Lighting HID/Xenon kits, Retrofits and Associated Topics
adjust the headlights on integra?
Old Oct 7, 2008 | 05:58 PM
hondakrazy's Avatar
Default adjust the headlights on integra?
i have a 96 integra coupe how do you adjust the headlights?
Old Oct 7, 2008 | 07:09 PM
TunerN00b's Avatar
Default Re: adjust the headlights on integra? (hondakrazy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondakrazy &raquo;</TD></TR><TR><TD CLASS="quote">i have a 96 integra coupe how do you adjust the headlights?</TD></TR></TABLE>
Hopefully someone else will post up pics, as I have none.
With a large phillips screwdriver. There are 2 adjustments on each light, horizontal and vertical. If you look at the top of the light with the hood open, you'll see 2 "openings" that are each formed by the housing and 2 tabs, with a white gear at the bottom. You turn the gear with the screwdriver by inserting it between the tabs.
I forget which is horizontal and vertical, but a quick trial and error test should identify that.
Hopefully thats an adequate description. I suck at teh explanations sometimes...
r81_em1
Jul 27, 2012 08:33 PM
chromedoutteg
Mar 6, 2008 11:35 AM
N1NjA TuRtLE
Nov 9, 2003 02:24 PM
joy-Ride
Jul 10, 2002 01:12 PM
