Honda CR-V & Element 2WD & 4WD Element & CR-V
JDM clock with temp sensor help
Old Feb 9, 2015 | 04:19 PM
lunar_rd1's Avatar
Default JDM clock with temp sensor help
Hello HT, I have run into a problem with my jdm clock. I can get the clock to function correctly but after following multiple guides online I cannot get the temp sensor to read. The only time I have gotten it to show anything showed 45C. The sensor was not even connected when this showed. The common diagram is
WHT--------BLU-WHT/BLU
YEL---------YEL
RED---------BLK-RED/BLK
BLK---------BLK
BLU/WHT---YLW/GRN
GRY--------BRW/WHT.
I have looked multiple times and cannot locate the yellow/ green wire other than the cigarette lighter wire. I also have no located any brown/ white wires. If anyone has a photo or diagram showing these wires or locations that would be a huge help. I have looked at the ac control wiring multiple times with no luck :/
Thanks in advance,
Old Feb 10, 2015 | 08:11 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: JDM clock with temp sensor help
What exactly vehicle are you even working on?
Old Feb 10, 2015 | 10:49 AM
lunar_rd1's Avatar
Sorry, that would probably help. Its on a 2000 crv lx.
Old Feb 10, 2015 | 11:22 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Can you post the diagram for the JDM clock/temp wiring? I want to confirm the JDM unit wiring first.
Old Feb 11, 2015 | 04:14 AM
Skillachie's Avatar
Here's a thread that prob has the info you seek
https://honda-tech.com/honda-element...ensor-3133450/
Old Feb 11, 2015 | 09:02 AM
lunar_rd1's Avatar
Skillachie, thanks. I've read that thread before. I just can't find what yellow green wire you used. Its not on the diagrams from what I can see.
carlinag13
Oct 9, 2015 07:11 AM
slimjim07
Apr 26, 2013 05:21 PM
mikemayer99
Acura TSX
Apr 6, 2009 02:33 PM
aaj23
Jun 23, 2003 03:00 PM
