Transmission Hand Cuff cnc design
Re: Transmission Hand Cuff cnc design
It normally eliminates 5th gear and holds the two transmission shafts to keep them from twisting and breaking gears on high hp cars.
its been too long since ive been in a trany (wow that sounded bad!) does his design eliminate 5th also? is it possible to cuff the shafts and keep the final gear, or is there space for it?
Ill buy one Right now L:OL "" PM'me""
I have a b18 ys1 cable tran's. if you woundering.
im shure Hijro & cable are the same
unfortunately, its not. removing 5th allows the cuff the shorten the shafts, making it harder for the applied force to seperate them.
Bense
Welding / Fabrication
16
10-26-2006 04:38 AM
91_hatch_si
13
05-08-2003 10:59 AM
