View Full Version : Honda S2000
- Patching up a soft top?
- hey sorry i need the pin layout for the stock deck
- new car debat ... s2k as a DD?
- Tire/Alignment questions
- s2k bolt on power ...
- Lowering Springs on an S2k?
- salvage Honda S2000
- "Spoon" style air intake duct install
- Pros/cons of the S2000.
- I R Dumb Quick Question
- looking for a DYI to pull out a s2000 motor
- advancespeedshop.com
- F20C swap prob
- viper alarm with goods
- s2k automatic top?
- f20c build help, needed!
- S2000 longblocks
- Quick S2K Inquiry.
- turbo probs
- Sceetch when turning left.
- Any of you have a custom exhaust?
- mag blue or orange??? or.....takata?
- Projected Price
- rebuilding a f20c
- oil change then check engine light on
- Ground connections?
- Best Boost Gauge to Match AP2 Cluster??
- Parking Lights no worky
- best exhaust ???
- HELP on estimating the cost of an s2k engine.
- Need all the help I can get!(please read)
- Teins - here we go..
- getting a s2k, ap1 or ap2?
- Weather Seal Coming Loose
- New to S2000 and would like help please?
- Had a 05 S2K, but maybe getting a AP1 S2K now ssooo....
- AE86 F20C build
- Picking up an S2000...What do/did you all pay?
- Check out the September issue of DSPORT Magazines W/ the Honda S2000 Challenge.
- front bumper/license plate hole plugs
- s2000 Cold Start Issues
- Does the "roof" switch light up?
- where is the turn signal relay located?
- My cousin is selling his S2k and I'm intrested.
- DIY: S2000 CR Shift boot install
- s2000 ultimate interior
- ap1 engine 90k miles w/ tranny
- BRAND NEW Greddy AP2 04-05 TUrbo Kit For Sale
- Just curious...who else has this happened to? (Wheel Bearing Issues)
- Vibration at high speed
- just got back from honda school
- Help Needed; Dash & Engine Power Loss
- VSA and Engine check light stays on after engine bay detail
- AP1 with EK fogs
- Custom AP1 headlights with LED's....do you like?
- can we use a hks bov on the comptech supercharger?
- Tell me what you think
- Why would I have hesitation when vtec kicks in
- Cody Red's Rio S (56k go away)
- knocking?
- tap for turbo oil feed
- What is the offset for the cr kais?
- rsx rims on a s2000
- putting on license plate on 2007 s2000
- is a 6 point roll cage illegal in california?
- Auto tranny swap is done after 2 years!
- throttle body
- Change Black Leather Interior to Beige? How?
- help >> spark plug anti foulers in the UK
- OEM hardtop pricing
- remove a broken tap
- New soft top today!!
- RedStarMotoring DD S2000 10.4 @ 138mph VIDEO!
- Was looking at a S2000 today
- 02 black s2000 questions
- 02 Temp Question
- In market to buy a s2k, im 6'2" tall, will I fit?
- Thinking about getting a s2k
- anyone use comptech replacement filter?
- Does anyone kno where i can find this spoiler?, for an s2k. pic included.
- Honda S2000 2000-2004 AP1 Lubrication System: oil filter, engine oil and more
- Honda S2000 2000-2004 AP1 Ignition System: timing, spark plug inspection and more
- Honda S2000 F20C Rocker Arms: test procedures and shaft inspection
- Honda S2000 F20C Seats (OEM): removal, installation and etc
- Honda S2000 F20C Wheel Alignment: caster, toe-in, camber adjustments and more
- Honda S2000 2000-2004 AP1 Wheel Bearing Removal and Installation
- Honda S2000 2000-2004 AP1: Hub and Knuckle Assembly removal and installation
- Honda S2000 2000-2004 AP1 Flywheel Removal and Installation
- Honda S2000 2000-2004 AP1 Dashboard Removal and Installation
- Honda S2000 F20C Cylinder Head Removal and Installation
- Honda S2000 Crankshaft F20C: main bearing selection, clearance inspection and etc
- Honda S2000 F20C Camshafts
- Honda S2000 Cam Gear Removal and Installation
- Reccomadations on 17" wheel/tires sizes?
- Honda S2000 Cooling System: Radiator test, thermostat replacements and more
- Honda S2000 Interior Consoles: side vent, console box and etc
- 18x9.5 +20 on a AP1 I searched
- Honda S2000 F20C Cam Chain Removal and Installation
- Will HP Design HPR5 rims fit the S2000?
- Honda S2000 Brake System: inspection, troubleshooting, removal, installation and more
- part help thanks
- MPH / KMH Selector
- looking for pics of 5zigen fno1r 17x8 +43 17x9 +43
- slave cylinder problem
- s2000 engine problems
- removed my s2000 badges and ran into a problem
- Capabilities of the S2000 Trans./R.E.
- S2000 coil-on-plug ground question
- My PowerHouse Amuse Build
- Would s2000 make a good daily?
- Trans/Differential
- Whats Part # For 03 s2k vtec solenoid gasket
- AP1 purchase
- My Greddy Turbo Kit AP2 dyno results
- I'm buying a s2000 soon!
- Decision on new AP1 purchase
- Need help from S2k guys
- 2006-2009 Honda S2000 AEM Intake
- yellow 02 AP1
- S2000 Ultimate Edition
- Auto-x footage with GoPro Motorsport Hero Wide
- Im new with these cars help!!!!!
- help with exhaust
- Soft top come with rear window?
- Can I add a defogger to rear window?
- Daily Driven 704whp Honda S2000 Jordan Tuned
- replacing the top
- Where can I buy a Vtec Solenoid Gasket
- noob question: identify this lip and fog lights
- track day pics
- AP1 Cruise Control OEM Block Off?
- AP2 v1 & v2 stock wheel pics needed
- S2000 CR Wing on 2004 S2000
- Radio trouble, help please.
- Asking too much for my car? What's reasonable?
- pic request C-West Front lip
- Thinking about buying an S2k or EVO...
- Air bags and turn signals/hazards/putting the top down
- clunk/pop noise from rear when pulling out
- Guys I found this weird contraption in the dumpster?
- hydrolocked s2k
- CCW has a new center
- Raw's 2 S2000 Turbo builds
- Done and Done
- S2k ECU plugs/OBD Question
- Suspension Advisement?
- Water in the trunk
- S2000 INJECTORS. SIZE?
- Painting the hardtop (fiberglass)
- s2000 on skunk2 springs
- Max Sleeve Bore
- turboing and s2k
- 2.4L stroker kit or 2.2L stroker kit
- Back fire but no missfire cel
- Small photo shoot with some friends.
- Some Recent pics...
- New hood - Thoughts?
- NA builds
- Need Help
- steering wheel emblem
- Thinking of trading my s2000. Replacement?
- Where can i purchase these side mirrors? ITG?
- Another one gets taken !!!
- Thinking about joining the S2K game..
- reving slow after 7K...
- 6-point harness install
- Help Vibration and grinding
- Real. True. Tuning.
- Worth it????
- 15 psi billet 71 lovefab gt1
- how to retention a timing chain tensioner ???
- anyone have a deployed 05 airbag?
- Humble Performance S2K
- n00b wants to BUILD :] opinions please and ty
- Qs on buying a S2K for dual duty...
- Grinding question
- I broke my Spoon Diffuser.
- "Squealing" sound when clutch is not pushed in
- My S2000 build thread
- RedStarMotoring S2k upgrades PICS!!!
- mugen NR wheels
- LS2 S2K spray
- Damaged Rubber Repair/Replacement?
- Wheel Identification: This Could be you!
- Help me understand wide body...
- Turbo S2000 or 02-04 z06?
- s2000 with supra motor
- Quick question about cargo space.
- Really wierd oil leak...
- CEL back
- 06+ exhaust on 01
- Easy way to remove S2000 emblems?
- Help, I think my front end is going.
- SoCal..buying from small dealership
- lowets offset possible for front s2k brake setup?
- How do you turn the maintenance required light on my 2001 s2000??
- VTEC Solenoid Gasket OEM part number
- black OEm seats for sell $550 firm
- Brand new CF Mugen replica hood and oem carbon fiber trunk $450
- Got money to spend want to go NA? any ideas
- aftermarket radio
- Need help with driver window
- Mugen NRs on an S2k? (searched)
- s2000 after market tail lights
- Pic request: Yellow s2000 w/white or gold TE37 rims ?
- Just lowered my car and rear vibration started!
- OEM Spoiler
- 17x8 17x9 +33 ?
- S2K wheels with lip
- Autometer pillar pod for AP2?
- Is it safe to Run Axle Spacers?
- 509whp / 357wtq @ 15psi
- JDM F20c vs. US F20c compatability??
- Honda Bond on Valve Cover Gasket?
- stock part question
- Anyone here went from a S2k to mustang gt or vice versa?
- thoughts about this s2k?
- I'm a newb to the S2k with questions.
- Calling all you alcoholics... needs E85 help!
- What's the best way to spend $3,000 on an AP2?
- Diff Fluid change..
- questions before my purchase
- Question on pricing of local s2k.....
- omni quicklutch master cylinder
- S2K drop.
- Complete the exhaust
- SOS 3bar Map
- Draining Fuel Tank?
- How do I post in GDD?
- s2000 f20c model
- Help - Greddy Turbo Timer in AP1
- First Startup for AEM Ems advice?
- weird clutch pedal feel
- how much is a s2000 engine (spun bearing) worth?
- f22 bottom f20 top
- Rim size
- S2k seats
- Buying new axles
- s2000 headers
- S2000 OEM car cover
- Question on Honda S2000 Clutch.....
- Turbo S2000 Ign. Problems. AEM EMS, etc.
- Paint or change rag top?
- coolant everywhere?
- S2Ki - Power of dreams - Northwest
- S2000 Oil leak??
- Mugen 6 point roll cage!!! Help!!!
- Defroster install + hardtop in 00?
- Soft Top Patch
- Sick and Sad racist destroy a clean S2k
