Honda S2000 Honda S2000
Weird engine noise
Old Nov 22, 2013 | 03:03 PM
OFCRPLZ's Avatar
Default Weird engine noise
About two days ago my s2000 started making a grinding noise around 3000 rpm, and it now drops rpms and recovers when i stop at a light, what can be causing this noise? heres a link to a video of it grinding
Any advice will be greatly appreciated!
Old Nov 23, 2013 | 07:06 AM
beandip's Avatar
Default Re: Weird engine noise
Doesnt sound like grinding to me, but that might just be because its a video and Im not in front of the car. From the video, it sounds like a fuel injector failing to spray or doing bursts of spray.
Old Nov 23, 2013 | 11:59 AM
pettyboy69's Avatar
have you checked the timing chain tensioner? I know they are notorious for going bad on these cars
Old Nov 24, 2013 | 08:30 AM
OFCRPLZ's Avatar
I was told that it may be the valves that need to be adjusted, would a messed up valve cause the vibrating noise?
Old Nov 24, 2013 | 09:23 PM
beandip's Avatar
That might be true and might explain why I hear the spitting. Have you opened the engine up at all? I bet you have some burnt scoring under your valve cover.
Old Dec 10, 2013 | 08:32 AM
Tight-R's Avatar
Just sounds like a heat shield rattling.
Old Jan 9, 2014 | 07:38 AM
Untengijutsu's Avatar
Exactly, sound like a vibration of a part at a specific rpm, harmonic resonance of a certain material or parts at specifid rpm.
Injector problem don't make rpm increase that regular.
Also, the TCT may be a cause, hard to tell on this video.
Swap for a brand new, modify this one by InlinePRO or billman or make de DIY repair on your unit.
This repair is from $0 to about $160.
v8killaz
May 13, 2009 09:41 PM
MKX-R
Jul 9, 2003 12:54 PM
