PDA
View Full Version : Honda S2000
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60
  1. TODA Dry Carbon High Power Surge Tank Question.
  2. K24 SWAP S2K
  3. For PWJDM PowerCamber Users
  4. Spark plug wire cover bolt help
  5. Almost sold my S
  6. Warm start 'limp home' problem - please help!
  7. owned for a few months
  8. vss light on after car parked and battery dead over winter
  9. S2k just cranks but won't start.
  10. 2001 S2000 leaking fuel injector
  11. S2K Prank
  12. Product trialing
  13. ****TERMINATOR S2K in TURKEY ****
  14. LHT Performance Meet 3/22/14
  15. AP2 TO AP1
  16. RYP + blue soft top
  17. Ap2 soft top
  18. Ideas for check enigne lights
  19. Enkei RPF1s
  20. new s2000 need advice
  21. Lowering springs AP1
  22. AP1 active code problems
  23. driving on icy roads
  24. s2000 potential buy?! Help!
  25. A PROPER baffled oil pan is now in production by Canton Racing!!
  26. Speedfactory Racing S2000 Formula Drift
  27. dean_c89's v8 s2ooo swap (build thread)
  28. s2000 radiator differences
  29. Valve spring differences
  30. Oil Pump Rotor Problem?
  31. New ragtop for '01 S2K - any ideas?
  32. 2001 S2000 ignition lock issue
  33. key fob issues
  34. Rattling sound on start up
  35. S2000 Rear end vibration under acceleration
  36. ISC Coilover Review
  37. S2000 immobilizer
  38. need help with codes from 06 ap2
  39. An S2000 in Formula D next year?
  40. where to buy OEM front lip? moonrock metalic
  41. S2000 AP1 - Low compression?!
  42. Got my stock ap2 v1 widen to 17x10.5 with 275/40/17 nt05
  43. help needed
  44. Weird engine noise
  45. New S2000 Owner
  46. Nightmare of buying Staggered wheels
  47. Unedited BB photoshoot clean and simple!!!
  48. J's Racing C304 60RS Dual Exhaust
  49. buying an S2k
  50. F20 F22C S2000 ENGINE NEED TO BUY
  51. LOOKING FOR A TSX CRANKSHAFT
  52. motor oil choice
  53. Wheel sizing non staggered
  54. Dead Radio & Cigar Lighter
  55. ap2 vtec zone modify discussion
  56. Buying s2k, what to look for
  57. noise after cai install
  58. Overboring a F20C block
  59. Funny review of an S2000.
  60. can't find the tread I started so...
  61. New s2k owner
  62. hardtop side catches
  63. need a sway bar suggestion
  64. Extremely tempted. Need to hear opinions...
  65. Two Questions About S2k
  66. s2000 driveshaft rotation vs B series awd
  67. Rebuilding engine, need some advice
  68. AP1 F20C Engine Untuned, Tuned, Tuned+V-stack dyno graphs
  69. Ballast ground wire
  70. ap1 vs ap2 suspension and specs question
  71. AP1 model from AP2 year ranges?
  72. S2000 HORRIBLE ticking... video
  73. s2000 ecm replacement
  74. cold air intake worth it?
  75. S2000 Exhaust Options
  76. How to change the rear license light?
  77. what Final drive for AP1 with AP2 engine
  78. rpf1 question beaten to death
  79. 3 S2000's Stolen in one week in Houston Area!
  80. S2K Oil filter
  81. add-on traction control and splitter
  82. S2k tb size?
  83. 00-01 soft top frames with "OEM glass replacement"
  84. real streets drag s2k, who built the bolt in 4 link for that car?
  85. best oil for high mileage F20c??????
  86. s2000 AP1 Full ARC build!!!
  87. center cap for 17" Volks CE28
  88. head lamp adjustment
  89. S2000 headlamp lens replacement
  90. how much boost before boom?
  91. red AP1 seats vinyl color and code
  92. Front shock absorbers leaking.
  93. Car dies under load
  94. Starting Problems
  95. From Miata to S2K
  96. New aem fuel rail- now I've got high fuel pressure
  97. Push Button Fried... Common Issue?
  98. S2000 owners manual
  99. Recall for brake booster
  100. The Holy Grail
  101. s2000 burnt valves
  102. S2000 Aftermarket Wheel Horn Wiring
  103. headlights
  104. E46 m3 or S2000
  105. 05 s2k rearend feels loose when at low speeds
  106. How do you make a Toyota better?
  107. Z2000 project 240Z with S2000 swap & Supercharged!
  108. Q for all Socal S2000 Owners
  109. misfire during idle but goes away once over 1200 rpm
  110. New Here, Introduction and need some help.
  111. oil filter relocation
  112. Clunk sound - tricky 1st gear
  113. Question about preloading suspension.
  114. Can EPS fuse box be eliminated?????
  115. lights go out whenever i turn or hit a bump.
  116. GhettoNinja's (a.k.a JDMricist) S2000
  117. Just Bought an S2K
  118. What exhaust on s2k
  119. A Testament to the S2000
  120. Project PHNHOME (my '08 sg build thread)
  121. RU Faster than a Redneck
  122. s2k Meet/Dyno Day June 8th
  123. Problem bent frame :(
  124. Push Start Bulb
  125. Karl's Spoon S2K - Full Feature!
  126. coil overs
  127. Odd Steering wheel question.
  128. My Stolen S2000
  129. ACG Fuse Short
  130. ap2 lip
  131. Picked up another S2k :)
  132. 2001 GPW Honda S2000 F/S
  133. s2000 oil pressure help!!!!!
  134. S2000 Modulo Climax!
  135. ARC Intake for s2k
  136. Snap oversteer video on youtube
  137. S2000 are trouble?
  138. Looking at buying an S2000 but...
  139. In the market for an S2K... What to look out for?
  140. Reliable track S2000
  141. help: engine idles better when batt. disconnected??
  142. Looking for help on my build
  143. Any aftermarket OEM-style bumper covers, or are they dealer only?
  144. Head unit gets hot, no sound to speakers
  145. New S2000 Owner Intro
  146. soft top fold pattern?
  147. S2000 Side Skirt Length
  148. convertible top help!
  149. AP1 Vtec issue after AEM Tune
  150. Forced induction...
  151. question about swap high beam and daytime running light
  152. s2000 fuel setup advice 600whp
  153. HID light "strobing" while the car is turned off?
  154. S2000 color suggestions
  155. Where did you buy your Robbins softop ?
  156. k20/k24 S2000
  157. Best year for S2000?
  158. low compression on cyl 1, have the head off dont see any issue
  159. s2000 with oil leake on right side - help
  160. VIDEO of 2 s2000s, 25mm AP2v1, UK Mod Exhaust (Checkboard brothers)
  161. s2000 cluster plugs
  162. Hunting down a clutch pedal vibration
  163. type r steering wheel
  164. S2K OEM Hard Top (silverstone) W/ stand and OEM catchers and defrost wires! $3300
  165. Cleaning crinkle red valve cover
  166. just wrecked a 2003 s2000 w/ 550whp
  167. FBM prototype Intake Manifold. Looks promising.
  168. Black 17x8 RPF1's with tires
  169. Black AP1 Seats
  170. Kings Performance/Yellow Bullet S2K sets the WORLD RECORD!
  171. honda s2000 ap1 ecu needed !
  172. CEL po300 and p2647...anyone had this before??
  173. S2000 GETRAG v160 Rebuild (PICS)
  174. lightened flywheel???????
  175. Pretty sure it's my TCT
  176. Fluidampr harmonic damper
  177. Propellar shaft help.
  178. Possible Rocker Arm problem???
  179. Need help with cruise control
  180. RSG///AMUSE hardtop review
  181. Rockstar Garage Track-Ready S2000
  182. f22c build info
  183. maintenance required
  184. rear diffusers
  185. f22c1 seized, able to reuse block?
  186. Dear S2K owners. Need advice on this platform
  187. Good Machine Shop in NY?
  188. Clicking/ticking noise under braking from one wheel
  189. Valve guide seal or turbo?
  190. oem s2k spring rates
  191. Intermittent ABS
  192. S2000 Carbon Fiber Dash Project
  193. 17 inch wheel confusion
  194. My Kraftwerks Supercharged AP2
  195. Drive ratio 4.10 - 4.44 - 4.57 - 477
  196. ap1 clear headlight diffusers
  197. 2005 S2000 Differential Oil Leak
  198. jdm obd0 b16a pulley ignition issues
  199. convertible top noise
  200. identify this steering wheel please?
  201. Big guys chime in...
  202. S2000 2001 turbo kit install
  203. whos s2k is this ?
  204. sticky
  205. changing transmission, and clutch oil ***NEED HELP***
  206. HELP! Bumper got hit by sand and tiny rock
  207. spoon vs stock front bumper.
  208. Air Pump Delete W/AEM EMS
  209. Broken Valve, time for head work
  210. Clutch Slave Cylinder options without CDV (Clutch Delay Valve)
  211. Chicago AP1 Valve Adjustment??
  212. Can AP1 airbag be used on an 04 AP2 with blown airbag?
  213. CP Piston Clearance
  214. Just got retuned s2000 From Mase to Trackforged turbo manifold
  215. AP1 Modified GReddy turbo kit trade for ITB's and header...Opinions?
  216. Dallas shop that can bore f20 block
  217. radio gets very hot, no sound to speakers. AP1
  218. Airbag replacement & seat belts
  219. How wide and low can your s2000 go? bumpy roads?
  220. Adios to Hondas (and my S2k) for a while.
  221. **** Honda s2000 AP1 BURNING OIL*****
  222. S2k Loses power after vtec engages
  223. Electrical Connector C501
  224. Cluster Mileage Problem
  225. How fast do you go in the rain?
  226. Nitto Motivo tire test?
  227. Craft Square CF Mirror
  228. Hey!
  229. best fit for ap1 front lip on ebay?
  230. Shifter moving too much
  231. What are the best tires Sizes for a rpf1 17 x 8..
  232. 200 V6 Accord AC ower
  233. 200 V6 Accord AC ower
  234. 03: ABS cutting in and out
  235. How noisy are the s2000 on highways?
  236. cr rims
  237. Prototype S2K ITB Cold Air Intake - Trackforged
  238. have you seen the light blue s2000 with white rims around town Champaign??
  239. Xxr 521 For sale
  240. S2000 suspension problem...toe arm not lining up!
  241. Scraping sound coming from Rear while driving?
  242. 2000 S2k - Misfire/rough idle.
  243. Greddy Turbo kit owners
  244. Will my AEM fuel rail off my '03 AP1 work on an '06 s2000?
  245. qucik question about putting rims on my s2k
  246. s2000 Radio low volume , cant turn up ... Need help
  247. amuse r1 titan rattle
  248. Kings Performance Street S2King-New Set up runs 9.5's
  249. What clutch do I have?
  250. What is this on the catback exhaust?
