kits, Retrofits and Associated Topics
Driver side headlight not working (retrofit)
Old Dec 12, 2008 | 10:25 AM
Crono139's Avatar
Default Driver side headlight not working (retrofit)
No need to mention the full setup, but I have a Hella / Philips Gen 3 HID kit with a CustomLightz harness.
The driver side headlight stopped working, and I already know that it's not the bulb.
So it's now either the ballast, harness (fuse), or ground, correct?
Could a bad ground on one side of the engine bay for the harness cause that side to stop working?
Thanks.
Old Dec 12, 2008 | 01:03 PM
Caveman74's Avatar
Either a relay or fuse. You might want to swap sides and see if the ballast lights on the other side. Did it flicker any? that is usually a lose ground
Old Dec 12, 2008 | 07:05 PM
Crono139's Avatar
Didn't flicker at all.
It was raining like crazy last night when I was driving home from school. I noticed the headlight was out once I pulled into the driveway.
I'll be swapping the ballasts in the morning.
Old Dec 14, 2008 | 09:54 AM
e46civic's Avatar
These ballasts have an internal fuse, it may be blown. Ground the ballast casing and apply power to the 12v lead, if it works the fuse is blown.
Old Dec 16, 2008 | 12:56 PM
Crono139's Avatar
The ballast is the culprit.
Already ordered a replacement pair from HID Planet.
As a side question, if the fuse is blown, can it be replaced?
Old Dec 16, 2008 | 04:53 PM
e46civic's Avatar
Im not sure, I would imagine so though. Open it up and find out. Ive never opened a Hella, only Bosch.
Old Dec 20, 2008 | 12:19 PM
prelude1897's Avatar
there's a guy on HIDplanet to fixes Hella ballast, but I can't think of what his name is. I know it starts with an L
Old Dec 20, 2008 | 12:23 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
So you're sure the ballast is the problem?
I had a poor ground on my driver side relay when I re-made custom harnesses for my retrofit back in 2004, which caused my left side headlight to not work. I moved the wire to a better/tighter ground and it's worked fine every day ever since then.
Old Dec 31, 2008 | 11:22 AM
Crono139's Avatar
Default Re: Driver side headlight not working (retrofit)
Replaced the ballast, and it works fine now.
Old Jan 2, 2009 | 08:03 AM
-Bionic-'s Avatar
Former Sponsor
Glad it worked out. You should of called me.
Sorry I didn't see this post earlier.
Bleakened
Oct 17, 2016 07:41 AM
vtek9
Lighting
Dec 20, 2007 02:26 PM
LudeJdm
Lighting
Nov 27, 2007 04:37 PM
GapxGuy
Feb 20, 2005 10:23 PM
GapxGuy
Feb 19, 2005 08:13 AM
