block damage
Old Jun 22, 2009 | 11:57 AM
topp_dawg_g's Avatar
From: springdale, arkansas, United States of America
Default block damage
i got an issue here. the mains on the block and caps have some wear on it from breaking a crankshaft. some are okay and some are pretty deep.
i sent my block out to laskey and they said that it's going to cost around $600-$700 plus new main caps because they well to make new tangs for the align hone. the crank is going to move up .015-.020 so i will have to get a thicker headgasket and file the dowel pins on the oil pump main seal. they said if i provide a new block, they can sleeve it for $900.
i was wondering if there's shop out there that can weld some material on the damage then align hone it. what do you guys think is my best option now?
Old Jun 22, 2009 | 12:40 PM
SD_Lurker's Avatar
HT White Ops
Default Re: block damage
I don't understand why you don't just get another block. That thing is trashed. Why spend all that money when you can just get another core for cheap and have it sleeved.
Old Jun 22, 2009 | 12:47 PM
Captain Bondo's Avatar
So you're going to weld them up yourself?
What is the welding/fabrication related content?
I agree just bin it and get a new core.
Life is way too short to bother dicking around with stuff like that, it ain't the original block from your '69 roadrunner.
Old Jun 22, 2009 | 01:28 PM
have a shop weld it. it seems like i heard them doing this before.
Old Jun 22, 2009 | 02:14 PM
SD_Lurker's Avatar
HT White Ops
WHY? Why waste money repairing this block? You've been quoted prices and it appears the cost of repair is not in your best interest. Buying a new core for a few hundred bucks and having it sleeved is your best bet. Oh and I advise you to use a stock crank. I assume you used an Eagle or like since it broke...
Old Jun 22, 2009 | 03:02 PM
siblues's Avatar
the price difference assuming the same work is done to both blocks is maybe 300 bucks for a new core so why risk thousands of dollars on parts and time for a measly 300 bucks.Get a new core.
Old Jun 23, 2009 | 05:54 AM
b00stcreep21's Avatar
Straight up, it's not worth the risk and the hassle. Just get a new block, and call it a day
Old Jun 23, 2009 | 06:14 AM
Reyke's Avatar
unlike everyone else here, I think you should keep it, and fix it, why buy another core who knows whats wrong with that one, look at what you have you know how ****ed it is and what you have to look forward to
Old Jun 23, 2009 | 06:56 AM
93supercoupe's Avatar
bc even after u repair the block, ur still not sure that its as relaibale as a stocker.Dont waste ur time or money on some repair that might work out.I know if laskey does it it will be fine but otherwise, why risk it?
Use a stock crank and u wont have this probleme.
Old Jun 23, 2009 | 07:11 AM
legendboy's Avatar
forget that block man, its garbage.
topp_dawg_g
Jun 25, 2009 03:13 AM
topp_dawg_g
Jun 24, 2009 02:04 PM
topp_dawg_g
Jun 23, 2009 04:14 PM
dr_latino999
Nov 22, 2006 07:46 AM
x91crxsix
Jul 21, 2006 08:59 AM
