Honda S2000 Honda S2000
Suspension Question.
Old Aug 7, 2007 | 08:13 AM
01SSAP1's Avatar
Default Suspension Question.
Need advice from the suspension experts.
I just recently bought a 2001 S2000. It came with Tein Flex Coilovers and EDFC.
On the crappy northern potholed and patched roads we have here in Nova Scotia canada it rides awful. I have tried different settings on the edfc but it makes little difference.
I was provided with stock suspension. I did some research and the stock spring rates are half what the tein ones are. If i put the stock suspension back will the car ride better?
Obviously I will loose handling but I am not going to be using it as a track car I just want a car that is fun to drive and not punishing.
Old Aug 7, 2007 | 08:42 AM
JDM knowledge's Avatar
Default Re: Suspension Question. (01SSAP1)
well it sounds like your a ***** jp.
ok now that i have gotten that off my chest...yes if you put the stock suspension back on it will ride better as in softer. Though stock AP1 suspension still holds its on when it comes to stiff. the only way to make the Teins softer is to caress them more and tell them that you love'em till the day they blow
Old Aug 7, 2007 | 04:16 PM
BoostedGreddy's Avatar
Default Re: Suspension Question. (JDM knowledge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM knowledge &raquo;</TD></TR><TR><TD CLASS="quote">well it sounds like your a ***** jp.
ok now that i have gotten that off my chest...yes if you put the stock suspension back on it will ride better as in softer. Though stock AP1 suspension still holds its on when it comes to stiff. the only way to make the Teins softer is to caress them more and tell them that you love'em till the day they blow </TD></TR></TABLE>
Sounds like a **** to me
Old Aug 7, 2007 | 04:53 PM
H.A.R.T B18C1EG6's Avatar
Default Re: Suspension Question. (BoostedGreddy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedGreddy &raquo;</TD></TR><TR><TD CLASS="quote">
Sounds like a **** to me </TD></TR></TABLE>
haha
Old Aug 7, 2007 | 06:12 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
try getting the car aligned. A shitty ride could also be due to the tires being toed out or in too much. The tires will be hitting bumps while traveling sideways. This increases the harshness of bumps by A TON! Excessive camber/ positive caster also increases the annoyance factor.
Make sure the previous owner hasnt preloaded the springs. This makes the springs stiffer, and consequently, the ride harsher.
Check tire pressure. If it's much above normal, your ride will be harsher.
All in all, the flex really isnt designed to be "agressive". The ride really shouldnt be that "punishing".
Old Aug 8, 2007 | 12:20 PM
jdm j's Avatar
In your case, set your EDFC settings to 16 Front and 16 Rear! That should make it better. Remember that the car is light and even on the softest setting on the EDFC, it will still feel stiff! If that doesn't work, check to make sure that the coil overs are evenly adjusted to the right height and or like "B Serious" said,"try getting the car aligned!"
Old Aug 8, 2007 | 12:23 PM
WowOzYouRock's Avatar
i bet you got a hard on too... ROFL HAHAHAHAHAHAHHA!!!
Old Aug 8, 2007 | 01:30 PM
p nut's Avatar
If I were up in Noova Scoootia, I'd put the stockers back on. That way, you won't get all jostled around when you're oot and aboot.
Old Aug 8, 2007 | 01:51 PM
cmdr430's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01SSAP1 &raquo;</TD></TR><TR><TD CLASS="quote"> It came with Tein Flex Coilovers and EDFC.
sell this suspension....
yes the car will ride much better......
Obviously I will loose handling but I am not going to be using it as a track car I just want a car that is fun to drive and not punishing.</TD></TR></TABLE>
if your roads are as crappy as they are.... you will probably gain handling because you are not bouncing around so much....
also, i will guarantee over half the people on here have never out driven the capabilities of a stock s2k suspension.....
raymondpowens
Nov 10, 2014 09:39 AM
weaksonnn
Oct 15, 2007 01:59 AM
01SSAP1
Suspension & Brakes
Aug 7, 2007 10:08 AM
