Fuel Cell Question - Minimum Volume?
Old Nov 21, 2012 | 07:12 PM
SovXietday's Avatar
Default Fuel Cell Question - Minimum Volume?
Started building a fuel cell for my car. According to my math, I will be a little over 2 gallons of capacity, not including the sump (that number is conservative). Magnafuel 4303 pump. I know that you can't run a fuel cell near empty because the pump will cavitate, so I want to make sure that 2+ gallons will be enough to make a few passes before needing to be topped off.
Fuel of choice will be E98, or maybe FTW if my pockets find a way to get deeper. Trying to keep weight in the back down as much as possible.
Old Nov 21, 2012 | 07:49 PM
tepid1's Avatar
Default Re: Fuel Cell Question - Minimum Volume?
Most require 5gal or so. I don't believe IFO regulates that. Read the SFWD rules from this years shootout.
Old Nov 21, 2012 | 10:10 PM
SovXietday's Avatar
Heh, this car will never pass SFWD rules, nor would I ever be competitive. I'm just building the car to have fun. More curious to know if I will run into fuel draw issues than anything else.
Old Nov 21, 2012 | 11:19 PM
tepid1's Avatar
Nah. You'll be fine. I'd recommend, that whatever you do, you have the fuel pump feed port low and facing the rear of the car so that during accel you don't lose pressure/flow.
Old Nov 21, 2012 | 11:22 PM
artie89's Avatar
Old Nov 22, 2012 | 03:34 AM
gogetta's Avatar
Also be careful where the fuel cell is located. If located outside the framerails a 1.5" "dont quote me om the size of the bar" halo must surround it to protect it in a crash
Old Nov 22, 2012 | 05:18 AM
dturbocivic's Avatar
its inch and a quarter .065 i do believe
95ITRJDM
Apr 10, 2011 06:09 AM
BLU CIVIC
Oct 29, 2008 07:47 PM
jwcardy
Apr 4, 2004 02:53 PM
Red D Dragon
Apr 3, 2004 06:53 PM
Toad
Jan 3, 2003 10:10 AM
