Honda CR-V & Element 2WD & 4WD Element & CR-V
2014 CR-V with code issues
Old Nov 30, 2017 | 05:48 AM
Stuka's Avatar
Default 2014 CR-V with code issues
Recently I bought a used 2014 CR-V for my Son, with 30,000 miles, just 3 day ago the chk engine light comes on, I checked with a scanner and it shows codes P0455 and P0456, looks there is an issue with teh EVAP system, any help in where to start diggin? Thanks
Old Nov 30, 2017 | 06:42 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: 2014 CR-V with code issues
Issue could be due to the gas cap gasket seal. A Honda service bulletin regarding some 2012 - 2013 CR-Vs had gas cap gaskets that created too much friction, preventing the cap from sealing properly.
The issue may possibly be similar. Regardless, turn the gas cap at least 3
times after refueling to see if the issue goes away.
Old Nov 30, 2017 | 10:37 AM
UK-Kev's Avatar
Hello, attached is the bulletin that tech8 talks about.
Kev
File Type: pdf
Old Nov 30, 2017 | 10:48 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Kev
That is not the specific bulletin.
This is the Honda service bulletin: http://techinfo.honda.com/Rjanisis/p...nu/A14-010.PDF
Old Dec 1, 2017 | 06:49 AM
UK-Kev's Avatar
Hello Tech8, Apologies for my assumption that you were talking about the bulletin I posted!!! It would appear that we have two TSB relating to the same issue from both sides of the pond.
Regards,
Kev
Old Dec 3, 2017 | 04:49 AM
Stuka's Avatar
Thanks Guys for the info. Now I know where to digg
Old Dec 8, 2017 | 04:26 AM
Stuka's Avatar
Ok Guys ,thanks a lot , finally I found the problem, was the gas cap, installed a new one and wala, thanks again
Corona92
18
Oct 24, 2020 05:51 AM
4est2sea
Aug 8, 2017 04:20 AM
lankan-balla
Apr 29, 2013 08:51 AM
LACruiser
Nov 5, 2010 10:58 PM
nicokpe
Sep 29, 2007 04:50 AM
