Cam Timming
I have a 96 b18c1 motor and the distributor is all the way advanced and i am still 3 deg retarted from stock
1. The timming belt is a after market belt and is longer
2. The head is shaved and making it a longer belt
3. It has a thinner head gasket
I myself think it is some of all and i am going to go with a Honda belt and get a set of cam gears, and with that bring the distributor back a bit then advance my cams and then bring the ignition timming up 2 deg
the car had a compression test done and it was cold it put out like 210 psi of comprestion
Is this going to be the right way to go about this and could there be anything else wrong
and the car does run strong it went 14.4 N/A and i had a cell from the obd2 ecu now i have the obd1 ecu with a convertion harness and it seems to me that it is running stronger
this is in a 95 hatch DX
i tryed posting it in the hybrid but no luck there
Mine is the same way, I have it all the way advanced and it is still off by like 3 degrees retarded. I think cam gears could correct this problem but Im not positive. Anyone? Thanks
what is done to your car or the change you made to make it like this?
i will have my GE cam gears in today thanks to Mike@MotorMatrix
i will tell you later today when it all goes on with a new Honda timming belt
i got my ignition timming to come up by advacing my intake cam and i am still tunning it in
any one have an idian like as in retard the ex and advance will give say less bottom and more top? i am looking for a bit more mid and top
T_bones
Aug 20, 2007 06:43 AM
JDMflavor_EJ
20
Jul 19, 2007 05:52 AM
