Honda CR-V & Element 2WD & 4WD Element & CR-V
B20vtec code 43
Old Jan 1, 2017 | 01:39 PM
xlusiveracer's Avatar
Default B20vtec code 43
So I been have idle problems with my b20v and it Would throw a code 43?? Was wondering could this code be causing my idle problems?and I do have a wideband but It would stay stuck at 10.00.could it be from my wideband sensor being blown? Or something else
Old Jan 4, 2017 | 05:04 AM
UK-Kev's Avatar
Default Re: B20vtec code 43
Honda error code 43 relates to fuel pressure regulator issue – You should also check for vacuum leaks.
Kev
Old Jan 5, 2017 | 03:20 AM
I'll check my fpr.im also missing the washers that go around my injectors would that cause a leak?
Old Jan 6, 2017 | 01:51 AM
Also once that code would come on.i can turn off the car and it's gone..it only comes on once in a while if the car is not fully warmed up
Old Jan 6, 2017 | 04:28 AM
tony_2018's Avatar
Fish Twig
bro...you need to fix the issue...
Old Jan 6, 2017 | 05:54 AM
what do you mean?thats what im trying to figure out.i don't know what's causing it
catchdz
Dec 2, 2011 07:01 AM
crusto2k3
Dec 1, 2008 02:14 PM
yz125rider21
12
Feb 12, 2007 04:49 PM
crxY-49
Jul 1, 2004 06:26 PM
