View Full Version : Honda S2000
- ***bad A$$ f20 2.4L stroker kit tech info read read***
- Password:JDM quality control
- S2000's with Rollcage Pics Please!!
- Longer 5th and 6th..........
- trade my s2 for hatch?
- S2000 hunt begins...again...in South Florida
- Ivtec F2xC now a reality
- 6th gear blocked.
- CCW's are on the way...
- S2000 swapp F20 to F22
- Suggestion
- s2000 factory radio wiring diagram
- Is this dumb? S2000 related
- Searched, no luck.
- rims volks sf winnings
- Is anyone running nrg hood dampers?
- soft or hard top
- EPS Codes
- Pic Request. Gold Wheels.
- Speedtech Competition or Neuspeed sway bar?
- What air intake systems you guys running?
- f20/f22 head and valve info
- Ugggh.. S2K or Si.. that is the question
- Looking at an S2K with a replaced motor.
- F20C S2K AE86 Corolla Build Started!!!! Updated 11/20/09
- OEM TSX ballast?
- Radio dash controls
- Has anyone gotten the TSB for 2nd gear popping out done?
- Tonneau Cover price OMG
- Battery Relocation, Fuse size?
- Dumbest question of the year..right here!
- wheels in a pinch
- Clunking sound when putting car into gear
- Help with keyless entry.
- nsx wheels
- Is the f20c and the f22c heads the same?
- New 2001 S2000 owner
- Front bumper license plate bracket holes
- My s2k is cutting of 7000 rpm
- Worth Trading for s2k??
- Question about S2k oem radio
- question about intake
- Walbro 255lph voltage mod
- Map sensor problems, replaced now worse
- cluster mileage question
- DIY rear axle CV cup swap
- J's racing flares and 17x10 +18 offset
- Hard Top ?
- S2000's value increase or decrease?
- Integra seat rail mounting point same as s2000?
- Winter driving?
- S2000: Gone
- stroking a f22?!?!?need advice
- Need some advice..
- help! How many quarts diff fluid for AP1? plz confirm..ive searched.
- Uneven Suspension?
- IPod with Factory Stereo
- Wheel questions?
- ***AFI Turbo TA/Modified S2000 Updated For 2011***
- 17x9 +35 all around?
- No spark! help!!
- 5w-40 synthetic ok to run?
- Chassis swap info
- Another Tire Size and Rim Size Question
- s2000 e cut out
- Best Aftermarket seats for Americans
- need some specs!!!!
- Soft top wax remover?
- Booming dound - tyre noise ?
- PICTURE REQUEST PLEASE
- will these bad ass wheels fit? s2000 dropped on espelir springs.
- AP1 vs AP2 dyno results
- ot of curiosity
- suede seats???????
- 3rd to 4th Synchro
- Your S2 and your Pets
- looking to buy my first s2k, what do you think?
- obx header on s2000
- 02 Idle Question
- Not your typical AP1 vs AP2 question
- Shift Knobs: NSX-R vs VooDoo Ti
- wheel bearing replacement question
- Introduction! New shop, needs test cars!
- Any of you guys ever purchased a hardtop from Ace_Drew1?
- 2004 Supercharged S2000 No VTEC, EPS malfunction, VSS not showing in AEM 30-6052
- price on pcx filters? boch honda lol....
- s2000 dash help
- S2000 mileage.
- Hondata flashpro on 00-05 s2000
- hard top question
- best year for the s2000
- F20/F20C/F20C1 ?!!? Engine Help
- Need help with 05 turbo S2000
- Finally got to work on my valve cover
- AP1 or AP2
- AP2 ballast question
- First: Hardtop or Wheels+suspension???
- Woooops . . if you could delete this that would be Fab
- Check out this s2k, let me know if its a deal or not
- weekend project finally finished... polished hood, lol.
- 2000 s2k....need advice.
- Rear Tire gets worn fast
- Good parts site for s2k???
- s2000 cluster wiring peeps
- Anyone Have Luck with Studded Tires?
- s2000 Headlight question
- Blind Spot and Hard Tops
- ap1 s2k Sound from rear.
- S2000 running rich....solutions?
- Abot to buy a S2000 with 169K miles... what should I look for?
- How do you check a CEL on an s2000?
- Does anyone no if s2000 has cam bearings
- New Flywheel with First Clutch Job?
- Any S2K owners play hockey?
- s2000 ap2 seats fit an ap1
- Brake cylinder master
- Second synchro WANTED
- Does anyone know...??
- Stolen Center Caps....Help
- Regamaster Lip Decals
- New Suspension Poping?!?!?
- type of rims
- New owner, few questions here
- s2000 guys.....
- S2K 2JZ Swap *INFO NEEDED*
- ▄█ What's corn fed, bright red and runs 12.0's ?... █▄
- White smoke question
- Looking to purchase a GPW S2000 and have some questions.
- replacing Softop, what is grey foam on rubber trim?
- Highest milage s2000
- ordered from here...
- Spray with what tuning?
- How do you like freeway/interstate cruising in your s2000?
- a little tip when doing tranny swap
- Clutch master cylinder question
- help! 40 or 45 series rear tires??
- coolant temp sensor thread?
- Anyone know where APR gets those mounts for their carbon mirrors?
- car won't start after 3mm HG, turbo, AEM
- Turboing after 155,000+ miles
- HUge Problem....please help
- Injectors....
- aftermarket head unit
- Availibility of Hardtops? Oem &/or Aftermarket
- S2000 Vs. porsche boxter opinions
- BuddyClub Or Apexi Coilovers
- nasty clicking sound from rear. Not the axel nut! help
- ap1 vs ap2 suspension!
- Just got an s2k... all i have to say is....
- Quick question about suspension
- registering a s2000
- S2000 Complete Build! 550whp!
- f20 ae86 project in progress
- Misfire with no CEL
- S2000 Sebing/Red int. exclusive to 2002?
- White Smoke from Exhaust on Idle
- Aftermarket Seats
- Ap1 air pump will fit on a ap2 ?
- Roof security question
- hey guys, dumb question but i gotta know.
- Need HELP quick!!! (Buying an S2K in a day!!)
- too early to dyno?
- New MG Style urethane front lip for the ap2! Finally!
- I want to buy an S2K, I need advice.
- Cel for no intake?
- How much should I advertise my car GPW S2000 for?
- Black or Dark Blue OE replacement softtop?
- 04-05 factory intake on a 02?
- Steed Speed Turbo Manifolds !!!
- vtec system test
- AP2 fishy price tag...
- Replacing longblock.Which new parts needed?
- So I just put on my new soft top and...
- place to buy a s2000 shell?
- DIY hood vents
- DIY custom AP1 head light diffusers
- quick question car making strange sound
- Tall owners of The s2k please come in.
- BuddyClub QF's
- need help with changing stering wheel to get cruise control
- Stupid Question, help fill the void about bird poop
- Did you buy your S2K new or used?
- spoon caliper fitment
- o2 sensor question
- Help with diagnosing weird idle drop
- is it worth it?
- San Diego - 2000 Silverstone 38k only!
- TOYOTA TE27 with HONDA F20C Engine...
- Private Label Header Test + Dyno... Accepting Donations for Dyno Time...
- Cumberland Md Oct 2-4 S2000 Meet
- Clutch Question (Slave Cylinder)
- Map sensor
- Valve Seals????
- O2 sensor problems
- installing a rear glass
- What are you guys paying on inusrance?
- S2K high rev a bad thing?
- Can I fit this RPF1's on my S2000 without modifications...
- S2K c30a engine swap
- SRS AND ABS LIGHT
- Quick Question..
- 05 S2000 8k miles
- Buying my 1st S2k
- Can we use 2006 comptech supercharger on 08?
- K20 RBC intake manifold on F22C?
- S2000 down
- hondata reflash
- Oil Filter Relocation Kit?
- Ebrake light blinks...!???
- help with wheel fitment
- ****mono block spoon caliper stock wheel clearance****
- S2000 tune problem
- Peakboost HVS topmount S2000 kit!
- Intake,Headers,Exhaust
- Honda s2000, 2001 loose of power when vtec engages
- How to install front lip
- Just got an s2000
- J's vs. Mugen header on F22 (yes I searched)
- About to get a new s2k
- Slipstream Front Lip
- QUICK QUICK HELP! Skunk2 springs plus rims???
- ap1 headrest speakers?
- F20C Head Removal - In car ??
- Loading up on fuel then stumbling
- oem car cover -- good for outdoors?
- Shopping around
- Top sliced, now what to get
- Valentine V1
- roll bar questions
- Looking for Manual
- Soon to be S2K owner...
- ap2 diffuser install????
- S2000 ?'s on interior and price
- S2000 Synchronizers
- Help a fella decide what year S2000 he wants!
- fuel pressure gauge
- Buying a S2K tomorrow, Need Help, Clutch Warranty
- Dealer won't allow test drives?
- cusco 6pt cage q's
- Wrecked S2k help
- Air pump assy bypass ?
- J's Racing Track Wheel Setups?
- 2jz mounts
- need help with headlights
- S2000 Exhaust advice
- s2k audio controls
- AP1 Speaker?
- Fresh New Look For The S
- S2k stock suspension
- Factory Alignment & Drop Alighment
