Is this collector ok?
Old May 1, 2006 | 04:24 PM
BlackT5's Avatar
Default Is this collector ok?
Bought this for super cheap and basically i'm wondering if that burn though is going to be a problem. I'm calling it burn though, I dunno what you guys call it
It's only tacked together and needs to be tigged up.
Thanks guys
Mark
Old May 1, 2006 | 04:33 PM
beepy's Avatar
Default Re: Is this collector ok? (BlackT5)
Looks like someone's practice collector. It can be fixed, just clean it up.
Old May 1, 2006 | 04:48 PM
BEEYOND's Avatar
need to practice.....more ... this collector need not to be used unless fixed by a pro....
Old May 1, 2006 | 08:30 PM
B18C1CYA's Avatar
I would build another one , and use low heat so you dont burn through and get the "moon rocks" on the inside , just take your time and work on the fitment , the better the fit the better and nicer the weld will be
Old May 1, 2006 | 09:47 PM
k24em2's Avatar
Default Re: Is this collector ok? (B18C1CYA)
Thats not bad for a 5-1 collector. Don't see them made out of pipe very often. Little more practice and it should turn out pretty nice.
Old May 1, 2006 | 09:50 PM
RaceCarRyne's Avatar
Default Re: Is this collector ok? (k24em2)
Old May 1, 2006 | 11:33 PM
Pay2play killa's Avatar
Default Re: Is this collector ok? (BEEYOND)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BEEYOND &raquo;</TD></TR><TR><TD CLASS="quote">need to practice.....more ... this collector need not to be used unless fixed by a pro.... </TD></TR></TABLE>
Why or it will explode?
That burn through isn't bad; I've fixed worse and never had a problem Its a bit tricker to do it on a Tig but a Mig would fix that in a jiff. Then use a grinder to re-shape it and you're set!
Old May 3, 2006 | 09:11 AM
BlackT5's Avatar
Thanks for the replies.
Somebody local to me will be making the manifold, so i'll leave it upto him weather he wants to use it or fab up another one.
I'll post pics one it's all done.. probably won't be for a while.
Mark
Old May 3, 2006 | 05:32 PM
cua0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1CYA &raquo;</TD></TR><TR><TD CLASS="quote">I would build another one , and use low heat so you dont burn through and get the "moon rocks" on the inside , just take your time and work on the fitment , the better the fit the better and nicer the weld will be </TD></TR></TABLE>
hahaha moon rocks, that's awesome, i've only ever heard it referred to as sugaring. (i believe that's the asme term for contamination due to exposure to unshielded ozone on the back side of a weld due to too much goddamn heat.)
Old May 8, 2006 | 06:48 PM
SkankyEJ7's Avatar
Default Re: Is this collector ok? (cua0)
better than i could do, so you get my
91-lsvtecsi
Nov 11, 2011 03:28 PM
Touge Factory
30
Aug 12, 2011 04:58 PM
fillipo
Other Make Vehicles
25
Feb 21, 2009 06:18 PM
KeyserSoze
Welding / Fabrication
50
Feb 28, 2006 09:43 PM
D for D series
Sep 10, 2005 06:50 PM
