Honda CR-V & Element 2WD & 4WD Element & CR-V
too much?
Old Oct 29, 2016 | 02:02 AM
blumule's Avatar
Default too much?
2001 crv. 2.0 engine needs a valve job.reputable shop quoted me 1700 to 2000 dollars. is that about right? car has 165000 miles on it. I don't question it being the valve train but the price to fix it stunned me a little.
Old Oct 29, 2016 | 02:06 PM
EJ8_Man's Avatar
Default Re: too much?
You could just replace the head for a few hundred dollars + labor
Old Oct 29, 2016 | 02:49 PM
TyGuy88's Avatar
This generation suffered from receding valves. It causes a ticking from the top end and eventually will cause a check engine light for misfires. You typically need a whole new head as recommended above. It may be worth while to look into one of the low mileage engines they are bringing over from Japan. A few guys at the shop have done this in their CRVs and have been vey pleased.
Old Oct 29, 2016 | 02:54 PM
kelsodeez's Avatar
derp resistant
yeah way too much. valve job takes 2 hours maximum and even if they charged $200/hr for labor, they are overcharging you. have you considered attempting to do the valves yourself? its pretty simple and there are tons of diy videos and guides on how to do it. you would probably end up spending 100 bucks on tools, an hour researching how to do it and 2 hours to do it.
Old Oct 29, 2016 | 03:20 PM
EJ8_Man's Avatar
B18B heads are identical to B20B heads
Put an end to b18 vs b20 head debate... - Team Integra Forums - Team Integra
There is an abundance of them for sale and in junk yards.
I have grievances against the 2 JDM motors I've bought. Both burned oil despite their "low milage". Good compression from a cold engine only tells you nothing catastrophic happened inside. The engine could still have serious problems. Request a leak down test if you choose a JDM replacement as suggested.
Old Oct 30, 2016 | 11:51 AM
Cayton's Avatar
I don't know about replacing the valves but that does seem like too much. It is definitely too much for just an adjustment.
If you can change your oil you can do an adjustment. I did mine for the first time and it took me 4 hours (lots of reading and double-checking). I then re-adjusted them two days later because I was parnoid I did them wrong and the second time took me two hours. Some people say it'll take 45 minutes. I'm slow.
Old Oct 30, 2016 | 02:09 PM
EJ8_Man's Avatar
Valve job is not the same as a valve adjustment. The shop will replace the guides, valves, grind the seats, and install new springs.
Old Oct 30, 2016 | 07:18 PM
Cayton's Avatar
You're right
Old Nov 3, 2016 | 06:23 AM
blumule's Avatar
thanks for help. would it be wise to just buy a used head off a good engine and swap it out?i dont want to go jdm at this point.when you say 100.bucks for tools can it be done without removing the head from engine?is my engine the 20b?
Old Nov 3, 2016 | 07:02 AM
EJ8_Man's Avatar
If you're replacing the head on your engine it will first have to be removed. I personally would pull the engine from the car and make things easy on myself.
Find yourself a service manual. They are free online. Research the net there are many posts and videos of people doing exactly what you plan to do.
A good used head is a good alternative for fixing your engine. Find one that has been cleaned and inspected by a reputable machine shop. They should inspect the head for warpage, proper sealing of the valves, and for cracks. With the head off I would replace the valve stem seals.
Every Honda engine has a stamp. Open your hood and look to the left of your exhaust heat shield about 1/2 down the block. Follow the seam where the transmission meets the block. You will find a stamp that will say B20 something.
Old Nov 3, 2016 | 03:51 PM
blumule's Avatar
ok ,wll check numbers on head .
Vtec04
Engine Machining & Assembly
Nov 10, 2017 02:23 PM
Niki O'rourke
Honda Civic (2001 - 2005)
Oct 10, 2015 05:49 AM
TravisCadello
Jun 30, 2011 08:30 AM
GruvyTune
Jul 3, 2002 07:40 AM
Halo
Sep 9, 2001 04:25 PM
