another et ?
Old Apr 15, 2003 | 05:28 PM
00hatch98r's Avatar
Default another et ?
ok be real with me . i have a 00hatch with a 98 spec r basic bolt ons intake exhaust header skunk2 chip p28. 14.7 at 95mph is the lowest. i taken it to times ever. my R/t was .896 should i keep practicing or should i dano it to see if something is wrong. be blunt. but don't kill me
Old Apr 15, 2003 | 05:31 PM
UncleBen'sRacing's Avatar
Default Re: another et ? (00hatch98r)
r/t has nothing to do with et
what are your 60ft times
Old Apr 15, 2003 | 05:34 PM
00hatch98r's Avatar
Default Re: another et ? (AllMotorEF9)
60ft time 2.431
Old Apr 15, 2003 | 05:41 PM
ok you need to learn to drive
what are you launching at, what are your tire pressures, are you dropping the clutch, feathering?, are you power shiffting or letting off the gas....
when you took off did you spin or not
Old Apr 16, 2003 | 03:00 PM
00hatch98r's Avatar
first gear mad spin, i try to feather but it doesn't always happen that way i don't power shift. but im a good shifter? how much life off the clutch will that take? what about tranny problem with power shifting? tire pressure 20lbs
Old Apr 16, 2003 | 03:46 PM
i have never had any problems powershifting, i dont think it strains it that bad
what did you launch at?
and what is vtec set at
Old Apr 16, 2003 | 11:15 PM
10seconds's Avatar
Honda-Tech User
it is not your shifting it is your 60's, if you can cut them down to a 2.2 you can probably hit a 14.4 or a 14.5. 14.7's are normal for stock GSR motors in a hatch...unless you have like a 92-95 cx or vx. I would practice your launching...or grab some drag radials.
steve
Old Apr 17, 2003 | 03:09 AM
Default Re: another et ? (10seconds)
yes i agree with you, thats why i am trying to see what he is launching at so i can help him figure it out
Old Apr 17, 2003 | 12:19 PM
00hatch98r's Avatar
the vtec is at 5200 and from you 2 it sounds like i need to work on my launch what would you run if you had the car? tire pressure. is there any way i can get better traction? what would you suggest?
Old Apr 18, 2003 | 07:42 AM
<--- i would run 22 psi, on 15" wheels.... dump the clutch at 4000 RPM, after a nice burnout, But DONT BURN OUT IN THE WATER....... after that its smooth sailing, with 5200 vtec.... its perfect
95vtec
Feb 5, 2015 06:30 AM
XhaloZ
Jan 13, 2006 01:17 PM
95vtecgook
Feb 22, 2003 09:25 PM
E. Honda
15
Sep 17, 2002 12:27 PM
Minorgliche
11
Dec 13, 2001 01:16 PM
