Feb FS Thread
Old Feb 4, 2013 | 07:31 PM
crazes's Avatar
Moderator
Default Feb FS Thread
Please read the rules for the new thread. At the end of each month this thread will be unstickied, and a new thread created in this one's place. If you haven't sold your parts, you may post them in the new month's thread. DO NOT BUMP THE OLD THREAD
1) This is for RaceCar parts ONLY. No body panels, fenders etc allowed, unless it is a full race front end. ABSOLUTELY NO useless OEM parts!
2) Do NOT repost your thread over and over hoping to get it on a new page. If your parts sell please remove them from your post. If you sell everything off of your list of parts, report your post to moderator by clicking on the just under your user name and we will delete it.
3)You are ONLY allowed ONE post in this thread. If you are found to have more than 1 post, in the FS sticky all of your posts in the sticky will be deleted, and you will be given an infraction. With enough infractions you will be banned
4) NO WTB ADS!
5) NO COMMERCIAL POSTS AT ALL THIS MEANS, IF YOU OWN A SHOP DO NOT POST BRAND NEW PARTS IN HERE
6) Please provide all pertinent information, including price, and try to return pm's.
We will delete any BS we feel does not belong in here
Please try and limit the size and # of pictures you post. using thumbnails would be fantastic.
From this point on, 3-7-2012, any edit mods have to make to these threads, will result in sanctions. if it persists, the stickies will disappear for good. THIS WILL BE ADHERED TO. No more warnings
EVERYTHING HAS TO HAVE PICS NO exceptions
Old Feb 4, 2013 | 07:38 PM
phantom_bcw84's Avatar
Default Re: Feb FS Thread
I bought this turbo to put on my integra and have decided to leave it with the turbo the integra has and decided to sell this one.
its a Precision 6765 ball bearing billet wheel turbo t3 .82 ar v band rear with 1 (one) hour of dyno time on an integra that made 600 hp then was taken off and sold to me. NO SHAFT PLAY OR END PLAY AT ALL perfect almost brand new turbo
part number PTB505-6765
505-814-4574 text is preferred but will answer calls
price $1,350 OBO plus shipping or paypal fees MIGHT TRADE FOR A 6262 BALL BEARING BILLET
Old Feb 4, 2013 | 08:07 PM
Kevin's Avatar
ID1000 injectors with clips SOLD
Hybrid Racing swap header $325 shipped. This is the same header as seen here http://www.hybrid-racing.com/store/h...ap-header.html albeit in used condition. Since this was in a k24 1990 Integra, i had to cut off one of the bolts that holds the collector on because it hit the subframe. I ran it for quite a while like this with no issues.
glokology@gmail.com
Old Feb 4, 2013 | 08:32 PM
SPOON_BeIgHtEeNsEe's Avatar
Default BNIB SKUNK 2 H22 valve train and intake manifold/TB
both were purchased brand new
i have a barely used skunk2 H22 intake manifold asking 325 + ship OBO
also have a barely used BDL 72mm TB. asking 300 + ship OBO
or buy both for 600 shipped.
Old Feb 4, 2013 | 09:33 PM
Tyler H's Avatar
H22 Turbo Manifold - $700
Built by Innovative Turbo Sysytems back in 2003. Was fully polished, bead blasted now. T4 single scroll and two bolt 38mm wg flange. Thick wall stainless steel TIG welded construction. Very durable, been used on a street car for years. I'll include an adapter to run a 44mm v-band wg. Including downpipe too.
99-00 Carbon Fiber Hood with Custom Scoop for Full Race K24 manifold - $200
Tilton H22 Cerametallic Twin Disk Clutch - $1000
Less than 10 passes. Excellent condition. Had my machinist clean up the flywheel bolt mounting surface, it got a bit worn.
H22 CNC Ported Cylinder Head. Ported by R&D Dyno Service. - $600
Includes cam caps, rocker assemblies, shafts, LMAs, dual springs and Ti retainers. Intake #3 has full valve guides, all other ports are cut back to the port wall. I'd recommend getting new springs and retainers.
Aeromotive ELIMINATOR 11104 Fuel Pump - $250
Slightly bent mounting ear.
Old Feb 4, 2013 | 10:03 PM
extralargenog's Avatar
Default H22 Stuff fo sale
Bunch of H22 stuff lying around. All in good shape. Buyer pays ship.
H22 Competition Clutch twin disk setup. with everything
(FW/Disks/Floater/Hardware) including the proprietary T/O bearing. Just
freshened up with new disks with he upgraded hubs 1500 miles ago. ALso new
pilot bushing. Assembly has been balanced, step cleaned up and its good to
go. No issues. 10 dyno passes and 1500ish street miles. Holding 750 WHP
without breaking a sweat...
Disks measure out at .245 and .246. New theyre
.250. They are in VERY good shape. Splines are mint. You can see the date I
wrote down when I put them in and when they came out.
Let me know if you have any questions Priced on the deals for quick sale. 730 bucks.
Three Eagle Rods and CP pistons (Shelf Turbo pistons @ 89 mm) Broke the
fourth rod. These are all mint and have only one Assembly TQ on the ARP 2000
(3/8 shank 7/16 head 2000 bolts) No spun bearings, no issues. All pistons and
rods are mint Piston skirts are mint and rings and bearings are still on
them. No scratcjes on skirts no det pitting. You can still See the CNC marks
on the crowns... I got some Pauters now and went back to 88mm on a new block
or Id run them again.
120 bux
50 MM H22A/A1 crank
Came out of running JDM crate motor no issues100 bux
Garrett T04ZR dual ball bearing turbo Ive had on my car for the past couple
summers. It is MINT, No shaft play, no chips. No bullshit. I made 750 WHP
and 575 TQ at 35 PSI on my built H22 with this turbo on stock cams. Its
ALWAYS had a K&N filter on it, comews with oil restrictor.... Never run
anything but Royal Purple, and doesnt smoke or anything it shouldnt do. It
hits HARD as hell and makes GREAT power. Still have the original box that it
came in.
Specs:
To4ZR
Ball Bearing.
Watercooled.
Turbine Wheel Exducer Size: 64.56mm<
Turbine Trim: 76
Turbine A/R: .81 (T4 hotside, ceramic coated)
Compressor Housing: 0.70a/r.
Compressor Wheel Inducer Size: 66.65mm
Compressor Trim: 64
ALL H22 stuff. Some stuff I have lying around. Stuff is on the deals. All of
it known good
ARP H22 Headstuds with (NEW in box) 100 bucks
50mm H22 Crank 100 bucks
Good clean OEM Very low mile waterpump 30 bux
H22 Crank timing gears 20 each
Good H22 Oil pump 80 bucks
2 H22 valve covers. 1 mint OEM black and 1 Shaved wrinkle black
2 Bare H22 Heads with cam caps and rails 75 each
OBD2 H22 Crank sensors 20 each set
H22 water tube 20 bucks
OEM Honda main cap bolts 1 TQ on them 20 bucks
Old Feb 5, 2013 | 01:46 AM
Garage786's Avatar
G-FORCE DOG GEARSET FOR B-SERIES
Heres your chance to own a good dog gear set, for a steal of a price. Has had under 15passes at 800whp. Ive had the set inspected by a few people and everyone says the same thing. There like new and unused. There are no signs of stress at all, there ready to be installed.
Price is $3400, located in Tampa.
Gear ratios:
1st- 2.92
2nd- 1.88
3rd- 1.35
4th- 1.00
You get two final drives, ones for 24.5 tyre and the other 26". They are 4.0 and 4.7.
Old Feb 5, 2013 | 06:19 AM
boosted hybrid's Avatar
AEM AQ1 Datalogger and harness. Used for 1 race, good condition. Harness was cut, but can be extended. Throwing in with AQ1. $175.00 shipped in the 48 states.
AEM 4 Channel wideband controller w/4 aem wideband sensors. Used on ethanol fuel only, and for 2 track passes and handful of dyno runs. In like new condition. $600.00 shipped in the 48 states.
AEM EGT sensor kit w/bung. Brand new. $100.00 shipped in the 48 states.
AEM High Output Inductive coils (4). Brand new. $50.00/each shipped in the 48 states.
AEM EMS-4 Mini Harness, Brand new. $75.00 shipped in the 48 states.
(2) 0-100psi stainless pressure transducers, (1) 0-200psi stainless pressure transducers. $75.00 shipped in 48 states each. Great for monitoring fuel pressure, oil pressure, exhaust pressure, etc.
LS2 truck coils - comes with pins, connectors, and seals. 4 sets of 4 available. $100.00 shipped in 48 states for set of 4.
Hurst Line lock roll control kit, used for a race in like new condition. $75.00 shipped in 48 states.
ARP rod bolt kit GSR brand new Part #208-6401 $50.00 shipped in the 48 states.
Longacre Toe adjustment kit. Used twice, good condition. Great tool for making remote suspension changes (track) $175.00 shipped in the 48 states.
Longacre Digital caster/camber kit. Used twice, good condition. Great tool for making remote suspension changes (track) $200.00 shipped in the 48 states.
K series PRB cylinder head. Comes with valve cover (not pictured), cams, valvetrain, rockers, bolts. Missing coolant temp sensor, and misc items such as coolant neck. In good working condition. $650.00 shipped in the 48 states.
Cusco 1.5 way clutch style LSD k series In good condition, has a little bit of mileage on it (may 1,000 miles). Great track or auto-x differential. $750.00 shipped in 48 states.
K20z3 1-4 gear main/countershaft assembly. Gears/syncros had 38,000 miles on them, have normal wear on them. $300.00 shipped in the 48 states.
Brand new Bogart 15x11 RT-4 spoke style wheels. Polished lip with black anodized center. Ultra light dual bead lock option. $1400.00 shipped.
(2) 10lb CO2 bottles. Inline auto CO2 shut off valve. 10lb billet CO2 roll bar mount. 0-100 and 0-90 preset CO2 regulator. $175.00 shipped in the 48 states.
All prices are fair and firm, not interested in trades. Shipped prices are for 48 states. Pictures can be found here:
https://www.facebook.com/evanstuning.../photos_albums
Old Feb 5, 2013 | 07:17 AM
hatrickstu's Avatar
All prices are OBO, but I am not taking a low ball offer, all parts are located in Rowlett, Texas and can ship ASAP. I am selling a good portion of my turbo setup.
I have a used Full Race divided top mount B series manifold. It was cracked and repaired at one point, no issues at all with cracking or leaking now. $700 for the manifold. PRICE DROPPED
Also selling the 4-inch dowpipe for this manifold. Very nice piece, and currently has the precision flange on it. $250 for this:
I am also selling my Precision 46mm wastegates with dump tubes. One tube looks like crap because it is not stainless, that is literally the only issue with the setup. They gates are in nearly perfect condition, work flawlessly and will come with 19psi spring setups in each. $500 for the setup. $$SOLD$$
Last I have my Intercooler for sale, I do not know the brand but it worked great on my 600hp setup and has no issues at all. It has 11.5x23.5x4 core. I was running this with my 6765 on the full race manifold and I will throw in the first charge pipe. I would like $400.00 for it.
Old Feb 5, 2013 | 07:38 AM
turbotypeR@SPEC's Avatar
25 Year Member
Bullseye S372 w/race cover and 1.25 exhaust-$600
GSR longblock for sale-$1000
Weldon 2025a fuel pump for sale. Just freshened up from Weldon-$500
New Racepak Logger dash for sale. This is a complete stand alone logging dash, not just the iq3 display. New price is $1495, I need to get $1200.
Old Feb 5, 2013 | 08:44 AM
SPOOLINmatt's Avatar
706-346-6024
matt.stover@comcast.net
ATI Street Damper: $250
MSD Digital 6: $200
Aeromotive Pro Pump - Flows a shitload
$525
-Precision GT4272R
$$OLD!!
-Custom Forward Facing Turbo Manifold, Selling for someone else, test fitted on my car to show pictures. Fabricated by Joe Simpson at Tempest Racing.
With 4" SS Downpipe
Flanged for 60mm Tial
$999.00 OBO!!
Liberty's Gears 1st generation 3rd gear, countershaft side, 34 teeth, 1.36:1
I no longer need to keep it as a spare
$100 OBO
Old Feb 5, 2013 | 08:50 AM
92redhatch's Avatar
Item: 92 587whp fully built civic part out
Price: $$$$
Contact: Pm or text (305)409-5776. Don't text me after 10pm
Item Description:[B] Text me for prices i have a ton of parts that aren't listed that ill add
Vehicle Description: I'm parting out my pride and joy. I've owned the car 9 years. I think it's time for me to move on. It's a 1992 civic cx. Everything on the car is for sale. Everything
Parts left for sale
OEM obd1 vtec Dohc distributed with NGK blue wires $100
B series shift linkage $65
Original oem Integra Type R shift *** with nut $40
Rear strut bar $40
Front strut bar $40
4 port electronic boost controller purchased from Turbogixxer tuning $45
Slim radiator fan $40
Oem radiator fan $25
Oem size autozone radiator $40
NGK Blue spark plug wires $40
Engine Sold!!!
Probably more things I'm forgetting
Car is basically a true street class race car.
Ran a best 6.8 at 110mph with 587whp and 411trq
Here's a few vids from YouTube on the car
[url=http://youtu.be/kdb_JnmdPac]587whp 411wtrq at 27psi 6765 billet t3 - YouTube[/
Photos:[B] Photos:[B]
Front strut bar $40
Rear strut bar $40
Stock radiator $60 (as seen in pic everything included)
Distributor with NGK blue wires $obo
Spare parts OBo
Old Feb 5, 2013 | 08:52 AM
sportfwddc2's Avatar
BNIB Tial MV-R 44mm (black) wastegate comes with all springs and hardware... SOLD
Old Feb 5, 2013 | 09:09 AM
newtype_33's Avatar
b-series super single competition clutch used 5 passes plus dyno...$500 shipped plus paypal fee.
for more pics and info call/text 925-325-5005
thanks
Old Feb 5, 2013 | 03:38 PM
boostontheD's Avatar
AFI topmount manifold with siliver paint/coating. (bought it with the coating already done)
T4 flange with 44mm WG flange no cracks or rewelded cracks
PRICE 600shipped plus paypal fees. OBO
Also have 2 PTE exhaust housings for sale
.81 T4 with Vband exhaust $125shipped
.96 T4 with vband exhaust @125shipped
Old Feb 5, 2013 | 03:39 PM
johnls's Avatar
sold
Old Feb 5, 2013 | 03:40 PM
TegraGSXR's Avatar
Last October I had a daughter and this summer I realized my priorities and goals in life have changed. I have owned the car for 10 years and it been a project since. 1991 Acura Integra LS. It has a weld in ten point cage, Lighter/Faster sunroof plug, VIS carbon fiber hood, ETD tracking bar, Skunk2 drag coilovers, sumped tank, and relocated battery. It has the factory dash, door panels and head liner. It doesn't have seat, heat or a/c behind dash, gauge cluster or steering wheel. Asking $1200. I check my pm's often or you can text me at (603) 724 0164. Bobby
Old Feb 5, 2013 | 04:10 PM
jdm inc's Avatar
few parts i need to get rid of
pm for more info! buy pays pp fees and shipping unless otherwise
gsr head studs no nuts only have 9 studs -make offer
str adj cam gears-sold
front mount manifold 850 obo
one solid driver side mount 150 obo
cam seal 20 shipped.
Old Feb 5, 2013 | 04:18 PM
blueballsh22's Avatar
built turbo h2b partout
Parting out a hatch...most parts have only a handful of passes and some dyno time...
Contact: Here or Jdmblack99@gmail.com
Can and will meet up for parts drop off or will ship at buyers expense
Paypal accepted
all prices are negotiable, lowballs will be ignored, prices do NOT included shipping or paypal fees
parts and pics in thread...thanks for looking
http://hondamarketplace.com/showthre...7#post48416257
Old Feb 5, 2013 | 05:28 PM
SpeedFactoryRacing's Avatar
Icon7 Re: Feb FS Thread
BME Forged Aluminum Connecting Rods 5.364 CC, LS Rod Journal, .827 Wrist Pin
10 Passes $500 shipped in the US.
Old Feb 5, 2013 | 05:54 PM
paulzy's Avatar
Skunk2 Pro Series Cam Gears for B-series. Brand new. Have installed them but the enigne was never turned over or started.
$200
Old Feb 5, 2013 | 08:31 PM
Charlie Moua's Avatar
driveshaft shop stage2 H22 hybrid axles were +$800 back in 2004
selling for $280
custom h22 intake manifold + fuel rail (-8an fitting) = $200
Taiwan F22/H23 turbo manifold.
Tig welded on some bracing and flat sanded it.
Turbosmart 40mm flange
$200
Precision 5858 SP Cover, T4 .58 a/r.
Brand New in bag!
$800 shipped (insured)
Old Feb 6, 2013 | 02:29 AM
vavoom's Avatar
Fullblown dual pump hanger 240.00 no pumps or fittings included.
Old Feb 6, 2013 | 04:01 AM
ls_on_boost's Avatar
Manley Performance PRO SERIES TURBO TUFF "I" BEAM STEEL RODS out of my ls vtec had 25 passes at 600hp pulled motor apart to
Refresh and upgraded to alum rods asking 400 shipped price drop
Old Feb 6, 2013 | 11:38 AM
Universal Magnetic's Avatar
SOLD
