full blown dual pump fuel gauge problem help!!!!
Old Nov 25, 2012 | 04:38 PM
xbigpitax's Avatar
Default full blown dual pump fuel gauge problem help!!!!
i purchased a full blown dual pump kit and i installed it into my ek hatch wired it up to a relay and fuse everything thing works fine but my fuel gauge doesn't work anymore.... anyone know why this would happen or has this happened to any one?!?!?!
i used the search to find out if anyone had this problem but couldn't find anything, please help need this fixed
Old Nov 25, 2012 | 05:36 PM
fullblown's Avatar
Default Re: full blown dual pump fuel gauge problem help!!!!
Did you check the connector for the fuel level sensor? You might of accidentally unplugged it. The oem sensor is separate from the fuel level sensor.
Old Nov 25, 2012 | 06:00 PM
xbigpitax's Avatar
its connected my friend with an eg is having the same problem.... ill call tomorrow i think i know what it could be
Old Nov 25, 2012 | 06:02 PM
xbigpitax's Avatar
if you wouldnt mind can you please send me the way you guys wire it up mabe it has something to do with that....
Old Nov 25, 2012 | 09:44 PM
MR.johnson's Avatar
Im sure you guys did the wiring wrong. My hanger has worked perfect for 3 years...
Old Nov 25, 2012 | 11:17 PM
xbigpitax's Avatar
That's what I'm guessing but I think the way I have it is the only way to do it, can you please pm me or post here how you wired up the pump
Old Nov 26, 2012 | 03:58 AM
MR.johnson's Avatar
http://homepage.ntlworld.com/kevin.y...ng_Drawing.JPG
Old Nov 26, 2012 | 06:34 AM
xbigpitax's Avatar
thanks it looks like the same way i did it but im going to check it again
Old Nov 26, 2012 | 06:41 AM
xbigpitax's Avatar
did you use 1 relay or 2.... i did it with 2 mabe that could effect sumthing..... ima goign to open the floter side and see if mabe the floater is stuck or sumthing....
Old Nov 26, 2012 | 06:45 AM
92redhatch's Avatar
I have a problem with my fuel gauge. It works but as soon as it gets under half a tank the car runs like if the tank was empty
Old Nov 26, 2012 | 07:02 AM
xbigpitax's Avatar
that sounds like ur filter has come loose... maybe, rem ur filter helps pick up fuel from the very bottom
Old Nov 26, 2012 | 08:49 AM
MR.johnson's Avatar
I'm running two relays wired like the picture.
Old Nov 26, 2012 | 08:52 AM
xbigpitax's Avatar
so am i on the factory wires how did u split them, i spliced the wire and conected two wires from each cable, and wired it the same... i dont understand how this is happeneing.... i have it wired just like u said in the picture, how fustrating
Old Nov 26, 2012 | 01:32 PM
turbo boost's Avatar
what amp fuse would you recomend? 20 amp? 30 amp?
Old Nov 26, 2012 | 01:39 PM
92redhatch's Avatar
Filter isn't loose. I triple checked
Old Nov 26, 2012 | 04:06 PM
EJ1_Ex's Avatar
call FBM
Old Nov 26, 2012 | 05:37 PM
xbigpitax's Avatar
i used a 40amp relay an the fuse is a 30.
xbigpitax
Dec 1, 2012 07:05 PM
changknows
11
Sep 7, 2009 02:29 AM
Wherm5150
Feb 3, 2009 07:26 PM
WeaponR
Apr 26, 2004 11:45 PM
