View Full Version : Honda S2000
- What does your S2000 look like? Should i get one? Help!
- wheels/tires
- Retuned. Now running warm and no heat... thermostat??
- Pic Request: polished OEM S2k mufflers???
- Could be owning an S2000 by the end of the week!
- yellow highbeam bulbs
- What's this s2k worth?
- s2k engine rebuilding... got a couple of Questions
- hard top motor mounts?
- I'm getting driveshaft vibration under load.
- Ap2 bumpers on an AP1
- Loud rattling noise at low RPMs (only under 2,500)
- Who all has broke out their s2ks?
- s2k rear end.
- how tall are you sub 5'6 people ENTER!!!!!
- Which is the primary 02?
- New wheels, but afraid to mount
- show me your center consoles
- Trade-in Questions
- where can i get this wing?
- CEL = Misfire MY02
- Frame damaged S2000 value.
- Is this a good deal for an s2000?
- got bored, made a time lapse video of my S
- where to get a decent replacement clutch?
- ***AFI’s S2000 For The Modified Magazine Tuner Shootout***
- Does anyone know where to source JDM parts?
- Throttle position sensor problem
- What size oil restrictor?
- AP1 OEM wheel specs
- aem ems users
- what cams?
- radio / stereo system
- Anyone run 18x9.5 et45 on your rear wheel?
- Tail Light Question
- Help with purchasing new Axis MOD wheels
- s2000 vibration
- AP1 or AP2 for turbo setup???
- S2000 Engine Temperature PHAIL
- About to purchase an Ap1 got some ?'s
- S2000 cluch write up complete, check it out
- Ap1 engine noise help!!!(ticking/rattle)
- Removing underhood heat blanket ??
- Filter choice for modded stock airbox
- So it happened.
- Help? IACV Dimensions
- Fog lights for ap2
- What the hell is this? Sensor?
- AP1 or AP2?
- s3000
- Widebands? Where do you run them?
- J's Tsuchinoko Intake?
- Finally its done. Need critiques on my S2000 engine removal and install guide...
- lowering my s2k
- fender roller fitment
- quick question about rims
- 18x9.5" 55 offset rear wheel on lowered S2k...will it rub?
- J's Racing complete SPL engine
- Winshield Wiper Problem
- Glass soft top + hard top
- Turbo S2k (Power and emmissions question)
- What coolant? 05 S2K
- Weird starting problem.
- Need help Picking out shoes for my s2k
- i need help pleasssseeeee
- Bypassing Immobiliser to fit F20c into AE86
- stock suspension
- Question
- Clutch or Master cylinder proglem????? help
- Where can I find this manifold?
- 00-03 seats different than 04-05
- DIY rear bumper vents
- Spark plugs?
- S2000 JDM Key
- prelude to s2000
- post your steering wheel setups!!
- Aftermarket seat rails (Mugen)
- Taking apart seats. Please let me know ASAP.
- How much power will stock rods hold?
- Ceramic window tint
- vw/audi guy makin the change
- PasswordJDM Money Shot contest
- Spuddering problems?
- Sports Modulo S2000 Concept
- anyone on here going to the Dragon april 23-26?
- j's racing rear diffuser!!!
- What about Vibrant mufflers?
- AP2 Red Interior?
- Should I get A s2000 help
- Turbo s2000?
- S2000 turbo or k20 turbo civic hatch?
- Differential question
- Cruise control not working, need help.
- Need some help from the s2000 GODS!
- Invidia 70m test pipe, have you ever see this?
- Wiring in Accessories
- s2k emblem
- Oil pan removal, WTH ?
- f20c and f20b IM
- s2000 vibration
- S2000 owners, how much does your insurance cost you per year?
- Cold air Intakes - are they worth it for the money
- Help: Engine Wiring!
- t1r header new version
- NSX wheels 94-01
- S2000 engine wires
- Do I have a useless OEM RADIO?
- Hartop install...
- s2000 owners i need your help
- problem with Skunk2 springs on AP2...
- 07 S2K How wide can i go?
- Kpro S2k install (extra sensors)
- all motor s2k
- problems with 2000 s2000
- Fuel Doors - Carbon Fiber / Color ...etc
- Starter location???
- 2003 Silverstone s2000
- Body damage
- High Desert, Ca
- No Brake Lights
- radio door mod, fit your radio without cutting
- 500whp or Bust (Picture Intense) 05 S2K w/30r
- wrecked s2k wont start?????
- Tire+rim Question
- 2009 S2000 last year?
- not realy tech, but BIG laugh
- Engine Died while in 6th gear doing 70 mph...help
- for the AEM guys, little experiment with the IAT sensor
- s2000 steering wheel 00-03 04-05
- new clutch......help.....pics inside
- my Mase Engineering turbo build
- 543WHP and 371WTQ Profunction Automotive Tuned
- Hardtop Help!!
- 5zigen ZR+ question
- New member and owner of a 2008 GPW s2000
- Diffrence in 2001-2005 S2K's
- put on my Advan RGII's today
- Pic/DIY Request:06+ with J's racing Intake
- Does anyone have pics of a S2000 with a rear lower tie bar
- ap2 door speaker install help
- s2k aftermarket wheel question.
- omghi2u S2K Section
- New to the World of S2000
- i need injectors
- S2000 at 80K miles.
- Clearence problems putting in motor.
- e manage on turbo ap1 S2000
- Mishimoto Aluminum Radiator ??
- S2000 OEM parts??
- damage
- Tapping OEM Radiator
- Couple questions about this THEFT s2000
- new to the s2k and need your help.
- Convertible top problem
- ...GT30 / S2000 build...
- Attatching harnesses
- S2K wheels help
- 2004 s2000 Clutch Delay Valve Question
- HELP! blinkers stopped working!
- Who has a modifry harness?
- Alternator change help needed Asap!
- Does your S2000..
- STI BBS wheels on s2000
- 701 whp AP1 S2000
- J's racing Roll Center adjust, # question
- anyone work @ honda? Want to check a service record
- Who copied who?
- s2000 "rear cover" for the CR model
- Some Noob Questions:
- Spoon thermostat in a s2k
- Sandwhich Adapter
- Good parts websites for brake rotors?
- s2k brake question pls help......
- Boosting ap1 without intercooler?
- Photoshop request AP2 V1s rims in different colors
- Flywheel & PP Torque Specs?
- 01 s2000 random misfires
- EVO VS. S2000 which should i get?
- Starter grind when Cold
- ► ~~ Official S2000 For Sale/WTB Thread ~~
- Electrical Problem
- Need some basic S2K info.
- DIY custom seat brackets
- Manifold Exhaust Studs
- Help!!! Passenger window issue.
- Cel p1399
- Engine Pull or Engine drop?
- Work Emo Cr Kai + Spoon Cali?
- Looking to buy a s2000 have a few q's ?
- Burning oil
- Good Ol' Clutch Swap
- Knock Sensor
- Big guy wanting a s2000
- New car new 1/4 et
- 190 hp on ap1 s2000
- - S2000 AP2 Clear LED Headlights - (Pictures and video)
- Coolant problem! =[
- My tech post for the year: brake light on a BYS wing.
- Brake pads....
- Project01 garage honda s2000 turbo
- How not to roll the fenders on an S2000
- Looking to buy a S2K
- 18" staggered TSW Kyalami's
- Loud transmission and Jerks
- best rims for s2k...pictures???
- S2000 owners...Would you like to see a group buy?
- pic request of 2 s2ks in a tunnel
- oil pan help!!
- New Wheels.
- What turbo build would you guys like to see?
- Calling any/all hockey players
- DC5 Brembos on a S2000?
- Just picked up an 00 S2k
- Name these Mugen Wheels
- who's going?
- Fuel Filter ?
- ek foglights on s2k
- ap1 cel TDC sensor.
- New guy checking in
- k-pro OR fpr
- let me know what yall think.......
- Quick Comp test [disable injectors]
- MEGAN Racing OE-RS vs. Invidia Q300
- S2000 ITB Questions
- Hard Time Choosing Seibon Hood..
- Buzzing noise coming from soft top
- s2000 ap1-ap2 conversion
- act clutch kit vs f1 racing clutch kit
- Honda reveals S2000 Ultimate Edition
- s2k in the snow???
- s2000 steering wheel size
- vtec bogging..
- oil drain plug thread
- short person driving s2k?
- Exhaust size question.
- QTR mile ???
- Removing stub axles from Quaife?
- Act HS1-HDSS clutch, help.....
- Random pics on a cold day (2007 GPW)
- my DIY brake ducts
- Vtec Controller
- Do they Make a bracket for your ipod?
- s2k itb's. bad idea? good idea?
- Need to vent haha s2000
- S2K steering rack measurements.
- What we all wish would have never happened... :(
- Value drop in s2000's
- s2k ckp question.
- Check out my new Wheels
- Gutting the cats (Stock Exhaust)
