2012 honda crv crank shaft sensor
Re: 2012 honda crv crank shaft sensor
Hi,
Why don't you explain the fault you’re experiencing, plus any diagnostic fault codes to explain you’re reasoning why you need to change timing sensor.
BTW No you don't need to remove the pulley to change the CKP sensor
Kev
Kev
The first image is from a 2012 CR-V parts diagram.
The second image is for the CKP sensor location for a 2011 CR-V, which is similar to the location for the 2012 CR-V.
