12's possible with this setup????
Old Apr 13, 2003 | 12:27 PM
TurboJesse
Guest
Posts: n/a
Default 12's possible with this setup????
I just finished installing my turbo kit on my del sol but im not able to drive it untill i get the bodywork and paint done so ive been ansy as hell these last few days anyways just wondering if you think 12's (i mean like 12.99 lol) are possible with this set up...
93 Del sol (Only interior left is dash, door panels and seats, no ac, no powersteering, Bumper supports removed, trunk fully gutted)
JDM B16A SIR II
T3/T04E 60 Trim .63 ar
Custom Equal Lenght Manifold
Tial 35mm Wastegate
Sheepdog BOV
3" Downpipe
3" Exhaust (no cat)
Starion Intercooler (modified endtanks)
DSM 450cc injectors
Updated Uberchip
BFG 205/50/15 Drag radials on GSR blades....
Hoping to hit low 13's atleast, but 12's would be great @10psi
Old Apr 13, 2003 | 01:11 PM
DLB1994's Avatar
Default Re: 12's possible with this setup???? (Mpir3)
how much boost
Old Apr 13, 2003 | 01:43 PM
TurboJesse
Guest
Posts: n/a
Default Re: 12's possible with this setup???? (DLB1994)
10 psi
Old Apr 13, 2003 | 02:18 PM
1 2 NV's Avatar
i think at 10psi it shouldnt b a problem i dont actually think u will run that time though. u will have traction issues with the DRs. learn to launch the car and it will come to u.
Old Apr 13, 2003 | 04:10 PM
turbodsmpower's Avatar
Default Re: 12's possible with this setup???? (hondaatwsu)
you should be able to do that no problem my buddy just did a numerous amount of 12.80 passes on 7psi on drag kit w/ 92 civic hatch si full weight car minus backseat so you should have no problem
Old Apr 13, 2003 | 05:08 PM
TurboJesse
Guest
Posts: n/a
Default Re: 12's possible with this setup???? (turbodsmpower)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbodsmpower &raquo;</TD></TR><TR><TD CLASS="quote">you should be able to do that no problem my buddy just did a numerous amount of 12.80 passes on 7psi on drag kit w/ 92 civic hatch si full weight car minus backseat so you should have no problem </TD></TR></TABLE>
Street tires? or slicks?...
Old Apr 13, 2003 | 06:18 PM
sqwerz
Guest
Posts: n/a
using a pair of slicks should make you hit 12's.
Old Apr 15, 2003 | 03:25 AM
Default Re: 12's possible with this setup???? (sqwerz)
slicks but can be easily done on a set of good drag radials
Old Apr 15, 2003 | 04:31 AM
Evil DOHC's Avatar
Should run around a 110 trap. You are good to go 12's with a 2.2 60 ft or better. You should have no problems runnin that time but you will be spinnin out the whole hard.
EVIL
Old Apr 15, 2003 | 05:53 AM
13HYBRID20's Avatar
Default Re: 12's possible with this setup???? (Evil GS-R)
Don't you guys read before you ask a question? I think bfg's are a very good tire you should be able to get some 2.0 60's on those if not better.
Old Apr 15, 2003 | 10:46 AM
marques4130's Avatar
i almost have the same setup.
93 civic ex coupe
jdm b16a1 w/ hydro tranny
t3/t04e 60 trim .63 ar
sfp manifold
custom piping
tial wastegate
pwr intercooler
delphi 550cc injectors
walbro pump
only difference is i'm going to be running about a 1 to 1.5 degrees of camber for autox and right now i have some sweet general 195/50/15 on my rotas
what do you guys think i could hit if i somehow managed to get off the line without roastin the tires
Old Apr 19, 2003 | 02:41 PM
AllMotorDC2's Avatar
I think you should be able to hit 12's no problem. As long as you hook (As in 2.0 60' foots) you should be in the 12's at around 108-109 at like 10 psi. My friend Dave has a B16 in his Sol with I/H/E with a 75 shot and is going 13.30's on some crappy 555R's.
Old Apr 19, 2003 | 05:45 PM
12SecHatch's Avatar
Default Re: 12's possible with this setup???? (13HYBRID20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 13HYBRID20 &raquo;</TD></TR><TR><TD CLASS="quote">Don't you guys read before you ask a question? I think bfg's are a very good tire you should be able to get some 2.0 60's on those if not better.</TD></TR></TABLE>
i got 1'9's on bfg g forces
mitsuman
51
Apr 9, 2013 07:53 AM
Sir_Wallace
Mid-Atlantic (Sales)
15
Nov 28, 2006 07:16 PM
srg
Jul 20, 2006 11:28 PM
srg
May 27, 2006 01:13 AM
AzntaggeR
May 9, 2005 08:01 PM
