oil consumption
When I first bought my 03 S2K from an Acura dealer, it was about a quart low, though the oil was clean. I got in a wreck (documented here), got it back and changed the oil immediately to 5.2 quarts of Royal Purple and a PureOne filter. 1500 miles later, I'm a quart down again (well, added the 0.8 that was left), and the oil is squeaky clean. I'm sure it was dino oil in the car when I got it (dealer change) -- I figured they just didn't put enough in.
Is this common? I also bought a 4/48K mile warantee through Acura on it. Any recourse there? The car only has 26K on it.
Thanks guys-
Tom
(on the road again and using oil)
Thanks guys-
Tom
I got my 01 at 26K. I'm at 32k. I immediately changed the oil -- Mobil1/OEM filter and like you was consuming alot of oil 1 quart/1K miles. I just did another oil change 1K miles ago. And now I'm can barely detect any oil consumption. The car's been on dino with the first owner...my driving hasn't changed -- actually it's gotten more aggressive as I got better with the car.
Don't know if it's common, but anything within a quart of consumption within 3K miles is not unusual.
alot of s2k's burn synthetic, try regular oil, or get some crank vents. my 04 s2k has 54k and never burned a drop, not even a 1/2 quart between changes, i use castrol gtx btw!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s2kdre »</TD></TR><TR><TD CLASS="quote">alot of s2k's burn synthetic, try regular oil, or get some crank vents. my 04 s2k has 54k and never burned a drop, not even a 1/2 quart between changes, i use castrol gtx btw!</TD></TR></TABLE>
Mine burns ZERO with synthetics and a catch can. Very little end up in the can, though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 67marobird »</TD></TR><TR><TD CLASS="quote">...so if I brought it to the dealer with this complaint under my extended warantee, I can expect to be told to F off?
not necessarily. But it would be hard to prove
VQ's have been recalled because of it. Like they said as long as it is reasonable it won't matter
</TD></TR></TABLE>not necessarily. But it would be hard to prove
hey... havent posted here before... i usually stay on s2000turbo.com... but its been rly slow lately...
so this happened to me not to long ago.. i went on a trip to upstate pa... was doing about 140 most of the way... and when i got back from the trip i noticed my oil was low..(changed oil a week prior to leaving) so i put some royal purple in.. it took 3 courts??? is that normal to burn that much oil???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverDc2 »</TD></TR><TR><TD CLASS="quote">
im running royal purple hasn't burned yet at 1500
Swear by this stuff.
</TD></TR></TABLE>Swear by this stuff.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jonnys2k »</TD></TR><TR><TD CLASS="quote">thats wat i had in the car when it burned 3 courts! i still love the stuff.. but i burned an awful lot!!</TD></TR></TABLE>
That's the first I heard of Royal Purple. Then again, they do put a lot of detergent in it. It probably cleaned the hell out of your motor. People who have used it on newer lower mileage motors have had no complaints. :shrugs:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jonnys2k »</TD></TR><TR><TD CLASS="quote">hey... havent posted here before... i usually stay on s2000turbo.com... but its been rly slow lately...
so this happened to me not to long ago.. i went on a trip to upstate pa... was doing about 140 most of the way... and when i got back from the trip i noticed my oil was low..(changed oil a week prior to leaving) so i put some royal purple in.. it took 3 courts??? is that normal to burn that much oil???</TD></TR></TABLE>
you were doing 140 most the way? LOL
thats quite a bit of load for an extended period. Suprised your tires didn't overheat as well. Remind me not to buy your car
buy krankvents. they stopped my oil consumption. i used to burn 1 quart every 1000 miles and now i burn none.
http://www.s2ki.com/forums/ind...52783
I bought a totaled car (for a project) that was about 3 quarts low when I got it. I was pretty dissapointed, but couldn't find any signs of leaks and after I filled the oil and started it, it still ran nice and smooth. Hopefully it wasn't too far past its time for a change.
Mine is always fine, I don't think it burns any, but I was told that it says in the manual they burn a quart between changes.
I haven't looked it up, but next time I'm looking through it I'll try to find a page number to cite.
Thomas ander
Honda Accord (2013 - 2015)
Mar 1, 2019 09:49 AM
Buzzbomb
Dec 8, 2007 04:31 PM
