Corner balancing
Old Feb 5, 2013 | 07:31 AM
zdiddy22's Avatar
Default Corner balancing
I have searched and called many places, but cant seem to find anyone who does corner balancing in Jacksonville, FL. Does anyone know of a place? I am trying to get the car ready for IFO. Thanks.
Old Feb 5, 2013 | 07:40 AM
PhilStubbs's Avatar
Default Re: Corner balancing
Mase maybe? Only person I can think of that might. There is a very simple and accurate way to use bathroom scales but being this is H-T the idea would just get bashed. I'll keep it to myself.
Edit: just had a thought. There is a small chance Brumos might do it. With their racing I'm sure they have a set of scales. Maybe they could work something through their service dept to do it
Old Feb 5, 2013 | 07:45 AM
zdiddy22's Avatar
I called mase, stage 6, hurricane, noone does it lol. I will try brumos.
Old Feb 5, 2013 | 07:57 AM
Bouckaroo's Avatar
http://www.scaleline.com/one_weigh_racecar_scale.htm
Call these people, they sell different sets of scales for this very thing, Im currently shopping around for a set now.
Old Feb 5, 2013 | 09:47 AM
Disco's Avatar
Dude id like to hear about the bathroom scale method. I know my car is way off and needs to be balanced out.
Old Feb 5, 2013 | 09:55 AM
redboost10's Avatar
Bathroom scales are just as accurate as the digital scales.
Old Feb 5, 2013 | 09:57 AM
xenocron's Avatar
How many bathroom scales that you can buy from bed bath are capable of 600-700lbs per corner?
Old Feb 5, 2013 | 10:01 AM
redboost10's Avatar
You don't put the car directly on the scale. FYI, philstubbs above also mentioned using bathroom scales, we always used this method until we bought the long acre scales
Old Feb 5, 2013 | 10:05 AM
xenocron's Avatar
Then enlighten me please, how do you weigh something without actually putting it on the scale?
Old Feb 5, 2013 | 10:28 AM
surfingsk8r's Avatar
IIRC you use some type of reverse leverage that lessens the load actually placed on the scale that is in a measurable percentage of the actual weight of the wheel. Ill see if I can find a picture of what I mean.
Old Feb 5, 2013 | 10:29 AM
Found this using google. I am curious as to if the other people in the thread have a different way of doing tho though that doesnt involve constructing anything like that.
Old Feb 5, 2013 | 10:31 AM
PhilStubbs's Avatar
My method is a little classier and repeatable than this, but the basic idea is the same. A little math and its pretty accurate. Just buy 4 of the same scales so they are consistent.
Old Feb 5, 2013 | 10:33 AM
redboost10's Avatar
Fabricate a fulcrum with a "see-saw" type platform for the tires to sit on that is x length away from the point sitting on the scale so that you can use a ratio to get the exact weight of the corners. Cheap and effective.
Ill try to dig mine out and take a picture.
Old Feb 5, 2013 | 01:43 PM
zdiddy22's Avatar
So back to the question. Does anybody know of a place in Jacksonville, fl that does corner balancing? Thanks.
Old Feb 5, 2013 | 02:32 PM
heavy duty's Avatar
How close is tdautoworks. U can try them. They are good guys. Don't know what town they are in tho.
Old Feb 5, 2013 | 02:44 PM
PhilStubbs's Avatar
Brumos didn't work out?
Old Feb 5, 2013 | 02:45 PM
2xraeted's Avatar
You can try IPG in Sanford, Florida
Old Feb 5, 2013 | 03:41 PM
paulzy's Avatar
Have you tried anywhere outside of the sport compact racing market yet? domestic drag shops, road racing shops, and so forth? SOmething like a porsche road racing specialty shop
Old Feb 5, 2013 | 06:48 PM
AllShowNoGo727's Avatar
x2 on IPG
Old Feb 6, 2013 | 03:19 AM
gettin it's Avatar
There use to be a place around here awhile back, ill ask Cez and see if he remembers.
Old Feb 6, 2013 | 05:01 AM
slowboy90's Avatar
a typical google search led me to
riggins engineering
Address: 275 Hammond Blvd, Jacksonville, FL 32254
Phone904) 786-7261
customers say average of 150 dollars to do it
Old Feb 6, 2013 | 08:18 AM
zdiddy22's Avatar
riggins engineering
Phone904) 786-7261
Thanks and I did a typical google search. I will give them a call and see whatsup. Brumos didnt work out. Thanks though.
Old Jul 20, 2014 | 12:29 PM
b00st4life's Avatar
which long acre model did you get?
Old Jul 20, 2014 | 03:22 PM
Tippyman's Avatar
FWIW they do make fairly inexpensive 700 lb scales.
https://honda-tech.com/forums/showth...552&styleid=18
They wont do much good in a drag application for a car much over 2000 though.
Old Jul 20, 2014 | 05:08 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Not to rehash the bathroom scale idea but we have done 4 scales per corner and just added the weights together. Used 2x4s as cribbing and cheap *** scales that were about $10 each. Worked in a pinch when the Proform scales took a **** and tech was being an *** and was not going to accept 0.1% over on the left side for anyone (circle track racing).
98ITRAgain
Aug 16, 2013 11:23 AM
VtecFreePrelude
Welding / Fabrication
Oct 3, 2009 01:39 PM
nEoMuGen
Honda Motorcycles
13
Jun 22, 2005 08:08 PM
Knestis
Jun 12, 2004 10:04 AM
