Honda CR-V & Element 2WD & 4WD Element & CR-V
ELD and Auto Trans Codes
Old Nov 29, 2014 | 05:46 PM
74baja's Avatar
Default ELD and Auto Trans Codes
Hi all,
I have a few questions about my 2003 CRV with a CEL. The physical symptoms are occasional jerking at low load, low speed in OD. I recently got a CEL and pulled three CEL codes with the flashing light technique: 20, 32, and 70. This led me to the ABS (probably unrelated), ELD, and auto trans malfunction, as mentioned in this video
. This video gets cut off at the beginning, so I'm not sure where he's going, but is it possible that the transmission problem is caused by the ELD, or is the transmission throwing the ELD code, too?
Thanks
Old Nov 30, 2014 | 11:18 AM
tony_2018's Avatar
Fish Twig
Default Re: ELD and Auto Trans Codes
Check your alternator fuse in the dash and see if its blown. Sorry can't help with the location as I've never worked on a crv but I recently had the same encounter and found out that a fuse was blown. The thing I haven't found was what caused it to blow. I'll be looking into it later on because I already replaced my firewall harness, engine bay fusebox and engine harness and converted my car to a 5spd.
theprofiteer
17
Jan 10, 2019 09:35 AM
Datto
Apr 7, 2013 06:21 AM
rugimpy
Jul 25, 2010 08:03 PM
sirmugenpower
May 21, 2010 08:48 AM
