Spark plugs
Old Feb 3, 2013 | 12:28 PM
DraginX's Avatar
Default Spark plugs
First I've been reading up on plugs all day long and haven't gotten an actual answer to my question so I will ask.
Why are the resistor plugs considered to be a better plug over the regular plugs like the BKRE9?
Is one style better for different setups, ex. coil on plug setups works better with x plug where stock distrubitor/wire ignition setup works better with y plug, or is one style plug better for above/below certain hp?
Discuss
Old Feb 3, 2013 | 01:38 PM
MR.johnson's Avatar
Default Re: Spark plugs
first. what coils are you looking to use.
Old Feb 3, 2013 | 02:20 PM
DraginX's Avatar
I'm using K-series coils.
But for knowledge sake would like to know why certain plugs should be used for certain applications or power ratings. I know alot of it is going to be peoples opinion but I'd like to get into the technical side of things if people are willing to share their knowledge.
I know of Tony T1's website he recoments Denso IK27 resistor style plugs for applications 400+hp over stock. Why these over say the regular BKRE 9's? Does this come down to personal preference? Usually if Tony recommends something there is a technical reason for it.
Old Feb 3, 2013 | 02:24 PM
DraginX's Avatar
Found my answer, guess I have been too focused on this and was looking in the wrong places, should have went directly to the faq's on ngk's site. Here's what it reads for anyone interested.
Q: When should I use a resistor spark plug?
A: NGK "R" or resistor spark plugs use a 5k ohm ceramic resistor in the spark plug to suppress ignition noise generated during sparking.
NGK strongly recommends using resistor spark plugs in any vehicle that uses on-board computer systems to monitor or control engine performance. This is because resistor spark plugs reduce electromagnetic interference with on-board electronics.
They are also recommended on any vehicle that has other on-board electronic systems such as engine-management computers, two-way radios, GPS systems, depth finders or whenever recommended by the manufacturer.
In fact, using a non-resistor plug in certain applications can actually cause the engine to suffer undesirable side effects such as an erratic idle, high-rpm misfire, engine run-on, power drop off at certain rpm levels and abnormal combustion.
zakiu
Honda S2000
17
Apr 23, 2007 09:04 AM
Calean007
May 9, 2005 07:04 PM
Jcup315
Apr 18, 2005 06:08 PM
HPilot
Feb 28, 2002 04:46 AM
