Honda CR-V & Element 2WD & 4WD Element & CR-V
Replacing the interior clock?
Old Jan 11, 2017 | 05:19 AM
s-os's Avatar
Default Replacing the interior clock?
The clock in my Cr-V from 1998 does not work anymore and it would be nice to replace it with one that shows the outside temperature. The original clock is the 4-wire type and the one I would like to install has 7-wires and the outside sensor has two wires.
It's easy to install the 4 wires needed for the clock but how do I connect the sensor to the clock? I guess I have to connect some kind of 5V referens to the sensor? Since I do not have a car with AC.
The clock itself seems to be a direct fit in the upper center vent. console -at least they look a like.
Old Jan 13, 2017 | 10:41 AM
BigBerz's Avatar
Default Re: Replacing the interior clock?
Sounds like you have the JDM clock with temp. You'll need to wire the temp gauge somewhere outside the cabin and then feed it to the clock.
Berz out.
Old Jan 14, 2017 | 12:38 AM
s-os's Avatar
Yes I´m thinking to replace it with a JDM clock, placing the sensor outside is not a big issue it´s more the wiring, I guess I can not wire it directly to the clock since it needs a 5 volt reference and I do not have a clue on how to connect it all.
Old May 14, 2017 | 09:51 PM
Hamster65's Avatar
If you want to keep your factory clock, try this..........it worked for me.
Honda CR-V 1999-2001 Clock Fix | Jason's Blog
KiwiRuss
Apr 1, 2022 12:43 PM
lunar_rd1
Feb 11, 2015 09:02 AM
bopbop93030
Audio / Security / Video
Aug 14, 2009 06:15 AM
bipedbear
Jun 9, 2005 12:15 PM
darkvibe
Nov 30, 2003 08:40 PM
