2001 S2000 leaking fuel injector
I have a 2001 S2000 that has a leaking fuel injector. Im pretty sure its an o-ring, but before I pull it apart to replace it, I am asking you guys if there are any tips/tricks to getting this done. Any help would be greatly appreciated.
Re: 2001 S2000 leaking fuel injector
its pretty straight forward...pop your gas cap open and pull the fuel pump fuse and crank the engine a couple times to de-pressurized the fuel rail so you don't get as much fuel all over the place...make sure you put some vasoline on the new O-rings too
mrbsponge
04-09-2005 01:35 PM
