To the DA's, attn: bottlefedintegra
Old Apr 9, 2003 | 07:58 AM
g2turbo's Avatar
Default To the DA's, attn: bottlefedintegra
Im in the final process of removing all the tar and unwanted interior pieces from my DA and just wondering HOW LIGHT the stripped 2g chassis can get. Its an RS no AC etc.
Bottlefedintegra what does your car weigh??
Here are some pics before i started and i can assure you it looks nothing like this now. Ill upload the new pics tonight hopefully. Im hoping for something around 2200 lbs. Dash, door panels, and carpet will remain.
What do your DA's weigh. Thanks guys
Old Apr 9, 2003 | 10:06 AM
bottlefedintegra's Avatar
Default Re: To the DA's, attn: bottlefedintegra (g2turbo)
I'm not sure what the weight is but I'll be going to the track next week and I'll get it weighed there. If I had to guess I would say around 2100 lbs. or less.
Old Apr 9, 2003 | 10:36 AM
boostin b16's Avatar
sorry to jack your thread, but what did you use to get that tar orr the floorboards of your car? that **** is hard man!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g2turbo &raquo;</TD></TR><TR><TD CLASS="quote">Im in the final process of removing all the tar and unwanted interior pieces from my DA and just wondering HOW LIGHT the stripped 2g chassis can get. Its an RS no AC etc.
Old Apr 9, 2003 | 10:42 AM
eddiecut's Avatar
Default Re: To the DA's, attn: bottlefedintegra (boostin b16)
heat gun works and so does dry ice.....
Old Apr 9, 2003 | 01:20 PM
MotorMatrix.com's Avatar
I am a bad person
Default Re: To the DA's, attn: bottlefedintegra (eddiecut)
I used an air chisel. its worked nicely. did the whole car in about 1 hour
Old Apr 9, 2003 | 01:23 PM
Default Re: To the DA's, attn: bottlefedintegra (MotorMatrix.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MotorMatrix.com &raquo;</TD></TR><TR><TD CLASS="quote">I used an air chisel. its worked nicely. did the whole car in about 1 hour</TD></TR></TABLE>
thanks for the info guys ... one more project for the weekend!!
Old Apr 9, 2003 | 01:36 PM
littlebluecrx's Avatar
The integra we ran last year was completely striped minus glass it weighed 2300 pounds, 2nd gens are phat pigs
Old Apr 9, 2003 | 02:37 PM
sickda6's Avatar
Default Re: To the DA's, attn: bottlefedintegra (littlebluecrx)
im at 2237 with back half lexan, no sound deadining, thick mat on firewall gone, single sparco 11lb seat, 10 gal fuel cel with 2gal in it, and not much else. oh yeah it has a chromoly 6pt cage also....had 17in te-37's on it when weighed.
Old Apr 9, 2003 | 02:51 PM
paulzy's Avatar
Default Re: To the DA's, attn: bottlefedintegra (sickda6)
Mike(ninsecrx)mentioned something about brake fluid taking the tar off like nothing. I'm gonna try it. I've tried the heat gun and it gets too gooey...The dry ice method works better than teh heat gun method
Old Apr 9, 2003 | 03:32 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: To the DA's, attn: bottlefedintegra (Paul_Vang)
Try anti-freeze also
Old Apr 10, 2003 | 10:16 AM
g2turbo's Avatar
Default Re: To the DA's, attn: bottlefedintegra (SIXTYdashONE)
thanks for the replys my car is getting towed to the paint booth next week to have the interior repainted white cause the car was originally red. The rear tire compartement is also getting cut out and a flat plate welded in. Hopefully to help with wind resistence.
id be happy with 2200-2300 lbs. time will tell
CHRIS
Old Apr 10, 2003 | 10:43 AM
Dublocivic's Avatar
Air chisel.. why didnt I think about that. I sat in my cousin's black CRX in the 100 degree heat with the windows up to get the tar hot enough to scrape up. That sucked bad.. I think I lost about 6 pounds and started hallucinating
Old Apr 10, 2003 | 11:04 AM
HotRodTeg's Avatar
Default Re: To the DA's, attn: bottlefedintegra (Dublocivic)
How heavy is the tar crap that is under the cars. Also how heavy is the tar stuff under the carpet in the car?
Old Apr 10, 2003 | 01:52 PM
Alcoholic93Integra's Avatar
Gotta give props to people still runnin the DA'S!!!!!!!!!!!!!
Old Apr 10, 2003 | 11:31 PM
LODOSS's Avatar
Default Re: To the DA's, attn: bottlefedintegra (Alcoholic93Integra)
jdm front bumper support saves another 15-20 lbs. =P also jdm headlights = 10 lbs.
my car is prob around 2400-2500 if backseat and all plastic is stripped. it is an auto
and auto tranny is heavy =p
Old Apr 10, 2003 | 11:35 PM
Kwuaymaikrup's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g2turbo &raquo;</TD></TR><TR><TD CLASS="quote">The rear tire compartement is also getting cut out and a flat plate welded in. Hopefully to help with wind resistence.
CHRIS</TD></TR></TABLE>
I can't seem to visualize what you are talking about here. Can you explain a little more? I have a DA9 as well that I am trying to lighten up a bit. Thanks,
-Ryan
Old Apr 11, 2003 | 03:16 AM
the-anti-crack's Avatar
fora da.
nice car man.
whats up with the ol line going over the valve cover?
Old Apr 11, 2003 | 03:56 AM
xxplosif1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Alcoholic93Integra &raquo;</TD></TR><TR><TD CLASS="quote">Gotta give props to people still runnin the DA'S!!!!!!!!!!!!! </TD></TR></TABLE>
DA'S are unique and have their own style !
Old Apr 11, 2003 | 04:57 AM
g2turbo's Avatar
Default Re: To the DA's, attn: bottlefedintegra (xxplosif1)
i didnt think my line was long enough to go around. But im redoing it eventually just really havent got around to it.
If you pop the hatch and look at the rear floor area there is the spare tire well. I am basically cutting the whole well out, and making the whole rear of the car flat.
Old Apr 11, 2003 | 06:44 AM
MARC P's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g2turbo &raquo;</TD></TR><TR><TD CLASS="quote">i didnt think my line was long enough to go around. But im redoing it eventually just really havent got around to it.
If you pop the hatch and look at the rear floor area there is the spare tire well. I am basically cutting the whole well out, and making the whole rear of the car flat. </TD></TR></TABLE>
If your ever plan on runnig at an event, you will be put in the pro class
Good luck
Old Apr 11, 2003 | 08:54 AM
old guy's Avatar
Default Re: To the DA's, attn: bottlefedintegra (MARC P)
NHRA Sport FWD class rules mandate stock floorpan, front to rear. Cutting out the spare tire well will bump you to Hot Rod, or back to brackets.
Old Apr 11, 2003 | 09:10 AM
turbochic's Avatar
Default Re: To the DA's, attn: bottlefedintegra (streetracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streetracer &raquo;</TD></TR><TR><TD CLASS="quote">How heavy is the tar crap that is under the cars. Also how heavy is the tar stuff under the carpet in the car? </TD></TR></TABLE>
When we took out the tar in my 97 ex trunk area, back seat area, and passenger floor, it equaled 35 lbs, not too sure how acurate my scale is, but it was freakin heavy, still hafta do the driver side. Also we did it with a large chisel and hammer =hand blisters *ouch*
Old Apr 12, 2003 | 03:11 AM
o i c.
any details on the motor.
im either buildig an ls-vtec (still have the b18a) or the b16...cant decide
how happy are you with the built b16 in a da?
Old Apr 12, 2003 | 06:40 AM
xxplosif1's Avatar
Default Re: To the DA's, attn: bottlefedintegra (the-anti-crack)
imo, the da is too heavy for a b16a, even for a built one. I'd built your b18a bottom end and get some cams or just swap a vtec head on it.
Old Apr 13, 2003 | 02:55 AM
im running a b16 in my da now and fairly happy. its faster than the b18a. when i finally get my turbo stuff going(getting real tired of looking at it), would rather have a little more.
i also have to say reving to 9k is fun too
