Honda CR-V & Element 2WD & 4WD Element & CR-V
Best/affordable CRV 2000 code reader
Old Dec 28, 2014 | 06:25 PM
wattaman's Avatar
Default Best/affordable CRV 2000 code reader
Hi guys
After a few failed tries to fix/improve my old CRV 2000, I decided that if you want something done right, better do it yourself. So I'm trying to find/buy a code reader to diagnose my car and, if needed, buy and replace the parts myself.
Can someone recommend a cheap (but coog enough) code reader I can buy? Preferably from aliexpress, because the amazon will charge high import taxes and delivery to Thailand; anyway, just need a name, something that someone used already and works for sure. I'll search it after that on the net.
(I live in Thailand and it is very hard to find a good skilled guy around here)
My latest failed experience with the Thai mechanic, me and the guy (was thinking to replace the fuel filter for fuel economy):
- The fuel filter is old, are you sure that you replaced it (me)?
- I replaced with another old one. (he, serene)
- What?! Why? How does that make sense to you? Do you change the oil with used oil, too? (me, frustrated)
- It is an import SH filter, very good.
- Yes, but... but... still... what?!? ... anyway, I'm losing myself so I pay and drive away fast. While driving, the left-front window stops working, the right-front light blinks and the air is not as cold as it should be - I must lower it to 20 degrees to feel cool.
So, you see, can't trust anyone around here.
Old Dec 29, 2014 | 08:09 AM
UK-Kev's Avatar
Default Re: Best/affordable CRV 2000 code reader
Originally Posted by wattaman
Hi guys
Hello,
Do a search on aliexpress for Honda VDM, this is about the best aftermaket tool at present.
Kev
Old Dec 29, 2014 | 05:22 PM
wattaman's Avatar
Originally Posted by UK-Kev
Hello,
Kev
Will soon do. Thanks a lot.
Old Dec 29, 2014 | 05:31 PM
wattaman's Avatar
300$ is a little to much. I found one called Creader 6. Any reviews on this one? It costs around 60$.
Old Dec 30, 2014 | 03:14 AM
UK-Kev's Avatar
Hi, Have a read of this.
Kev
>>>> https://honda-tech.com/honda-civic-2...anner-2900091/
Old Dec 30, 2014 | 05:05 PM
scottyyhz's Avatar
Online OBD2 Interface Module Car Diagnostics Tool for Honda - Black
This one looks good, anyone try it?
Old Dec 31, 2014 | 04:21 AM
HondaPartsHero's Avatar
Technical Hero
Do you have an iPhone or android? Buy a cheap elm327(Bluetooth for Android phones and wifi for iPhones) off eBay and then download one of the apps from the store (Torque for android or Rev or Dash Command for iPhone). That's what I'm using and it's pretty awesome. You can also use these on computer software as well and use a laptop.
Old Dec 31, 2014 | 04:23 AM
Technical Hero
I'm assuming he wants data logging and sensor monitoring but for simple code reading a paper clip will do in a pinch
Old Dec 31, 2014 | 07:21 AM
wattaman's Avatar
I think that's better than my idea... or at least cheaper. I've read the Torque description and it seems to do a lot.
Thanks for the suggestion.
Old Mar 24, 2015 | 05:31 PM
wattaman's Avatar
I bought the elm327 and was ready to use Torque, but it seems that there is no ODB plug on my car. I've asked my mechanic and the Honda guys and they both told me that.
I thought ODB was introduced in '90s. Is it possible that it arrived later in Thailand?! Mine is a 2000.
Oh well, at least it cost me only a few $.
Old Mar 26, 2015 | 04:37 PM
Technical Hero
You don't have it, to my knowledge only USDM and Canadian have it
Old Mar 26, 2015 | 06:00 PM
wattaman's Avatar
OK, thanks for confirming. I guess next time I'll buy something I should make sure I can use it.
Cheers.
Old Mar 27, 2015 | 01:25 PM
UK-Kev's Avatar
Please re-check with Honda and ask them if your CRV has the Japanese’s 5 PIN OBD flat connector, you will probably find they will have to request the information from Japan, or contact them yourself direct …… Note you will need VIN numbers and any number you can find off the ECM.
If they confirm you have the old 5 PIN ODB connector, you can purchase an adaptor cable to ODB2 / EOBD 16 PIN diagnostic plug.
Kev
Old Mar 27, 2015 | 02:31 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
You can just look under the dash to see whether it has a 3-pin Data Link Connector (DLC) or a 5-pin DLC.
Your car will still have the 2-pin Service Check Connector that can be jumped with a wire or small paper clip.
jonwrong
Oct 27, 2021 12:33 PM
SlowB20z
Jan 1, 2013 02:43 AM
yo bj
Feb 23, 2011 09:25 AM
madmax91efsi
Oct 19, 2008 02:41 PM
klamdring
Mar 10, 2007 02:51 PM
