B16 Stroker
Old Apr 21, 2003 | 06:55 PM
Elex's Avatar
Default B16 Stroker
Tried this in tech got no answer, if i want to run a B18C crank in a B16 block what length rods do i need and how far does the wrist pin on the pistons need to be moved up?
Old Apr 21, 2003 | 07:09 PM
Suprdave's Avatar
Default Re: B16 Stroker (BSeriesMadness)
I'm not going to 'give' yu the answer...
but take the
b18c1 crank stroke - b16 stroke
that difference has to be made up
Endyn has pistons that are .137" raised pin...the rest has to be made up in the rods.
Suprdave
Old Apr 21, 2003 | 07:23 PM
Elex's Avatar
Default Re: B16 Stroker (Suprdave)
cool thanks man
Old Apr 23, 2003 | 02:54 PM
allmotorb20vtec's Avatar
b16a stroker(skunk-2 desighn)
89mm crank ls/crv
82mm custom pistons arias
custom rods by crower
Number of Cylinders are = 4 to 1
Piston Diameter = 82.000 Millimeters
Piston Oversize = 0.000 Millimeters
Engine Stroke = 89.000 Millimeters
Computed Engine Displacement (CID) is 115
Computed Engine Displacement (Litres) is 1.9
Computed Engine Displacement (CC) is 1880.1
w/this set up in a 91 crx hf ran a 12.86@104.9 mph stock head,cams, manifold, ect.. this longblock is for sale on e-bay check it out.... jdm b16a (skunk-2)
Old Apr 23, 2003 | 05:10 PM
Elex's Avatar
Default Re: B16 Stroker (allmotorb20vtec)
yea i pretty much refuse to buy anything from skunk2 thanks anyway.
Old Apr 23, 2003 | 05:53 PM
enginetiks's Avatar
the toda 1800cc stroker kit consists of:b18c5 crank, pr3 rods and toda pistons..this setup also clears the block without notching
Old Apr 25, 2003 | 04:36 PM
88CRXHybrid's Avatar
Default Re: B16 Stroker (mschvs)
the biggest problem you are going to have to face is the fact that the B16a block has alot shorter deck height than the b18c so you will have to use cutom rods and make sure to get it right or you will destroy your head.
Old Apr 25, 2003 | 05:33 PM
Elex's Avatar
Default Re: B16 Stroker (88CRXHybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88CRXHybrid &raquo;</TD></TR><TR><TD CLASS="quote">the biggest problem you are going to have to face is the fact that the B16a block has alot shorter deck height than the b18c so you will have to use cutom rods and make sure to get it right or you will destroy your head.</TD></TR></TABLE>
trust me i know
Old Apr 27, 2003 | 02:26 AM
263mm2.0's Avatar
There is alot of options out there to stroke it out. Best combo is to use a B18a crank, ARI rods and piston kit 81mm bore, and your at just under a 1.9, but close enough. The GSR crank is a better paper weight.
DGKrew
Jul 1, 2013 07:39 AM
ED9man
Jan 3, 2009 01:17 PM
draneusmc
Nov 13, 2004 04:32 AM
rudebwoy
Nov 19, 2003 06:48 PM
Deltax75
May 20, 2002 09:03 AM
