PDA
View Full Version : Honda S2000
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60
  1. s2000 Bonneville build
  2. CEL + P1411
  3. I was misinformed
  4. 2026 S2000 Coming Soon?
  5. S2000 Electrical connectors
  6. Help me identify the ticking noise
  7. 20 PSI Fuel Pressure
  8. !st timer post
  9. My S2KAP2
  10. secondary air pump
  11. Help Identifying the seats in my S2000
  12. 05 Misfire Problems
  13. 2005 S2000 killing batteries
  14. AP1 or AP 2 Tranny
  15. spring differences
  16. Steering control module
  17. s2000 build
  18. New Clutch Master Cylinder Missing Boot??
  19. S2000 Vtec Failure P1259
  20. s2000
  21. Window not working with Top
  22. I got tired of breaking transmissions (dct swap)
  23. Urge Designs ITBs
  24. BMW E30 WITH S2000 ENGINE - BUILD
  25. Urgent help needed with S2000 MY00 keyless entry module
  26. Ap1 S2000 No Power to Ecu or Fuel Pump
  27. S2000 Build
  28. Changed out my O2 Sensor
  29. Honda S2000 AP1 to AP2 headlight retrofit: How to make your auto level adjust working
  30. New p0135 after clutch install
  31. Why Are Negative Offset Rims So Hard To Find?
  32. Cold start idle issue/flutter
  33. Source for JDM AP1 headlights or reputable modding site
  34. S2000 drivetrain issue
  35. S2000 Engine Ticking
  36. good exhaust
  37. Looking on some valve train confirmation please (keeper angle)
  38. light squeal when accelerating
  39. Power Steering failure EPS reset noise
  40. F20C Vtec oil pressure sensor/switch bypass
  41. Please recommend best jDM under 20,000$
  42. Engine/Transmission Options
  43. My stock s2k
  44. Honda's Hardcore Sports Car - Slip Angle Spotlight
  45. ign switch shear bolts 2004 S2000
  46. DCI Nitrous Controls!
  47. WiP/PoC: S2K AP2 OEM tail lights on AP1, without cutting the car.
  48. Full composite body for S2000
  49. Troubleshooting 2000 no-start
  50. Main bearings clearance
  51. K24W s2000????
  52. Intermittent Green Key Problem
  53. passenger side window
  54. Catalytic converter
  55. Windshield for s2k?
  56. F20c block
  57. is there a replacement for discontinued torque sensor assembly for a 2002 S2000?
  58. My new to me 2006 Honda S2k!
  59. Swift SPEC-R Wheel Fitment!
  60. Is the lock nut for CRV same as one for civic?
  61. synthetic viscosity
  62. RPM Stumbles after revving
  63. Best Ap1 replacement soft top
  64. Very strong fuel vapor smell in hot weather
  65. CLUTCH START SWTICH STOP REPLACEMENT
  66. Stabbing the transmission
  67. S2K Trans. & Diff. fluids
  68. 99 honda s2000 engine cuts out at 7000RPM
  69. Need help raising height of s2k
  70. Cluster pinout 2004 vs 2006
  71. Trans noise
  72. rediator coolant not circulating
  73. AP1 F20 INTO AP2 CHASSIS HELP
  74. repair cracked cam cap
  75. how to reduce the oversteer and rear tires kicking out suddenly?
  76. Check Engine Light On - No Codes
  77. s2000 doesnt accelerate when flooring it
  78. s2000 maximum amount to skim head
  79. raising the car
  80. Programming Remote
  81. Small hole in soft top, please help!
  82. Fluctuating RPMs after cleaning throttle body and iacv
  83. ADJUST HEAD LIGHT s2000
  84. Suddenly I lost cluster dump (93C66) for HONDA S2000. Maybe somebody has a whole dump
  85. Clutch chatter issue or ignore?
  86. Greeting from Sactown.....new to this forum
  87. fuel damper line
  88. Softop/Hardtop ??
  89. [STOLEN] 2001 Spa Yellow AP1 in Somerset County, NJ
  90. Seized front lca bolts
  91. stalling S2000
  92. Timing Chain replacement, do I need Timing Sprockets?
  93. Want to get some ideas about to buy a set of wheels
  94. compress piston on the tct
  95. Possible purchase of 2005 S2000?
  96. Differential
  97. diff swap
  98. Advice: S660
  99. JDM s2000 cluster remove speed limit
  100. s2000 2jz
  101. Restoring Questions.
  102. Steering rack issue
  103. Tapping Noise - Higher Idle Than Usual
  104. zero compression
  105. Video: Honda S2000 – Beauty in Refinement
  106. S2000 Build Suggestions
  107. S2000 Evap operational questions
  108. S2000 Evap operational questions
  109. Question on AP1 Cylinder Head
  110. S2000 clutch acting funny
  111. 00MY AP1 The new daily
  112. fixing a wrecked auction AP1
  113. What year of s2000 Ap1 is best?
  114. SOS 20 amp re wire kit
  115. lowering S2K problem
  116. Slight wine like sc
  117. S2000 bad wheel bearing
  118. How to tell which year a cluster is from?
  119. Why is my headlight browning?
  120. Tire sizes and offset on my s2000?????
  121. Honda s2000 ap1 2 step, can anyone give me info please?
  122. S2000 Start button disassembly
  123. S2000 suspension parts
  124. can this built s2000 be supercharted/turbo'd?
  125. S/C vs Turbo For DD w/ minimal track usage
  126. Favorite Front lip, and why?
  127. Nitrous f20c
  128. AP1 and AP2 dash vents the same?
  129. Ap1 w/ Kpro Illinois emission
  130. 2017 s2000
  131. Anyone know how to power up a S2000 cluster ?
  132. S2000 built motor, what to do with ECU
  133. Shock replacement
  134. J30 Swap in an S2000
  135. DC/MD/VA - pFAB TURBO KIT s2000//COMPLETE with Engine Management
  136. s2000 wont start
  137. Under hood label
  138. fresh of the block
  139. Ballade Sports Double Carbon OEM Style Hardtop Review
  140. Finally pulled the trigger!
  141. is nobody using ID 725 injectors for s2000?
  142. Honda Reviving S2000 ?
  143. Clutch
  144. S2k eps connectors
  145. ____ Bride Seats verify authenticity _____
  146. 2006 ap2. Traction stuck on?
  147. Buying a salvaged S2000: Need some advice
  148. Engine won't hold idle - please help!
  149. S2000 Hamilton Palmer Immobiliser Issue
  150. What Holds Value a S2000 or...
  151. What do I need to install GC/Koni setup?
  152. AP1 Rear Bumper Cap (LEFT EXIT) ???
  153. interior help
  154. Now have 2 S2000's... just picked up an AP2 with 23,000 miles
  155. help! gauge cluster stopped working
  156. Whistle Noise And Knock Coming From My Engine
  157. Need help 2003 s2000 wont start
  158. my new project !!!
  159. 15mm studded spacers on AP1 wheels
  160. Valve adjustment on my 08 AP2...engine seems a little more noisier?
  161. Idle problem after TB install
  162. Need help from the s2k Guru's
  163. First time? Electronic Switchable Hood Exit Exhaust
  164. Need a good shop in MD. Any ideas?
  165. Sorta New to honda-tech
  166. New S2000, new thread.
  167. 2005 s2k cruise control
  168. Kraftwerks C38 supercharged S2K
  169. Help s2000 failed mot
  170. Terrible Patch Job!
  171. Top Fuel S2000
  172. Bad vibrations
  173. Wheel ID help needed.
  174. What can I do with these remaining parts on a S2000?
  175. Small S2000 Meet PR
  176. getting lowered S2k legal in Hawaii
  177. AP1 instrument wiring harness in a 2003
  178. Help
  179. The gameplay for my s2000
  180. Idling high on it's own
  181. Help
  182. Surfboard on roof?
  183. s2000 hids
  184. Soft pedal after installing new clutch!
  185. dealing with dummy air inlets and digital dash
  186. Random Misfired issue
  187. Car not starting
  188. Help with header install
  189. Help buying high mileage s2000
  190. OBD port not getting any power?
  191. KING Amer's "Game Changer" Stock Chassis Honda S2000 1st 1/4 mile passes
  192. Starter motor occasionally makes a harsh sound
  193. S2000 DIY hybrid
  194. Maybe buy an ap1 S2000
  195. I want to buy a s2000
  196. ap1 coolant over flow problems
  197. vtec solenoid thread pitch bolts HELP pic
  198. Flat towing s2000
  199. problems after headgasket change
  200. Auxiliary under hood fuse box question.
  201. used ap1
  202. can anyone help me find oem rear catchers
  203. Phearable.net Tuned 704 WHP S2000 Stock Bottom End
  204. AEM EMS V2 Issued starting
  205. purchased 2004 ap2
  206. Ring and Pinion
  207. 2001 suspension upgrades
  208. Massive Vibrations from the Rear S2k
  209. widow door stop?
  210. Which S2000?
  211. Abs plug missing?
  212. Problem with seat locking ? Any help or ideas ?
  213. O2 sensor brands?
  214. no power to my drivers side wiring harness
  215. Best brakes w/ stock wheels (AP1)?
  216. 05 F22 INTO 06 S2000 - INTERNALLY THE SAME???
  217. Can anyone tell me what this is
  218. s2000 hardtop
  219. Looking at buying AP1
  220. Used car experience?
  221. work cr kai???
  222. Too hot to sit shotgun?
  223. S2000 EPS light on/won't go pass 5k rpm/limp mode??
  224. Any tips on how to maintain a supercharger?
  225. NorCal S2ki 2014 Meet
  226. Anybody using kenne bell BAS here? Need help with install.
  227. S2000 aftermarket intake manifold
  228. 2006 AP2 + CR steering rack...CR EPS required?
  229. Tires going bad too soon?
  230. RHD SubFrame on LHD
  231. O2 sensor wiring
  232. O2 sensor question
  233. POST YOUR KEYCHAINS!
  234. s2000 bought from dealer
  235. Intermittent no start problem
  236. How do I reset my srs light
  237. spun bearing s2k ? or thrust bearing
  238. Denso o2 sensor question
  239. I need help
  240. Installed Odyssey PC680 car wants to die when coming to stop!
  241. 2002 AP1 Track-ster
  242. S2000 power delivery question
  243. Purchasing an 01 s2000
  244. Purchasing an 01 s2000
  245. Idle issue?
  246. STOLEN!!! PLEASE HELP!
  247. S2000 automatic headlights
  248. s2k trans stuff
  249. J's header installation
  250. concept s2000 new gen?!? will it happen?
