Lighting HID/Xenon kits, Retrofits and Associated Topics
S2K HID shut off!!!!!!!!!!!
Old Oct 28, 2008 | 06:02 AM
mach0's Avatar
Default S2K HID shut off!!!!!!!!!!!
I installed an s2k hid retrofit into my car..only issue was the ballast are huge..so we relocated them behind my turn signal (DC4)...today one of them turnd off..I checked the seating..its fine..checked the connection to the factory headlight harness, fine ( i used connectors so no splicing..) it happened to be raining today, is it possible the ballast got wet and fried?
Old Oct 28, 2008 | 01:28 PM
mach0's Avatar
anyone?????????????
Old Oct 28, 2008 | 01:43 PM
Oo0MaRkY0oO's Avatar
what kind of ballasts are they? are they mounted in a way that water could have gotten inside? did you check the bulb to see if it burnt out? if you used fuses/relays, have you checked those as well?
Old Oct 28, 2008 | 05:38 PM
mach0's Avatar
Default Re: (Oo0MaRkY0oO)
fixed already..blue and fried...waters a bytch
they were s2k's ballast too
Old Nov 1, 2008 | 11:30 PM
striker_18's Avatar
Default Re: (mach0)
disconnect them and let them sit dry for a couple of days. It should fire up after
markeke3
Lighting
Oct 12, 2012 12:41 AM
NSXRguy
Lighting
Mar 6, 2010 07:45 PM
maal15
Dec 13, 2008 11:30 AM
Homer_Simpson
Oct 31, 2001 09:54 AM
