Honda CR-V & Element 2WD & 4WD Element & CR-V
05 CR-V Water pump replacement - what else?
Old 11-25-2017, 12:05 PM
jDMJeRk's Avatar
Default 05 CR-V Water pump replacement - what else?
I need to replace the water pump on my CR-V. It's got about 140k miles on it.
Is there anything else I should replace while I'm at it?
Anyone have a suggested retailer to purchase the parts from? I reckon back in the day, you could buy a "kit" but I think this was more for the timing belt/water pump combos.
Thanks in advance!
Old 11-25-2017, 05:24 PM
brewerkz's Avatar
Default Re: 05 CR-V Water pump replacement - what else?
Rock Auto is pretty competitively priced. I guess I would assess the condition of the radiator, since your draining the coolant out.
Old 11-25-2017, 05:30 PM
Global Moderator
tech8's Avatar
The drive belt if it hasn't been changed before.
Old 11-25-2017, 07:13 PM
Occidentalis's Avatar
Make sure they do the water pump gasket (they will probably know to do that) when they do the water pump.
If you're in there, a valve adjustment and cover gasket is worth it at that mileage, and like tech8 said, a belt.
Old 11-27-2017, 07:14 AM
jDMJeRk's Avatar
Thanks for the input.
I'll check out the radiator
Buy a new belt since I'm in there already.
I'll investigate the valve adjustment; never done one on a k-series before (I"ll have to research that) and the vc gasket since I'm already there.
I thought there would be more to it.
Rick1t
03-14-2016 01:30 PM
95DC2GS-R
08-12-2009 05:23 AM
rafiq7
11-30-2004 09:16 AM
pnthr30
10-31-2003 07:29 AM
Fooman
10-25-2001 02:47 PM
Quick Reply: 05 CR-V Water pump replacement - what else?
