View Full Version : Honda S2000
- New Intake Manifold Coming Soon....
- Grassroots Motorsports magazine needs a pre-2006 S2000 for a story
- hard decision of two cars.
- s2000 wheel options?
- Wix Air Filters For S2K!!!
- @ Buttonwillow S2K Challenge
- Turbo kit for drifting
- Post your wheel size and offsets pics!!
- Turbo S2000 drivetrain question
- Brake Lights not working plz help
- boncing idle, wont hold steady rpm
- 05 s2k 1st and 2nd gear problems
- S2000 HID ?
- My New Roadster ( Project S2000 )
- Coilovers ?
- 2008 CR Flywheel weight
- EVAP Removal?
- Blisteins PSS9 reviews?
- Got Featured on FuntionTheory.com
- Blisteins PSS9 Where did you buy and for how much?
- Ground Control's on my AP1 not going low enough?
- Low compression 2001 s2000
- My S2000 started torque steering tonight???? WTF?
- suspension suggestions??
- Deleting ABS for Shave and tuck
- S2000 owner's chime in....Is this a good buy
- Radiator Sensor Resistance values for s2000 to do swap?
- speedometer question????
- new to the s2000 and the forums here .
- Misfire at Idle - Stumped
- Bought a '02 S2000
- xxr's on s2k 17x9 +20.
- To steal, or not to steal
- Wire tuck/ PFab 6262 install
- hello Honda s2000 bolt patern bellhouse
- Recommendation of Softtop Installer in SoCal
- BBS RS 17x10
- 1999-2000 Honda Civic Fogs in AP1?
- My Baby's been totaled! AARGH! advice please
- s2000 shopping
- tilt steering
- Replacing s2k seat belts
- My 03 S2K Build
- S2K Wheel Fitment/Offset Thread
- **S2Kitt Update Page** Hellafunctional
- Low offset/wide rim, and body work questions/recomendation on a body shop in VA
- can i fit a 15" rim on the back of my s2000
- Crazy engine dream i had wanted some input to see if im crazy or nor
- engine rebuild stock or aftermarket?
- Increasing leg room for the taller and bigger guys
- show me a pix of ground wire to engine block?
- mazdaspeed miata
- removing immobilizer from ecu
- Major Transmission problems for '03?
- Want a red "H" steering wheel in my AP2, what are my options?
- RacingBrake vented rear BBK
- aem ems series 2 01v14 to 01v17 firmware?, any new fix and advantage?
- Mugen Plexiglass replacement.
- Turbo temperature
- Honda S2000
- some videos of my starting problem with AEM EMS!
- My 2003 S2K
- s2000 startup video with AEM EMS V2? on 750cc injector or more
- Clean tailights of water
- skunk2 stage 2 N/A cams
- is it normal for the temp to be at 180-185 F at idle?
- Find me a pic of a GPW s2000 w/17" white RPF1's pleasee
- Heater blowing cold air in s2000
- S2000 Backfire in first gear on top end.. opinion?
- anyone have experiences w/ P680 battery daily use?
- Enkei rpf1 questions.
- dyno result for my turbo s2k
- piaa sport mesh
- Gearbox is feeling like crap.
- F20c Dyno Graph AE86 Swap
- WANT THESE WHEELS..HELP?
- low to mid range rpm "struggling"
- Help turn signals not working
- s2000 street/autox spring rates and suspension?
- Do I finally pull the trigger and stick my neck out for the one
- s2k f20c pistons
- Rough start/sometime no start with AEM EMS ECU?
- anyone on here work for Honda and can get me the Radio code?
- I need help :(
- 215/60/16 tires on AP1 wheels (winter tires)
- engine fluid spec for the S2000
- Bride Gias Brackets for stockish height
- buddy club seat rail fix
- Will ap2v1's w/ 245's in the rear rub on a AP1??
- $600.00 for S2000 oil plug replacemement??? please advise, thanks
- S2K All motor advice
- Adjustable cam timing with oem cam gears
- Ap1 and ap2 springs the same?
- S2000 without rear diffuser, picture request
- Rear end making a weird noise, by the wheel
- HID ballast question...
- Is my fuel sender/float stuck?
- Overheating and Heater not working
- custom exhaust build v.9
- headlights delema
- spoon tai bumper with fogs
- J35A3 L66 Satun Vue EVAP Emissions Problem
- Mugen Hardtop (FRP)
- S2000 RHD build
- ?hks exhaust
- hypertech max energy programmer
- My new 03 s2k
- post your hardtop pictures OEm,Mugen Etc.
- ABS light
- Bolisbuilt S2000 hits the dyno again
- Cool things dealing with antenna
- Loose Shifter
- how to take out s2000 head lights/tail lights
- Pic Request: S2K Mugen/Spoon front bumper
- teeny tiny braille battery review
- Pic request: Sebring AP1 w/ white CR-Kai (specific car)
- Chicos S2K - You'll hate it.
- bc coilovers?
- Can shift gears at a stop with out pressing the clutch & car does not move.
- How much is stock ap1 exhaust worth
- Removing spoiler ... Help
- 2000-2003 and 2004-2005 same air intake?
- S2000 differential weight
- do s2k have ignition switches or just button
- Greddy carb sticker.
- d2 stuck on hard
- s2000 offset questions
- No heat in the car.ap1
- Will Civic Injectors work in an S2K?
- Should I roll fenders?
- test pipeand now check engine light on
- Good springs.
- S2000 iPod adapter... will it work on an AP1?
- 08 S2k Purchase, What to look for?
- Your First Mods
- Choosing the right tires.
- ls1 in s2000?
- AP1 Vs. AP2 a friendly competition
- Build Quality of the Honda S2000
- Motor Caravan Insurance
- fuel injectors?
- Search for AEM ECU 30-1012 or 30-1052
- gear oil additives
- Steering Problem while parking !!
- Where is that thread: "how to lower factory seats further."
- god speed project coilovers.
- Factory CR wing dimensions
- anyone bought this lip?
- tranny
- CDV/clutch delay valve
- My car dives left & right when ON/off throttle.
- transmission grinding, rattling, ringing
- Catalytic Converter Replacement - Best Option
- wheel size~help
- F20c into E30 3 series
- FINALLY GOT WHAT I WANTED!!!
- Control arm bushings
- Coilover thread
- Loud noise under car
- Running two inches wider in rear okay?
- drivers seat removal on a 06'
- Ap1 s2000 Wheel Fitment
- s2000 hood with vents?
- I just bought a s2000 but i need some help to get it back on the road
- F20c Standalone Harness?
- Immediate , Knock sensor broke! Different Honda?, Can i use a different Knock sensor
- BRAKE,SRS,MAINT REQD LIGHT HELP
- Coolant Leak *pics*
- S2000's have a lot of problems!
- tranny
- RSX-S seats in a s2000?
- Shutter.lit Photography: Spugen S2000
- New member
- wheel question (offset)
- Attn: Huntsville, Al/Nashville, TN/ Orlando, FL Owners
- Can I drive with a ripped transmission mount?
- installing a new soft top.
- Where is the Engine code stamped on an S2K Block?
- hey guys~ welcome me!! im newbie here!!
- clock keeps resetting to 1:00 and issue with gas meter
- s2000 N/A motor build research
- Soft top on a CR?
- 2003 S2000 Enduro Car Project - Need advice
- NEW RECORD FASTEST S2K IN THE WORLD 7.97@171
- F20c head resurface limit
- Spark plug threads messed up
- What is this and where do I get one?!
- resetting vafc 2
- Please Help, Driver Door Won't Close
- A new S in Wisco.
- My newly purchased (as of today) 03 GPW S2000
- new project
- Red Star Motoring S2King runs 7's !!!
- wheel?
- Question about coilovers.
- Brian crower stage 2 vs stage 3
- HELP! To buy or not to buy Link inside....
- Help Needed: Daily Drivable Turbo S2K
- Finally bought one....2007 BB s2k
- WTB: HUGE LIST Of parts needed to finish my car!
- WTB VAFC 2!!!!
- meeting spots in seattle??
- Preventive Maintenance Checks and Services
- kind of S2K topic but about 2000 accord question
- s2000 n00b, Keyless entry question...
- Need info on a front lip....
- What are the colors on the crank
- Lowering Stock Seat Height
- Thinking about buying this s2000...link inside
- Question: Best magazine?
- nutral too loose.
- Kings Performance S2King NEW DYNO Numbers!
- Need help low compression
- ap1 dash harness part #
- favourite snow tires for the s
- 1986 Corolla SR5 S2k Build....
- Looking to purchase an S2000
- what yr ecu + cluster doo i have >??
- engine check light?
- Show Off ur Wheels and Tires!!!!!
- picked an ap1
- Is this S2000 worth purchasing?
- Strange Noise - HELP
- Sebring s2k with cr parts
- Production numbers and color breakdown
- Price of S2000 considering it's a convertible after summer?
- what bumper and fenders are these?
- Need some help deciding
- Any guys running a GPW s2k w/white ap1 rims?
- AP1, strange "Squeeking noise while decelerating"
- CD issue
- Hood Latch
- WTB: s2000 block
- FS: Enkei RPF1s Staggared 17"
- how to clean cr seats?
- Help S2000 CV joint allways get broken!
- Third Brake Light Not Working - State Inspection
- Swift or Eibach Pro-kit
- BBS LM 17" for my s2k
- my s2k
- I think I fixed the idle/clutch-in stumble!
- looking to purchase s2k in near future
- s2000 with a miss
- Strange sound
- Injector Dynamics 725cc or 1000cc Injectors
- vgs steering wheel
- Knock knock, who's there?
- cant decide whether to get an S2K or keep current car, help
- Want the "flush" look, are my wheels too big?
