Honda S2000 Honda S2000
PULLS TO THE LEFT AND BACK WHEN THROTTLE. HELP!!!
Old Aug 28, 2007 | 02:00 PM
ruracer18's Avatar
Default PULLS TO THE LEFT AND BACK WHEN THROTTLE. HELP!!!
I have a 04 s2000 and everytime i drive at about 50mph or somewhere there it swerves to the left and as u let the gas go it pulls back, and then again and again. tires have been aired up. the steering wheel does not turn the whole car moves by itself. feels weird. maybe its the tires or something loose, help.
Old Aug 28, 2007 | 02:03 PM
WowOzYouRock's Avatar
Default Re: PULLS TO THE LEFT AND BACK WHEN THROTTLE. HELP!!! (ruracer18)
im not sure but i think its the power steering fluid might be low....
Old Aug 28, 2007 | 02:08 PM
bobjohnson's Avatar
Is it out of alignment?
Old Aug 28, 2007 | 02:18 PM
ruracer18's Avatar
Default Re: PULLS TO THE LEFT AND BACK WHEN THROTTLE. HELP!!! (bobjohnson)
i did change my springs, put lowering springs.-1.5inch, changed tires, used, but it never did that before.
Old Aug 28, 2007 | 03:37 PM
ap1lvr's Avatar
I had the same problem, it was my tires. They were low on air after I filled them it was back to normal.
Old Aug 28, 2007 | 03:41 PM
ruracer18's Avatar
Default Re: (ap1lvr)
the air is perfect, it even does that when i put dif wheels on, i put some 18s of my bros eclipse and still the same.
Old Aug 28, 2007 | 04:54 PM
g2kap1v2's Avatar
its always reccomended to get an alignment when you change the springs and shocks.
Old Aug 28, 2007 | 05:04 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: PULLS TO THE LEFT AND BACK WHEN THROTTLE. HELP!!! (WowOzYouRock)
alignment
air
tires
Old Aug 28, 2007 | 06:36 PM
b20integrapower's Avatar
Default Re: PULLS TO THE LEFT AND BACK WHEN THROTTLE. HELP!!! (S@nt0s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ruracer18 &raquo;</TD></TR><TR><TD CLASS="quote">i did change my springs, put lowering springs.-1.5inch, changed tires, used, but it never did that before.</TD></TR></TABLE>
Used tires? Get new tires and I'll almost guarantee your problem will subside. I'll paypal you a dollar if I'm wrong.
Old Aug 29, 2007 | 04:06 PM
ruracer18's Avatar
Default Re: PULLS TO THE LEFT AND BACK WHEN THROTTLE. HELP!!! (b20integrapower)
if it was the alignment the car would pull to right or left. it goes straigh as i cruise at about 50-60mph then give it gas and it pulls to the left or shifts to left, and as u let it go it pulls back and drives normaly,
Old Aug 29, 2007 | 04:15 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ruracer18 &raquo;</TD></TR><TR><TD CLASS="quote">if it was the alignment the car would pull to right or left. it goes straigh as i cruise at about 50-60mph then give it gas and it pulls to the left or shifts to left, and as u let it go it pulls back and drives normaly,</TD></TR></TABLE>
look 2 posts above this one. That's your answer.
Old Aug 29, 2007 | 06:06 PM
Evs-One's Avatar
Solbros Owns Me
oviously the issue happens under engine load. If the rear tires are different sizes/pressures dramatically different, or the LSD is failing, this can happen.
Old Aug 29, 2007 | 08:47 PM
ap1lvr's Avatar
LSD?
Old Aug 30, 2007 | 04:31 AM
JDM knowledge's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ap1lvr &raquo;</TD></TR><TR><TD CLASS="quote">LSD?</TD></TR></TABLE>are you lost as to what an LSD is? its a drug go take some.
Old Aug 30, 2007 | 09:43 AM
ap1lvr's Avatar
Default Re: (JDM knowledge)
enlighten me.
Old Aug 30, 2007 | 11:38 AM
ruracer18's Avatar
when i lowered it i did not know u had to put on shaft spacers and drove around for a while, now i have them on but still think i broke the differential, i hear that if the shafts in the diff move that means its bad or something broke. could it be that.
Old Aug 30, 2007 | 12:00 PM
mugenadict's Avatar
That might be true if it had any power steering fluid.
Old Aug 30, 2007 | 12:18 PM
Techno Tonis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ap1lvr &raquo;</TD></TR><TR><TD CLASS="quote">enlighten me.</TD></TR></TABLE>
dude, LSD ***** you up man. Take like 3 hits. fun city
...oh...what...? the hell is a limited slip differencial?
Old Aug 30, 2007 | 09:21 PM
Default Re: (Techno Tonis)
he means limited slip differential.
Don't be a smart *** if you can't do it correctly.
Old Aug 30, 2007 | 09:23 PM
Default Re: (b20integrapower)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20integrapower &raquo;</TD></TR><TR><TD CLASS="quote">^^
Don't be a smart *** if you can't do it correctly.</TD></TR></TABLE>
aww boo hoo, i confused the letter t with the letter c, now no one has any clue what I am talking about
boy, my english is FAIL
Old Aug 30, 2007 | 09:43 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Techno Tonis &raquo;</TD></TR><TR><TD CLASS="quote">
I'm afraid YOU have no idea what YOU are talking about. I just felt like being picky. Take it or leave, I really don't give two *****.
Old Aug 31, 2007 | 04:32 PM
ruracer18's Avatar
soooooooooooooooooo start looking for an lsd or wat.
Old Aug 31, 2007 | 04:37 PM
ruracer18's Avatar
Default Re: (ruracer18)
would a differential from ap1 fit on my ap2
Old Aug 31, 2007 | 06:31 PM
m R g S r's Avatar
...oh...what...? the hell is a limited slip differencial?</TD></TR></TABLE>
e/k combo is better
it sounds almost like the car is one wheel drive....when he accelerates the driving wheel may turn forcing the car to the opposite side.....so maybe the diff is really fucked up? i dunno get a new S
Old Sep 1, 2007 | 07:58 AM
jdm-ray's Avatar
From: home of Marciano/Haggler, city of champions, MA
Default Re: (m R g S r)
maybe you need to change the diff. fluid
