Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
2008 civic si abs and vsa light don't turn on.
Old 03-08-2016, 08:19 PM
Alcatrax30's Avatar
Default 2008 civic si abs and vsa light don't turn on.
Hey guys i was confused, when i turn my key to ON all the lights come on except the abs and triangle and vsa light, and i tested the vsa and it does not engage, and the abs does not engage. any ideas what it could be ? i removed the rpm cluster to see if the light bulbs were out but i didn't see any light bulbs. The vsa button does not do anything. I also went to get my car checked out and came up with an abs code 14-1 meaning the front left wheel sensor is faulty but i don't see an abs light. Whats going on ? Thanks for reading. Is there a fuse that controls the gauge cluster lights abs and vsa light? My car is manufacture in Canada so does that mean it does not have VSA? there button is left of the steering wheel but does not do anything. But do the canadian 2008 si's come with abs ? because my abs light does not come on at all.
Old 03-09-2016, 04:03 AM
Four(G)63's Avatar
Default Re: 2008 civic si abs and vsa light don't turn on.
Do a brakesystem or chasis scan. Itll give you more accurate faults. And if you can, do a live test
Old 03-09-2016, 05:03 AM
Alcatrax30's Avatar
I had it rechecked out, got same ABS code and i did a cluster light test
The abs light did not turn on nor the vsa
Old 03-10-2016, 09:44 AM
DaveSi677's Avatar
What code or codes did you get?
Old 03-10-2016, 02:57 PM
Alcatrax30's Avatar
14-1 front left speed sensor , but no abs light, is there something that controls the abs and vsa light?
komat
10-08-2010 05:37 AM
b18bc3po
04-06-2009 08:26 AM
Tulo
03-27-2008 06:57 AM
dblas
Acura TL, RL & ZDX
02-23-2007 02:40 PM
JimmyAtlantis
12-08-2005 08:51 AM
Quick Reply: 2008 civic si abs and vsa light don't turn on.
