PDA
View Full Version : Honda S2000
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60
  1. LE-1605 Diff Fluid + 8130 motor oil
  2. **Level 7 intake system dyno tested against oem***
  3. CEL P1457
  4. New 6th Gear
  5. S 2000 Distroyed
  6. Hard tops
  7. New Guy
  8. *ALERT* -My S2000 was just broken into! (Staten Island, NY)
  9. ALL DAY Clothing + Level One Presents: Speed Sessions
  10. 03supers2k Build Thread
  11. ASM Overfender questions
  12. Need a S2000 rolling shell can be stripped!
  13. creaking noise from passenger rear helpppp!!!!!
  14. Schmidts redrilled to fit into S2k?
  15. HELP! Such a nice a\__/s\__/s
  16. s2000 blown rings or valves or valve seals???
  17. 650whp on the dyno but no power on street!
  18. s2000 ITB's =)
  19. What to look for when buying 2003 s2000?
  20. Steering
  21. Bisimoto Tuning Turbo S2000
  22. Coilover Install -- PLEASE help!
  23. S2000 PhotoShoot
  24. 500hp Stock Motor AP2
  25. f22c piston into f20c block?
  26. Problems starting - help!
  27. Which head gasket to use?
  28. Salvage Title: Pro and Cons?
  29. s2000 turbo build what injectors do you recommend?
  30. GRINDING NOISE HELP NEEDED PLEASE?!?!?!
  31. s2000 AP1 or Integra Type R
  32. engine
  33. Dual stage to single stage?
  34. Yet another "Is this a good price for an S2000" thread
  35. EPS Light, No Vtec, Speedometer at zero
  36. Rock chips!!!
  37. Ls2 s2000 6sp
  38. AP1 GT30R RC1000 E85 on single Walbro
  39. 2003 s2000 worth 10k
  40. p1399, p0300-p303 codes???HELP
  41. whats the best wheel paint for bronze color or glossy gunmetal
  42. green key flash
  43. s2k replacement parts
  44. Honda S2000 JDM EDM USDM Rare Parts Thread!!!
  45. Rock Damaged Winshield While Test Driving
  46. need help on rear suspension
  47. Looking to make over 650whp on turbo build
  48. good hard top brands
  49. New clutch
  50. How is the S2K for a DD
  51. Keep AEM or scrap and go Kpro
  52. My Custom Widebody S2k
  53. 6th Gear Randomly Goes?
  54. Tps problem
  55. Engine rebuild
  56. S2000 Newb 606WHP
  57. Sebring on White x 2
  58. is this seller asking for too much?? spa yellow s2000
  59. What Car Would You Choose And Why
  60. S2000 or Miata - can you tell the difference?
  61. In need of electrical help
  62. does taking off the intake box make any difference to the car?
  63. ABS light on after drop??help
  64. valve tick and no pwer
  65. Rough idle
  66. Vibration after drop
  67. Took my AP1 to the track! Video inside
  68. f20c limp mode *vid inside
  69. New S2000 Owner Here! 03 S2K!
  70. need a new clutch 4 s2k what you think?
  71. AP1 Seats
  72. LIKE TO SEE WHAT FRONT LIPS ARE OUT THER
  73. Emange question
  74. OEM S2000 hardtop
  75. D.I.Y. Write-up on replacing the Clutch Master Cylinder on a S2000
  76. any way to fit an adjustable steering wheel?
  77. steering rack information
  78. Where to buy 2nd gear synchro
  79. S2k Injector Plugs.
  80. Honda s2000 Max Negativ Offset
  81. AP1 blows Batt. fuse. Help me please!
  82. S2000 Cover Suggestions
  83. New S2000 Performance Shop opening in Texas!
  84. 4 seperate probes and egt meters for each cylinder for tuning?
  85. Help On Picking A S2000
  86. I've owned my AP1 for nearly a month now...
  87. Tps
  88. AP1 & AP2 bumper question
  89. Can you use the JDM F20c Engine Harness on the USDM S2000?
  90. Tps question
  91. Is $9500 too much for a 2000?
  92. Kings Performance Street S2King goes 9's on Drag Radials
  93. S2000 hardtop
  94. No brake lights? help plz
  95. Purchasing a S2000: What to look for?
  96. AP1 trunk lid vs AP2??
  97. hmmm problem??
  98. Best cam for a turbo s2k
  99. AP1 Tachometer Signal?
  100. Sparco Fighter seat
  101. OEM S2000 car cover
  102. 13000 for a 2005 S2K?
  103. Try's to die when coming to a stop ap1
  104. Pics from this past week, from my boys Xavier an Chris
  105. drivetrain and transmission solutions for 550+whp S2K's
  106. While letting off accelerator to shift car pulls...
  107. greddy e manage
  108. P0420 CEL
  109. Can i put the enkie evo 9 wheels on my s2k?? help plz
  110. will 235/45/17 fit on my s2000
  111. Why shouldn't I?
  112. what bodykit is this
  113. Lowered S question
  114. Injectors for turbo F20C
  115. f20c alternator pinout/ wiring diagram?
  116. S2k Vtec not engaging after engine swap.
  117. 08 S2K, 14k, Mint, Seat Bolster Wear!
  118. s2000 turbo valve help
  119. Ferrea Valves Guide installation
  120. Help located engraved stamping on block
  121. Honda dealer put GM GL-4 gear oil in diff and said its ok
  122. Weird grinding noise.
  123. Synthetic oil question
  124. LOOKING FOR A OEM CD CHANGER CAGE (S2000)
  125. Seat Weight & replacing seatbelts/oem
  126. Help with suspension
  127. Please delete
  128. Name this S2K Engine Part
  129. What do you guys think of this new diffuser, simple and subtle?
  130. Is this s2k worth it?
  131. NEED HELP : My Honda S2000 Isn't turning over and Running. IM STUMPED
  132. Dome light question
  133. My New 05 Red S2K
  134. s2000 comparison !!
  135. 06 s2k getting code p2183!
  136. Just picked up my S2k ;)
  137. Taction Control Comes on by its self...
  138. Proud owner of new s2k :) A few ???
  139. clutch problem??? need help please
  140. can anyone tell me what bumper, sideskirts, and rear add on i have?
  141. Stupid Question of the Day.. What lip is this?
  142. f*d up driveshaft from shipping (what to do?)
  143. diff concern in buy a s2k
  144. Issues after soft top installed
  145. looking for full race intake!!!!!
  146. URGENT! Possible Rod Knock. Video INSIDE!
  147. My Budget S2000 build
  148. Tranny problems
  149. MY03 F20C in MY02 s2k smoke and a tick
  150. Precision Fabrication S2000 turbo build
  151. Towing my S2000 behind my Motorcoach
  152. Trade good or no?
  153. i dont know what kind of exhaust i have
  154. Thinkin of Enkei RPF1s vs Blitz 01s....
  155. subframe shift?
  156. clutch question 01 s2k
  157. COILOVER PURCHASING QUESTION HELP GURUS
  158. Gas Gauge
  159. Trunk problem
  160. Complete n00b question - 06 air intake sensor
  161. WIW
  162. Shock suggestions
  163. does anyone know how to fix convertible top?
  164. Considering purchasing an S2000; input requested
  165. S2000 - Scheduled Main't
  166. The Blackmarker's Project S2K Diary - Featuring The Speed Syndicate
  167. Seat Locks - Extra Cautious
  168. JGs s2000 Build(56k NO!)
  169. Mintex Xtreme Brake Pads
  170. Tranny problems
  171. Charm City Tuning - Jeff's S2000 Street Build
  172. Turbo Cost
  173. picking out a clutch.....
  174. What to do whilst a wasp threatens your cabin?
  175. s2k driver window problem
  176. sold my EK9 and bought an AP1
  177. Need advice?
  178. s2K24
  179. s2000 odometer display not working
  180. Brackets for OEM Rear Spoiler
  181. ap1 vs. ap2 pricing need some advice please!
  182. Took off my cylinder head AP1 - pics inside
  183. Need some opinions for my S2000
  184. jspec vs h motors any insight
  185. NEED HELP (Buddy Club Related)
  186. Car will not engauge VTEC
  187. aem ems cruise control?
  188. jdm engine on us ecu any problems?
  189. HELP...Just bought an AP1 Can use some help
  190. buying "S2000 vs S2000 CR"
  191. OEM Seat Rails for AP1
  192. alignment for non-staggered
  193. Alignment settings
  194. Dash light help?
  195. Replacing Megan Track Series Coilover Components
  196. wheels for sale
  197. new car help
  198. 07 si hfp rims into 03 s2k ap1
  199. s2000 ap1 first gear serge ?
  200. Dyno Test: Brian Crower Stage 2 All Motor Drop In Cams 13-20whp Gain
  201. Headlight Washers ??
  202. Help: Mugen replica hardtop fitment issue
  203. advice on clutch replacement
  204. s2000 valves, springs, etc....
  205. My Turbo S2k is Reborn
  206. Buying an S2000 AP2 2006
  207. jdm headlights
  208. any good shops around chicago?
  209. Just bought an 06' Laguna Blue S2000!! Have some questions..
  210. Value of this car
  211. ap1 wheels with 225/50 all around?
  212. best intake
  213. nardi steering wheel
  214. S2000 interchangeable parts?
  215. Power steering problem, eps light NOT on
  216. Finally Brought It Home
  217. knock sensor?
  218. trade for drag dr-17's?
  219. Main Harness Accessory Wire?
  220. Good deal or not?
  221. what is this hose called that burst? *pics*
  222. whats up guys got 06 s2000 today
  223. Whose Autocrossing?
  224. Clutch chatter
  225. Inherited a 2005 S2000
  226. s2000 wreck in nc
  227. K24 powered S2000????
  228. S2000 or MKIII MR2
  229. bilstein pss9
  230. Looking for an S2000 cylinder head
  231. s2k turbo setup T3 or T4?
  232. AP1 Seibon Carbon Trunk
  233. What would this cost to fix????????????
  234. 1971 S2000
  235. S2K Wheel help
  236. Looking for help
  237. Anyone got some s2k seats forsale localish?
  238. s2000 rims will they fit and what u think? and ksport??
  239. Source for s2000 male engine loom connectors....
  240. 2005 s2000 steering wheel badge?
  241. Turbo S2k owners look : Fuel system question
  242. Honda s2000 whit Skyline r34 rear differential??
  243. Honda s2000 whit Skyline r34 rear differential
  244. just bought a s2k i need help
  245. ap1 and ap2 air box the same?
  246. Drove an AP2 today.
  247. Mugen bits on my S2k engine bay
  248. Im bored, I have wheels on the way, will they fit as low as I am? LoL
  249. crimes against S2000
  250. S2000 Cylinder Head Removal (F20C1 headgasket head gasket)
