Honda CR-V & Element 2WD & 4WD Element & CR-V
Coilover
Old Dec 2, 2020 | 03:44 PM
jafet's Avatar
Default Coilover
I want to to know if I could use coilover from a 2003 Honda Element to a 2003 Honda CR-V
Old Dec 2, 2020 | 04:35 PM
Ryanthegreat1's Avatar
Default Re: Coilover
Front Element struts are about an inch longer with a heavier spring. This will act as a lift kit.
Also the Element has a larger ball joint on the steering end links and the CR-V ball joint is too small to work.
The rear struts use a different top hat and also have a heavier spring. Length is similar but again the Element strut is just slightly longer
Not a direct fit unless you are swapping other parts. If you are just talking an adjustable coil spring setup to put on CR-V struts then that should work.
Old Dec 2, 2020 | 05:07 PM
jafet's Avatar
I was looking to buy adjustable coilover for my crv but the one for the element are cheaper
