PDA
View Full Version : Honda S2000
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 [19] 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60
  1. Moderator(s)...Please Help
  2. S2000 Motor Swaps?
  3. Accident story (already posted on s2ki for duel members)
  4. grounding system
  5. Dang
  6. 17x9+45
  7. BC Racing Coilovers DYNO Plots. Thoughts? Comments?
  8. Anyone going to Homecoming?
  9. S2000 cr HARDTOPS
  10. Transmission spring washer
  11. Gas Cap issue....
  12. vafc questions
  13. Alignment Complete, Questions Now
  14. suspension/ coilovers
  15. Velocity Trends 07 S2K Custom Turbo Kit Build Pics
  16. hey everyone!
  17. ► ~~ Official Introduction/I'm new here Thread ~~
  18. KBee Coilovers.... anyone try these?
  19. will a new stock clutch fix clutch buzz?
  20. LS1 S2000
  21. My new s2k, coming from a civic.. lol PICS!
  22. question about transmission
  23. steering
  24. O2 Check Engine Light
  25. Performance chips
  26. Newb here with a QUESTION.
  27. A/C compressor clutch sheared off?
  28. s2000 BYS duckbill???
  29. better Transmission oil
  30. anyone know this Hardtop??
  31. Okasa Projects Coil Packs
  32. cant fig this out
  33. similar difference s2k & integra type R
  34. Quick fix for cracked lip.
  35. Soft Top Question: Cleaning them
  36. timing chain tensioner
  37. cuting off coolant to the intake manifold
  38. Quick question about a car that was once SC
  39. j's racing tie rod ends and swift replacement coils
  40. Miata Based Questions
  41. Ricks leather.....
  42. F20c Piston- dome volume
  43. Help picking out an exhaust
  44. Chargespeed Brake ducts
  45. Steering feel?
  46. apexi vafc 2 Question
  47. sorry about this ek fog lamps for s2000
  48. My s2000
  49. im new to honda tech
  50. new to s2k got a few Q
  51. Quick test pipe question
  52. ap1 vs. ap2 header
  53. Couple of strange sounds.
  54. thanks to those who helped. . .
  55. Used Transmissions
  56. S2000 Blue Soft Top for SAle
  57. Honda S600 - The Grandaddy of 'em all!
  58. maintence light
  59. 700 whp s2000?
  60. Ground Control Vs. Spring question
  61. KONI/ESPELIR Driver side is .25 inch lower than passenger side...
  62. Berk header / Hks catback !
  63. AP1 steering wheel w/airbag
  64. Shift beeper?
  65. fix the camber with washers ????
  66. shakes REALLY BAD as u accelarate HELP!!!
  67. PULLS TO THE LEFT AND BACK WHEN THROTTLE. HELP!!!
  68. Synapse Engineering 40mm W/G
  69. engine and power of 00 - 03 and 04+ S2k
  70. My first HPDE event at Pocono Raceway (Pics and thoughts)
  71. Aftermarket Parts Question
  72. EXHAUST?
  73. well this is a really fast question
  74. Poped the cherry on my S
  75. I want everyones opinion on exhaust for an ap2
  76. s2k handling and other
  77. ap2 stock header?
  78. *******???s2000 cabin filter???**********
  79. uninstall NOS help
  80. Disable Autolamp!~
  81. Got s2k 2 months ago, but he is pics
  82. *What could make my injectors bad if not super charger?*
  83. Manufacture warrenty.....
  84. alignment question(s)...
  85. S2000 cams ?
  86. turbo/exhaust
  87. S2000 16" wheel vs 17"
  88. What year S2K came with what motor??
  89. Quick question for you all
  90. LOOKING FOR HONDA S2000 SEAT BOLTS THAT LOCK...???....
  91. AP2 s2000 vs. 05 RSX type S
  92. Bad transmission?(not clutch buzz)
  93. "Long Term" 2007 issues?
  94. Better 2sk handling
  95. Robbins top material: Stayfast vs Pinpoint?
  96. Rear Dif Problem, expensive fix?
  97. Which white centercaps fit?
  98. any s2000 mechanics free today (san diego)???
  99. Exhaust System for S2000
  100. Hardtop Question!
  101. Mobil 1 5w-20 Info
  102. can i take the rool bar off? hardtop s2000...
  103. buying s2k tomorrow, TSB question
  104. nopi. any one going
  105. cusco 4pt roll cage seat room??
  106. Installing dual valve springs ap1
  107. modding a s2k
  108. Can I make em work?
  109. s2000 seat bracket bolts
  110. S2000 And Volks...always a good combo!
  111. 340WHP 231TQ @ 8.5 psi good?
  112. I love the smell of a brand new car
  113. Check out 3" stock looking exhaust system using Thermal mufflers.
  114. how do i change my bulbs?
  115. idle problem with s2k
  116. Good News!
  117. Test pipe question
  118. Was insurance this bad for you guys?
  119. Future of the S2000?
  120. Hey I have the Honda service manual for the AP1
  121. **PROBLEMS WITH S2K***
  122. Hello, I drive an s2000 and I am New!
  123. Dyno'ed the s2k Yesturday...
  124. NA Pistons??
  125. CF hood or no
  126. Took my car to the track for the first time! Need advice.
  127. another hardtop question
  128. looking into buying an s2k
  129. MPG!!
  130. What realistically are you looking at getting after the S2000?
  131. skunk2 exhaust for sale!
  132. Plans for my future S2000
  133. Aftermarket Cluster for S2k
  134. MUGEN CARBON HOOD [SALE]
  135. 2004-2005 airbag on 2000-2003 steering wheel?
  136. soft top plastic to glass with defroster conversion NEEED HELLLLLP
  137. !!!*What size are stock injectors on the 01 S2K*!!!
  138. Not to beat a dead horse but....
  139. Idles fine until you touch the gas/brakes/etc
  140. bc racing coilovers are available for the honda s2000
  141. Common S2000 Problems/Issues
  142. LOWERING SPRINGS
  143. random ? about aftermarket bumper
  144. Testing Waters, how much can I get for my car?
  145. axis HALO - watcha guys think? * * CHECK THIS OUT * *
  146. Magical Gas !
  147. Shaking in the rear when accelerating. Need Help!
  148. does the s2000 light up?? when u turn on the lights?
  149. 97mm crank storker kit???
  150. hello, first post
  151. S2000 driveline upgrades
  152. Reverse Lights no working.
  153. ap1 exhaust on a ap2
  154. Oem Ap1 lip....ABS or Urethane?
  155. oil consumption
  156. question about warranty
  157. Blue-light special for speeders in Alabama
  158. couple of questions that i need answers to.
  159. Question about Koni shock stiffness HELP!!
  160. Torque
  161. Pucked up my s2k on saturday...
  162. how do you move the fuel line in the trunk out the way?
  163. 2002 s2k vs. 2007 si sedan
  164. Who here has experienced the "Money Shift" in their s2k?
  165. Lol Funny story. and serious question.......
  166. Oil change
  167. I'm so glad I got my car back...
  168. Need help with flywheel please.
  169. TracySports S2000
  170. left window open! doh! helpppppp!
  171. Question about Espelir springs install
  172. VTEC RPM
  173. Performance Mods
  174. Cat Test Pipe
  175. S2000 guys need advice.
  176. AP1 or AP2???
  177. aftermarket pistons for a turbo s2000 setup
  178. kwik question
  179. Tuning Help!!!
  180. Is my HID bulb out or is it my Ballast?
  181. yet another offset question...
  182. s2000 ap1 2.4L stroker?
  183. WTB: OEM or CF TRUNK, Rear Ap2 Bumper, and AP1 or Ap2 tailights
  184. Working a deal on a Hardtop
  185. Need Sugestions For Rims on my 2006 AP2???
  186. What direction does the driveshaft spin?
  187. 2006+ S2K EMS
  188. paint job.
  189. Baseline Dyno Thought i would share.
  190. Finally purchased one.
  191. diff preload
  192. Some new pics of the AP2
  193. New AP2 Owner -- Silverstone/Black
  194. S2000 with Rev Hard Turbo Kit running into problems...HELP...
  195. Suspension Question.
  196. Just painted my calipers...
  197. my car is for sale guys...just a link
  198. Oil change
  199. photoshoot with my s2k and friends wips
  200. Camber kit. help
  201. Can someone do me a favor....? Tire size?
  202. I just bought a 07 white S2000. anyone know which deep dish bronze rims to put on it????
  203. Exotic car run in NJe
  204. 4.77 Final Drive >> where to buy ?!
  205. Taking off the back plastic window in 2001 S2K
  206. noob question
  207. 17X7.5 wheels
  208. Wheel ?
  209. Alternator issues
  210. NEED HELP WITH S2000 ANTENNA??
  211. recommendations for wideband
  212. Funny story
  213. advice for turbo setup
  214. f20c1 for sale
  215. calling all supercharged s2k;s
  216. WTB S2000 Steering wheel
  217. I want to buy Staggered Rims.......
  218. In desprete need of help!, VSA {(ABS)} ! LIGHT ALL ON
  219. Aftermarket CD players
  220. Just bought a new S2K
  221. S2000 diff oil
  222. Anyone know the AP2 S2000 Stock Spring Rates?
  223. s2000 skunk2 turbo cams
  224. my new clutch
  225. wheel specs?????
  226. My Ap1
  227. spoon video on Ap1/2 front upper mounting points (will make you think)
  228. Why are s2000 good?
  229. ITB's Street legal?
  230. K-Pro for 00-05 S2000 Now available
  231. hello, my name is Matt.
  232. Headers on the S2K?
  233. Love thy neighbor, right?
  234. *sniffles*
  235. Engine Stalls
  236. 02 2000 diff. 60,000 miles nice diff
  237. Hit the curb w/ rim while backing up
  238. odometer won't show anymore
  239. S2000 Transmission & Rear dif oils
  240. Quick Hardtop Question
  241. Anyone running Buddyclub N+ dampers on their AP1? opinions?
  242. Anyone running a VAFC on their AP1?
  243. S2k Fuel Gauge Problem
  244. AP1 Question Inside...
  245. Modifry aftermarket headunit adapter question
  246. i want an ap2 s2000
  247. antenna question
  248. How do you reset your oil light??
  249. greddy turbo upgrade..
  250. need help finding some rims
