Lighting HID/Xenon kits, Retrofits and Associated Topics
HID FOG Light Flicker
Old Oct 13, 2008 | 10:59 AM
88 EF Hatch's Avatar
Default HID FOG Light Flicker
I have a set of H3 3000k HID bulbs. SO After installing them the lights flicker as they turn on and one of them will turn off after like 2 seconds. Some times both of them turn off. I thought it was a ground problem so I checked the ground and grounded the bulbs separately. I'm still having the same problem. I have to turn the switch on and off in a continuous motion like 10 times until they both stay on. I don't want to burn out the bulbs. Any ideas of what kind of problem I have?
Old Oct 14, 2008 | 09:57 PM
jdmek9imagex's Avatar
Default Re: HID FOG Light Flicker (88 EF Hatch)
Did you cut the wires? I did it and got new bulbs at http://www.sparkhid.com
Old Oct 25, 2008 | 10:10 PM
bpr0422's Avatar
how are the ballasts getting power?
if you are using your ebay harness that came with the ebay oem like foglights... then i suggest you make a new harness..
Old Nov 3, 2008 | 06:23 PM
Default Re: HID FOG Light Flicker (jdmek9imagex)
Yes I did. Was I not supposed to?
Old Nov 3, 2008 | 06:25 PM
Default Re: HID FOG Light Flicker (bpr0422)
I cut the two ballast power wires and joined them together, and ran one power wire to the fuse box. Do I need to run the power separately?
Old Nov 4, 2008 | 05:08 AM
sikmansherman's Avatar
It would be better for you to get the power directly from the battery with a relay harness.
And you need stronger wires to make it as well because HID needs larger current to start up.
The wire behind the fuse box won't allow such a high load and so you ballast won't get enough power to start up.
Old Nov 4, 2008 | 03:55 PM
ok well how big of a wire should i use? so will any universal 4 prong relay work? Oh and last night I was washing my motor. After I was done I turned on my headlights, which are 9006 10000K and they turned on. I turned off my car for 2 minutes and when i turned it back on my passenger headlight would not turn on. it flickered. I swaped bulbs and its just that one size. Did my ballast go out?
jdm89crxhf
Lighting
Apr 21, 2012 01:20 PM
K24_Y61P
Honda Civic (2001 - 2005)
Aug 13, 2007 07:53 AM
dreams_of_ek9
Dec 29, 2006 04:20 PM
malubawla
Aug 10, 2006 11:17 PM
chinese buffet
Oct 16, 2005 08:09 PM
