Intake Manifold Material?
Old Aug 10, 2009 | 02:54 PM
Janz99's Avatar
Default Intake Manifold Material?
Just wondering what thickness of material everyone was using for your intake plenums? Where are you guys buying it from?
Thanks
RYan
PS- im talking about aluminium.
Old Aug 10, 2009 | 02:58 PM
got wide's Avatar
Default Re: Intake Manifold Material?
check here, i havent ordered from them yet, but i plan to
http://rossmachineracing.com/plenumextrusions.html
Old Aug 10, 2009 | 03:04 PM
russianvr4's Avatar
OG Fabricator
thats where i got my material for this intake. 1/4" thick, its pretty much indestructable.
Old Aug 10, 2009 | 04:12 PM
Janz99's Avatar
I was thinking of something more along the lines of this:
I think it would fit better in the engine bay then the D shaped plenums.
Ryan
Old Aug 10, 2009 | 06:07 PM
got wide's Avatar
really dont think the d plenum will have any fitment issues as long as the runners arent too long. but the one you pictured could be made from tubing and flat stock 3/16 should be a good general thickness but if its for an n/a setup you could probably get away with 1/16 if you needed to or up to 1/4. the most important thing would be to try and research and find the ideal plenum volume and runner length, but that is pretty hard to find some times.
Old Aug 10, 2009 | 07:23 PM
Janz99's Avatar
Where can you get thicker walled tubeing from? Id be looking for 4" 90's or 45's to make something like shown above. Ive seen the intercooler piping stuff and its pretty thin. Thinner then id really like to use for an intake plenum. I was thinking 3/16 for the plenum.
The reason id like to use this style of intake versus the D shaped plenum is because of where it places the throttle body. Im very limited for space, and with the intake shown above, it would make intercooler piping fitment a piece of cake. That and it would have a slightly larger plenum volume in comparison to the D shaped.
Ryan
Old Aug 10, 2009 | 07:56 PM
got wide's Avatar
mcmaster.com has straight up to 5", and i usually get my flat plate from http://www.metalsdepot.com/index.phtml?aident= but i dont know where to get the bends from that thick. what engine/car are you making this for??
edit: there is also a where to buy thread stickied at the top of the fab forums but i havent looked at in a while there might be a place to get bends from in that list.
Old Aug 11, 2009 | 03:36 AM
customplenums.com's Avatar
1/8" is plenty, thats all i ever use without any problems. its just a matter of how they are put together.
russianvr4 - i am currently doing some flow testing on the same engine at the moment. actually should have standard flow figures back by the ned of the week and have a couple of orders for guys over there in the US for them. We'll see how we go before and after.....and dam that is some nice welding you have going on there.
Old Aug 11, 2009 | 06:30 AM
russianvr4's Avatar
OG Fabricator
keep me posted, im interested in seeing what you find out.
make sure you post it on www.3si.org also
Old Aug 11, 2009 | 06:45 AM
redboost10's Avatar
Ryan
www.globaltecheng.com has some aluminum pipe and tubing.
Old Aug 11, 2009 | 06:55 AM
hootiehoo's Avatar
http://www.jasperintegration.com/navi.html
Old Aug 11, 2009 | 01:48 PM
AFI Turbo's Avatar
All ours are 1/8th inch but they are made alittle different than how most tappered style plenums are.
Old Aug 11, 2009 | 03:05 PM
got wide's Avatar
Originally Posted by hootiehoo
that dual plenum setup is interesting, is there any testing results out that show any performance gains or flow testing?
uberEFtuner
May 20, 2009 09:40 AM
macDelli
Feb 19, 2009 08:41 PM
quickda6
Welding / Fabrication
31
Dec 10, 2006 06:58 PM
Aeka GSR
Oct 18, 2002 06:58 PM
gsr98vtec
Dec 4, 2001 09:39 PM
