Scary stuff
Old Apr 3, 2007 | 09:17 PM
Evile140's Avatar
Default Scary stuff
Guy brought his car over for me to work on his headers, he caught one of them on the trailer while loading his car.
Well I was looking at the car and found some scary stuff. It is a mustang first off, 410ci, ported everything, should run around 5.80's in the 1/8th at a little over 3000#.
Anyway, here are some pictures of the brackets holding the motor plate on, and some pictures of the welds on the cage. It has already been inspected and passed.
Here is a link to the directory.
http://www.eville140.com/wow/
I just hope he never wrecks the thing.
Later
Randy
Old Apr 3, 2007 | 09:21 PM
.RTErnie's Avatar
Default Re: Scary stuff (Evile140)
WOAH! thats some shitty welding lol. I've mig welded for less than an hour in my life and even I know how to weld better than that lol. More heat!!!!!
Old Apr 3, 2007 | 09:27 PM
F20Cteg's Avatar
Default Re: Scary stuff (RTErnie)
That is some scary **** alright.
Reguardless of the person that actually did it, the NHRA tech should be fined for okaying such unsafe welds, then fired.
Old Apr 3, 2007 | 09:40 PM
tony1's Avatar
Default Re: Scary stuff (F20Cteg)
Damn, i wonder if getting a chassis cert sticker is like getting an inspection sticker if you know the right people? I can't imagine anybody actually looking over that cage and deciding it was safe.
Old Apr 3, 2007 | 09:44 PM
Finest's Avatar
The cage welds look like glue! The Elmer's brand stuff!
Old Apr 3, 2007 | 10:13 PM
Bantam's Avatar
2nd Coolest Person in DFW
Default Re: Scary stuff (Finest)
seems like the roll cage is the wrong place for budget cuts
Old Apr 4, 2007 | 12:17 AM
terr1bleone's Avatar
i tried explaining this scenero to a guy about a year back. i told him that most tech inspectors only look at point placement, and if its welded completely around the tube, it usually passes. he didnt believe me though, he argued that they are very strict on the weld quality. just goes to prove it.
Old Apr 4, 2007 | 04:40 AM
weiRtech's Avatar
OG Fabricator
bubble gum would work better than those welds- on the cage especially. scary indeed.
Old Apr 4, 2007 | 05:42 AM
Luke J's Avatar
Default Re: (weiRtech)
It looks like he put so much time and effort into everything else.....Wow.....That is crazy
Old Apr 4, 2007 | 06:12 AM
RACEPAK's Avatar
Default Re: (Luke J)
lol
Old Apr 4, 2007 | 06:58 AM
david@didrace.com's Avatar
I've seen the NHRA pass stuff like that time and time again.
Old Apr 4, 2007 | 09:01 AM
k24em2's Avatar
Default Re: Scary stuff (david@didrace.com)
Just means more entrance fees for the NHRA the more cars they pass. You sign a wavier anyway so if you crash and burn it ain't their fault.
Old Apr 4, 2007 | 12:29 PM
shrums-EG6's Avatar
wtf
Old Apr 4, 2007 | 12:34 PM
tmac007's Avatar
Default Re: Scary stuff (k24em2)
Thats brutal, somebody should rig a cage up with puddy or sumthing, paint it and see if it passes. And if it does take it to the legal level. That is terrible.
Old Apr 4, 2007 | 02:34 PM
essex's Avatar
Default Re: Scary stuff (tmac007)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tmac007 &raquo;</TD></TR><TR><TD CLASS="quote">Thats brutal, somebody should rig a cage up with puddy or sumthing, paint it and see if it passes. And if it does take it to the legal level. That is terrible.
LOL I can make some pretty sweet TIG look-a-like beads with gasket maker or a squeeze bottle of ketchup....just let it dry...then paint....lol.
Old Apr 4, 2007 | 02:41 PM
JT2MA71's Avatar
is that pvc pipe glue?
Usually, when welding motor mounts to the car you'd want good enough welds to make sure your $10,000 motor doesn't fall the fawk out.
Old Apr 4, 2007 | 03:32 PM
9bells's Avatar
OG Fabricator
Default Re: (JT2MA71)
Brutal. I was recently at the mercy of the tech inspector for nhra.
Certified my cage happily, failed 3 of the ones that showed. He was
looking with a flashlight, the whole nine yards.
Even heard him say to the one guy;" I can't pass something like this"
I have heard it both ways. Some of these guys that try to do it themselves
are just brutal. As stated, last place to scrimp.
That guy's life is at risk in an accident. When the welds split, the tubes will be like weapons inside the cab.
Old Apr 4, 2007 | 06:48 PM
CagedRuss's Avatar
I think I may have this one beat. I had a customer about three years ago that bought a Vega Wagon that ran a 540 CID Chevy and was running 1/8th and 1/4" for a few years. The original owner and his brother built the car in their driveway.
My customer/friend bought it really sight unseen, saw it through pictures. Gets the car delivered to his house and was excited about the car that he didn't see the flaws because of the nice paint job.
Loose wheel studs and also the knurls were stripped
Aluminum fuel line and battery cable rubbing suspension and frame
unsupported fuel and brake lines
Holes on both sides of the frame rails!
Guess is as good as mine?
Guessing the car was stick welded and then re welded with wire to make tech?
More
Gawd there is more!
Customer paid to much for the car, had to gut the frame and cage and repair the frame and do a new 10 point cage with a new floor. The front suspension was just as bad, lower strut rods for the control arms had broken frame brackets and were held together with about a 1/2" of bird crap stick welding. Car was and is still the most dangerous thing I have ever seen to date!
Old Apr 4, 2007 | 07:08 PM
Lamchop0000's Avatar
gruesome thread
Old Apr 4, 2007 | 07:14 PM
GFurm's Avatar
cage looks like it has a disease...
Old Apr 4, 2007 | 07:18 PM
hucoreyCRX's Avatar
Looks like he thought he could just go a buy the cheapest little 110v mig welder at homedepot and built a drag car. If he were to ever blow a tire going down the track with that set up, man, I dont know if he would live or not.
Old Apr 4, 2007 | 08:19 PM
RC000E's Avatar
Default Re: Scary stuff (hucoreyCRX)
OMFG...RLMFAO...TERRIBLE!
Old Apr 4, 2007 | 08:40 PM
PPLH8R's Avatar
Default Re: Scary stuff (RC000E)
Dude that **** is solid !!!!!
Old Apr 4, 2007 | 08:46 PM
h22sedan's Avatar
Default Re: Scary stuff (PPLH8R)
Wow, those welds are ***.
Old Apr 4, 2007 | 09:15 PM
JT2MA71's Avatar
I wouldn't worry about the driver's safety in that car at the track.
I would question the safety of the spectators.
