Honda S2000 Honda S2000
idle problem with s2k
Old Aug 20, 2007 | 06:17 PM
cool_junk's Avatar
Default idle problem with s2k
I have an 2000 s2000 that is idling great but when you rev it up with the a/c on and let it fall back to idle, it almost dies. It doesn't do it with the a/c off. I have cleaned the throttle body and IAC thoroughly with no change. I have done the ecu idle learn procedure multiple times with no change either. the symptom does not occur during normal driving, only on a free rev with the a/c on. please help
Thanks, Drew
Old Aug 20, 2007 | 06:26 PM
LAS2K's Avatar
Default Re: idle problem with s2k (cool_junk)
Recent weather change?
Search for "map whack".
the end.
Old Aug 20, 2007 | 06:30 PM
cool_junk's Avatar
Default Re: idle problem with s2k (LAS2K)
Fuel trim looks great! 0-5%
Drew
Old Aug 20, 2007 | 06:44 PM
revhi's Avatar
As long as the car doesnt stall its normal.
Old Aug 20, 2007 | 07:20 PM
Blacknizzle07's Avatar
Hi I have a 2001 S2K and it does the same thing. Ive tried everything that the people on the forums recommend but still no change and my car even dies completely. So I'm takin mine to the shop and tellin them to find out wat it is and I will let you know when they find out.
Old Aug 20, 2007 | 08:20 PM
Mr. Projekt's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cool_junk &raquo;</TD></TR><TR><TD CLASS="quote">I have an 2000 s2000 that is idling great but when you rev it up with the a/c on and let it fall back to idle, it almost dies. It doesn't do it with the a/c off. I have cleaned the throttle body and IAC thoroughly with no change. I have done the ecu idle learn procedure multiple times with no change either. the symptom does not occur during normal driving, only on a free rev with the a/c on. please help
Thanks, Drew</TD></TR></TABLE>
Did you clean out the MAP sensor port as well?
Old Aug 21, 2007 | 01:31 AM
WowOzYouRock's Avatar
Default Re: idle problem with s2k (Mr. Projekt)
that has nothing to do with weather change or sensor what so ever... hence, it only happens with the A/C is on??? ... its completely normal the RPM fall with the A/C on... what happen is that, the A/C pump restrict the RPM speed (at idle) because of the friction from the pump...
now of your car dies completely, the A/C line might be clogged, kink, or faulty A/C pump itself... symptoms of that, not blowing as much cold air anymore...
Old Aug 21, 2007 | 05:39 AM
cool_junk's Avatar
If the map port was clogged it would show up in the fuel trim! (It's perfect!)
Old Aug 25, 2007 | 02:05 PM
6KVtec's Avatar
i have an 01 s2k and it happens to me to, but mine happens to me when the a/c is off to, but my car never dies, so i figure its just normal...
Old Aug 25, 2007 | 04:40 PM
llansy's Avatar
your ok
boarding2008
Aug 8, 2008 08:44 AM
lude98SH
Mar 16, 2006 12:56 PM
redED9Si
Aug 21, 2005 06:58 PM
..::91TEG-G2::..
Jan 26, 2005 10:01 AM
