View Full Version : Honda S2000
- which fog lights for s2k
- newb here! looking for a few minor mods!
- r.i.p.f20c
- Reintroduction Thread: '03 GPW Supercharged Build
- Would I need a tune for my s2k?
- rack n pinion needs to be replaced? s2000 ap1!
- Global Time Attack @Buttonwillow
- Approach angle of S2000?
- OEM Pistons with Cast Iron Sleeves
- OMFG the clutch!!
- New clutch time!
- oversize cylinder bore, does it need to be tune?
- faulty hid unit in s2k???
- Turbo s2000 hp guesses
- S2K FRP and CF Hard Tops!!!
- Question about Godspeed Coils; Am I doing something wrong?
- F20C compression height-someone prove 30mm
- Engine rebuild help
- will these fit? work vs 18x8.5 +32 and 18x9.5 +26
- s2000 cr front spoiler
- Where are all the OEM tags on the AP1?
- My Berlina Black S2K...
- Just picked up a 05 S2K. What little things are their to keep an eye one?
- GOOD DEAL OR NOT?
- NEW GUY! (NH)
- code
- deleting smog equipment with piggyback
- Wiring an S2k cluster in eg/dc/ek??
- Possible S2K Purchase. Opinions?
- Rattle under 800rpm
- skid plate
- ap1 block re-sleeved, which piston rings?
- Driveshaft Shop releases new 2.9 version axles
- Aftermarket Bushings
- Kings Performance S2K NEW Numbers 9's on Drag Radials+StockMotor+KP Stage 1 turbo kit
- someone drop some knowledge on me bout s2k's
- S2000 topless decals/stickers
- 03 s2000 some new parts
- Ap1 Clutch issue
- Whats this bolt?
- "hot potato" potential s2k purchase, chime in
- Hardtop puchase question!
- Reliability & Durability
- HELP: Wheel and tire size for auto-x & road racing
- trunk problem on my ap1
- mugen hub boss dc5/s2000?
- New TO HONDA TECH
- eps issues
- Does an S2K bellhousing match up with f22b??
- Side Skirt Question?
- new head unit, will door be able to close??
- 18x8.5 +35
- ASM S2000 Build
- Quick s2000 question
- s2k swap question
- 1 WHEEL STICKS OUT MORE THEN THE OTHERE ON THE REAR
- water gets into my 06 s2k's tail light
- tires for stock wheels
- The new S2000 trend of the year
- Anyone ever did a comparison?
- s2ks with real tires
- need help whit advan 18x8,5
- AP1 vs AP2 front bumper
- AP2 Stance Wheel Sizing Question! Stuck in a Pickle!
- Rubber gasket for Front Lip Spoiler
- carbon fiber trunk front panel?
- Took my bumper off. problem....
- s2000 AP1 rear diff help
- Window Auto Down
- Scarlett's Welcome - S2k Vid
- Ap2 Front Bumper on Ap1 s2k
- shipping S2k Hardtop
- Honda S2000 CR Hp
- 2008 si trade for s2000 or sell
- Re-seal headlight?
- Question related to clutch buzz. AP1
- Intake cover on Honda s2000
- 04' S2000 ECU options?
- s2000 engine in to....
- What "rearlip" ??
- s2000 on vegas strip
- Engine bore and deck height
- 2004 Honda S2000 Rebuild - 8's on gate
- i'm thinking about picking this up... help
- Interested Buyer
- How many o2 spacers do you guys use for your test pipe?
- S2000 Makeover
- In the market for an s2k
- What is the best chip as to performance?
- Help diagnose problem. 2001 s2k
- Turbo Oil Return Question
- n00b with an AP2 searching for guidance!
- factory alarm keeps going off whenever plugged in
- cold air intake or modified airbox
- ap1 flywheel in ap2
- My ap1
- Factory Alarm Problems - Help!
- New S2K owner!
- which engine oil is good for my 2006 s2k?
- Eibach Pro Kit question
- What are best wheels and tyres for a S2000
- Question about coilovers
- Need Help: Rear Turn Signal
- Please HELP Identify this Paint Color!
- Modifry ECT Temp Converter for Ap1?
- AP1 Front Lip/Spoiler Replacement???
- Cheap Tempory Seat Options for S2k
- To buy or pass?
- seat color question
- Future AP1 Owner
- AP1 shifts much smoother when cold?
- ECT Sensor?
- Engine/transmission weight
- My 2007 honda s2000 dies when I press the clutch?
- vibrate on startup normal?
- Rollbar
- What hardtop sites are still working (OEM)
- S2k Engine bay Ink
- how hard is it to find an f22c crank
- Need some advice about pricing on s2000
- s2000 questions & + 6'2" = Problems ?
- question about 2006 s2k's fuel cap
- Looking for an S2k
- Apwhat Brake Bleeding/Fluid change Guide
- QUICK question about mileage???
- greddy turbo kit!!!
- Post your power,new or old, inspire other members to mod!!!
- Help On My S2k 03
- AP1 vs AP2 Core Support
- New OEM hardtop link?
- S2000 rear drive shaft.
- Apwhat Coilover/Spring install guide
- ap1 alll motor?
- My Ap2 timeline
- Rattling Tranny in my s2000?!?!?
- help me figue out this noise
- Lowering and handling
- Tein S tech Vs H tech S2000 HELP!?!?!?!?
- 713whp Stock 2.0 Motor Dyno + Street Run
- Aenoy black s2k :D
- turbo?
- How many watts do an S2000 ballast produce?
- Which Springs Are Best for s2k
- 18x8 +42 18x9 +42 will they fit?
- Walked out to my car today to find this...
- new here and to honda!! ideas!!
- Turbo S2K from Russia Moscow
- Southern California Auto Sales
- S2000 ap1 cluster male pigtails?
- Is it possible to have S2k m/t attached to b16???
- So how is the MOST "RESPECTED" motor/engine building on the west coast?
- Does any one know what a "flex panel" is?
- Independent Honda service in Houston area
- Electrical problems on my S2000
- s2000 hardtop
- 03 S2000 Lights And Motor Suddenly Shut Off Completely!
- Trailer Hitch AP!
- GPW s2k project by motoring spirit -street culture couture-
- track time, 4600mi trip, blew a clutch, crossed 50k miles, track time, broke a diff!
- CEL and bogging Plus almost no oil
- Article: Entry Level ap1/ap2 building
- 225/45/17 on AP2 front wheel
- Whats everybody's thoughts on side strakes?
- Bad Shaking at 65+
- another new s2000 owner
- HONDZLA vs all ( race compilation gtr, bike, cobra etc )
- Oil Consumption, 2001 s2000, 61K miles
- S2000 tow hitch
- Quick Question About OEM Lug Nuts
- honda s2000 cr FAQ's
- HSK HI power Dually Exhaust??
- '03 S2K Rear Bearing Squeak Over and Over
- What are ap2 v1 Wheels
- Passenger blinkers dont work!!!
- F20c with K20a crank
- POLL: AP1 Front w/ Lip or AP2 front with lip????
- What is it with S2000's?
- Best springs with stock shocks?
- What rear spoiler is this?
- rear camber adjustment
- need help brainstorming overheating issue
- GT2871RLE-32 garrett
- LOUD NOISE ON TOP END
- S2000 center council
- most recent picture of my S2000 =)
- injectors
- S2000 Brake questions
- NEW S2000 OWNER HERE!!
- S2k Speaker question ??
- Need help if this is a good deal?
- sound deadening
- Is newer always better?
- Salt and Pepper S2k Shoot
- Cannot identify CEL code - '03 S2000
- Looking for a good idea to put on s2000
- HELP! Engine light on after ECU been plugged back
- P0219 Over Speed Condtion Date?
- sagged shift boot
- Help with buyin this S2000 Need INFO!
- A Getrag Supra tranny in an S2000?
- in need of a s2000 engine
- Question, Clutch Issue?
- 03 S2000 Passenger Window Problem!
- My FR02 S2k, mostly stock but 70k and immaculate
- My 443whp Stock s2000 Ap1 Turbo Build
- Start up noise.
- Such a nasty S2k
- breaking drive axles...help
- J35 Swapped S2000 Running, Intercrew Auto Salon, Video inside
- Gorilla RE's very own Nick udstad's feature on Mayday Garage!
- S2000 OEM seat
- Forged Performance Turbo kit, pics
- Fortune Auto 500 series Coilover Review
- help on getting hot
- My 03 GPW S2000 Build
- I need help with my s2000!
- Oem hardtop owner
- Audio controls and stock cd player?
- replacing one coil vs all four
- Having Secondary Air Injection Problems?
- s2000 block
- Stolen seats...need new seat belts. HELP!
- this is good?
- New S2000 owner. :)
- Ap2 transmission leak.. Help please.
- S2k factory stereo controls
- megan racing front and rear roll centers
- Hardtop Noise
- S2000 Trans Help
- Hard top questions
- Diff = 23mm bolt?
- Does anyone know where i can find this body kit?
- Carpet removal questions.
- update: 625hp stock motor
- Should I use this replacement CV axle?
- Adding sound system into my S2K?
- F/S: 2005 AP2 S2000 Seats
- S2000 Ecu Pinout
- Stock Headlights?
- roll bar help please
- Opinions... My AP1 headlights retain moisture.
- VIDEO: S2000 Autcross today at the Sheriff's Track
- Just hit 150k what to replace.
- S2000 headlight protectors?
- 2jz s2000 from action auto
- Need help on wheels sizeing
- Track S2k time laps
- Coming Soon...Food for thought
- changing ecu's ap2 to ap2
