Honda S2000 Honda S2000
alignment question(s)...
Old Aug 25, 2007 | 12:35 PM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
Default alignment question(s)...
ok heres the deal... i just lowered my car yesterday on Swift Mach Springs... its a conservative 1" drop which is all i was looking for so i was happy with that regard... i know i have to get an alignment done, but do i really have to wait a week? also my steering wheel is in the 10 o' clock position... this will be adjusted when the alignment is done? should i just bring it to a pepboys, firestone, etc? os is there better places to choose?
ohh and i will post pics as soon as i can find my data cable... thanks guys...
Old Aug 25, 2007 | 02:35 PM
frankdatank's Avatar
yes you need an alignment, yes it will fix the steering wheel, and yes you should wait a week for the springs to settle.
Old Aug 26, 2007 | 11:41 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (frankdatank)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frankdatank &raquo;</TD></TR><TR><TD CLASS="quote">yes you need an alignment, yes it will fix the steering wheel, and yes you should wait a week for the springs to settle.</TD></TR></TABLE>
correct0
Old Aug 27, 2007 | 05:43 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: (S@nt0s)
I'm surprised that your steering wheel's angle changed so much. Is it seriously that off? I just swapped to Espelir (~1.3" drop) on stock struts and the steering wheeel seems perfect. The camber is definitely off and I get more bump-steer, but overall feel remains the same.
Old Aug 27, 2007 | 05:45 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (shamoo)
i agree that his steering wheel is of so much with just spings unless they removed the toe rods for some reason
Old Aug 27, 2007 | 07:17 PM
S2KILLA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S@nt0s &raquo;</TD></TR><TR><TD CLASS="quote">i agree that his steering wheel is of so much with just springs unless they removed the toe rods for some reason</TD></TR></TABLE>
nah did a flawless install... it baffled me as well
Old Aug 27, 2007 | 08:32 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (S2KILLA)
it just doesnt make sense to me... that the springs will throw it off like that....
Old Aug 28, 2007 | 04:20 AM
S2KILLA's Avatar
ok maybe i exagerated a lil bit... maybe not 10, buyt more like 11 o clock... yeah i dont understand it either... we did my buddies S last week with espeliers and the only issue he had was major camber... and ive lowered several cars in the past and the only other time it happened was when i put coils on my teg... im gonna do a spot check tonight and re-torque everything down... im getting an alignment either thurs or friday so hopefully it will be corrected...
also, i was pretty sure you had to wait a week to get an alignment when lowered on springs, but i heard somewheres that it didnt matter how long you waited with the Swifts... they basically said as soon as you slap them on thats about as low as its gonna get... thats why you cant trust everyone
Old Aug 28, 2007 | 10:03 AM
shamoo's Avatar
I'm going to align my car sometime this week, as I installed my Espelir's last week. I'm sure with some springs you can wait, and some you don't. But it's only a week, so it won't make too much of a difference.
Yep, also confuses me with the steering angle. When doing springs/suspension on the S2000, the tie rod doesn't need to be remove at all. The A-arms just unbolt very easily and the entire assembly shifts forward. Good luck.
Old Aug 28, 2007 | 10:10 AM
S2KILLA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shamoo &raquo;</TD></TR><TR><TD CLASS="quote">I'm going to align my car sometime this week, as I installed my Espelir's last week. I'm sure with some springs you can wait, and some you don't. But it's only a week, so it won't make too much of a difference.
Yep, also confuses me with the steering angle. When doing springs/suspension on the S2000, the tie rod doesn't need to be remove at all. The A-arms just unbolt very easily and the entire assembly shifts forward. Good luck.</TD></TR></TABLE>
yeah i know... its kinda bothering why this happened... ill let you guys know if I find anything wrong tonight
Old Aug 28, 2007 | 10:11 AM
WowOzYouRock's Avatar
hopefully the springs for the rears are on the rear and the fronts are in the front...
or the spring is not sitting correct on the perch..
Old Aug 28, 2007 | 10:15 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S2KILLA &raquo;</TD></TR><TR><TD CLASS="quote">ok maybe i exagerated a lil bit... maybe not 10, buyt more like 11 o clock... </TD></TR></TABLE>
wouldnt that be worst then???? hahahaha
Old Aug 28, 2007 | 10:39 AM
Default Re: (WowOzYouRock)
ohhh and you prolly didnt preload the bushing..
Old Aug 28, 2007 | 11:39 AM
S2KILLA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WowOzYouRock &raquo;</TD></TR><TR><TD CLASS="quote">
wouldnt that be worst then???? hahahaha </TD></TR></TABLE>
ummm no... if 12 is pointing straight up... and 11 is right next to 12, and 10 is even further away from 12, itd be worse... didt you learn how to read a clock in like pre-school? haha
ohh and i just checked... everything seems to be flush and bolted in correctly... ill do the final check later on...
Old Aug 28, 2007 | 11:41 AM
S2KILLA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WowOzYouRock &raquo;</TD></TR><TR><TD CLASS="quote">ohhh and you prolly didnt preload the bushing.. </TD></TR></TABLE>
we did... thats y i keep coming up empty handed...
Old Aug 28, 2007 | 12:00 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
we did... thats y i keep coming up empty handed...</TD></TR></TABLE>
well maybe your steering wheel was just a tiny bit off before. When you put the springs on, it just exxagerated it. Angles change pretty dramatically on the S2000 even with 1'' of lowering.
Did you rotate the tires? Swap them side to side? maybe you had some uneven wear before and now it sits weird. My steering wheel on my GSR is straight, and then when I rotate the tires, it goes crooked. When i have them rotated back to the original position, the steering wheel goes back. lol it's weird. The car goes straight, and there's no uneven tread wear.
When they align the car, they align it with the steering wheel pointed straight. So they will match the wheels to the steering wheel when they align.
Old Aug 28, 2007 | 12:05 PM
Default Re: (B serious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B serious &raquo;</TD></TR><TR><TD CLASS="quote">
When they align the car, they align it with the steering wheel pointed straight. So they will match the wheels to the steering wheel when they align. </TD></TR></TABLE>
Captain Obvious over here... haha
Old Aug 28, 2007 | 12:11 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Captain Obvious over here... haha</TD></TR></TABLE>
hahahaha but what if i want my "H" to be upside down ?
Old Aug 28, 2007 | 12:14 PM
hahahaha but what if i want my "H" to be upside down ? </TD></TR></TABLE>
just the "H" but not the steering wheel? hahahah
Old Aug 28, 2007 | 12:15 PM
S2KILLA's Avatar
Gangstaaa!!!
Old Aug 28, 2007 | 12:18 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
hahahahaa
Old Aug 28, 2007 | 12:46 PM
Black S2K's Avatar
I helped drop my friends s, we droped it on espelirs and he went and got his allignment done liek two days after. Now about a month later his springs finaly broke in and his camber got all messed up again. So he has to go get hiss alignement done again. I ordered the same springs (espelir asd) they havent come in yet though. But when they do and whne I install them im gona wait a good month b4 i get the allignment done. Anyways where is that pic you said you would post?????
Old Aug 28, 2007 | 05:40 PM
toomuch2c's Avatar
I
Old Aug 28, 2007 | 05:46 PM
toomuch2c's Avatar
I have a quick question for anyone that can help... I installed KONI Yellows with espelir ASD. The whole drivers side sits about .25 inch lower than passenger side. How can you tell what springs are front and rear. There are no descriptions on the springs telling you which are front and rear... Can anyone help me with images or what i need to look for to try and identify which is front and rear springs? Thanks ....
Old Aug 28, 2007 | 06:21 PM
B serious's Avatar
lol well he asked if an alignment would fix it. so i answered.
