Honda S2000 Honda S2000
maintenance required
Old Dec 4, 2012 | 04:52 PM
92cxhatch169's Avatar
Default maintenance required
my maintenance required light flashes at cold start up, and then goes away. any idea's?
Old Dec 4, 2012 | 07:00 PM
MiMiK's Avatar
Default Re: maintenance required
"maintenance" is due soon. do you reset it when you do your oil changes? if not and you want to go away, hold the trip button while you turn on the ignition(don't start the engine). hold it until it shuts off.
Old Dec 4, 2012 | 07:47 PM
it wasnt on when i changed the oil last. thanks for the info
Old Dec 4, 2012 | 09:58 PM
dagle's Avatar
What mileage are you at? Might help us spot if you're due for anything big. But chances are it's just for the oil change and needs to be reset
Old Dec 5, 2012 | 05:23 PM
almost 97k
Old Feb 13, 2013 | 06:48 PM
1_Clean.GSR's Avatar
The 100k mile maintenance should be coming up. I believe is a transmission fluid replacement, brake fluid flush, air filter, spark plugs and Alignment with tire rotation as well. I might be missing a few things but that's what I know as of now...
Old Feb 13, 2013 | 07:03 PM
Boots's Avatar
first, you bumped an old *** thread
second, you dont rotate staggered tires
nukem384
Mar 16, 2010 07:20 AM
black0hatch
Honda Civic (2006 - 2015)
16
May 18, 2008 08:44 PM
KrazyDawg
Mar 18, 2008 04:39 PM
hometheaterman
Jan 30, 2008 03:44 PM
sony224422
Feb 20, 2006 03:54 PM
