22 inch slick
I am putting a turbo on my 2000 Acura integra with a gsr in it. When I finish it I want around 300 to 350hp. I was thinking of getting some 22 inch slicks because I will be able to fit them on my car with out raising it up. Will a 22 inch slick be good for me?
mess around with the transmission calculator
http://www.zealautowerks.com/transcalc.php
i figure that a gsr around 300-350hp should probably trap mid 110's give or take a bit
I'd say 24.5 too maybe 23. I would recommend raising car anyway it common to "cut" slicks at the end of the track under breaking if it's not raised enough. You don't wanna Runin some slicks.
If you do get the 22" and worried about running out of gear at the end then turn up the rev limiter. I would hope you have a upgrades valve train when running anykind of boost.
