race/ tucked radiators set ups
Old 10-23-2014, 09:16 PM
bigislandc2's Avatar
Default race/ tucked radiators set ups
I wanted to see some race or tucked rad set ups.
I just got mine in but no mounting tabs or filler neck so looking into ideas on how to mount it and I just got regular 32mm outlets/inlets
Thanks guys
Old 10-24-2014, 07:06 AM
Turbo-LS's Avatar
Default Re: race/ tucked radiators set ups
I have a Scirocco radiator in my DC with top mount manifold. I used an inline fill neck which proves to be useless and to low for proper air bleed. I had Dave Fry make me a surge tank setup off my coolant neck so i have a high point in the cooling system to the height of the valve cover. Works great !
Old 10-24-2014, 07:14 AM
CHEETAH's Avatar
I have a lean kit (k-series) and the front intake takes up 75% of the front radiator support width so hard to squeeze a radiator thats wider than 11 inches...so I got a CX Racing Air intercooler 11" x 13" and weld in -12AN fittings to use as radiator... ASP and K Tuned make the coolant adapter off the head with a small canister and radiator cap so that its the highest point on the coolant setup...
Old 10-24-2014, 09:21 AM
Any pics !!
Old 10-24-2014, 10:58 AM
93egSLEEPER's Avatar
Check out speedfactory tuning and race fabrication. They just started producing their own line of tucked radiators that are SICK
Old 10-27-2014, 05:57 AM
Turbo-LS's Avatar
This is the exact radiator i have from that seller on ebay. I believe I paid 150 shipped. It's a dual pass style rad and cools VERY well. My car stays in the 180's driving. At the track on a hot day highest temp Iv'e seen after making a pass was 202 at the end of the track and the temps come back down to high 180's very quickly This is in a 800hp car and I live in Texas. Heat wrapping also makes a huge difference in heat soak and keeps temps down
Old 10-29-2014, 08:20 PM
thanks i have a sheepeybuilt rad. just wanted to see how all of you guys are mounting them. i need to get a filler neck assy. as well
Old 10-30-2014, 04:35 AM
2000CTRSi's Avatar
Justin is that a dizzy with wires I see???
Old 10-30-2014, 02:55 PM
Flexer's Avatar
Turbo-ls,
To fit that radiator did you have to remove your hood latch? I just don't see any other way of fitting it? Any pics showing the whole thing?
Old 10-30-2014, 03:32 PM
g2turbo's Avatar
The Speedfactory unit is very nice, but it seems hard to run a topmount setup with this radiator. Especially if you plan on running the puller fans on the engine side of the radiator (as pullers).
I would be interested to see if anyone has made this work, regardless of turbo manifold design.
Old 10-31-2014, 10:18 PM
Well the sheepey one I have is almost identical to SF rad. I'm running a forward facing mani with up pipes so I guess I'll have to fab something up and run a radiator cap filler neck from SF.
When I put mu engine back in ill get some pics in. But I was hoping someone else would have pics for ideas..
Old 11-02-2014, 04:03 AM
Turbo-LS's Avatar
I'm currently running a dizzy with hondata CPR until I switch to AEM.
Yes you have to cut out the hood latch in order to fit in like I currently have mine setup. Before my new manifold I was able to retain the stock hood latch when the radiator didn't need to be as far forward. I'll snap some better pics.
Old 11-02-2014, 05:55 AM
Natural Aspirations's Avatar
Would it be possible to slide the VW rad far enough to the passenger side to run a backdoor IC?
Old 11-02-2014, 07:42 AM
Turbo-LS's Avatar
I'm running back door intercooler on both the hot and cold side. You have to trim the sheet metal but it works. As far as with a forward facing manifold I'm not sure.
Old 11-02-2014, 10:04 AM
Turbo-LS's Avatar
Old 11-06-2014, 08:19 PM
Here's some pics of the bracket I made from aluminum. Seems to like it will work for me. I'm also fabbing a small bracket for the top end tank.
Old 11-06-2014, 10:00 PM
da_dude's Avatar
The scirocco aluminum radiator I have the end tank where the inlet and outlet side goes through. I stuck a wire through to see if there was anything blocking but guess not. I can clearly fish wire it from the inlet to the outlet. Thought there suppose to be a plate blocking it off so coolant can flow through to the other end and back. I'm going to have to cut it and mod it.
Old 03-16-2016, 06:09 AM
hondata555's Avatar
Is tucked radiator setup with -16an hoses is efficient enough to run on the track (circuit, time attack) ??
Old 03-18-2016, 03:20 PM
sayco's Avatar
I just cut and resize and relocate the bottom water neck. Reason i cut it is to mske room for future lean set up
Old 03-20-2016, 06:27 AM
rudebwoy's Avatar
I have the speed factory drag radiator with spal fan, and meziere water pump for my current setup, I use a full race topmount and it places the wastegates in a very weird position so running dual 3" backdoor intercooler, and 3.5" downpipe. I hope with this new setup I can have A normal looking engine bay in a car that stays cool in all conditions, I plan to run a oil cooler as well. I always overheats on the dyno, so I travel with a giant BMW radiator and attach it to the bumper for dyno tuning.
Old 03-20-2016, 10:46 AM
Turbo-LS's Avatar
more cooling surface is always goping to be better for extended periods of spirited driving. use a shroud and a good fan and allow the fan to run above xxx mph. Also making sure all air makes its way through the rad helps a lot and heat wrap
SCoupe 5sp
33
01-17-2014 11:50 AM
GoFastTshirts.com
01-23-2007 09:25 AM
B6tPoweredMx3
12-10-2005 03:52 PM
EGh22aEG
01-09-2002 06:37 PM
Quick Reply: race/ tucked radiators set ups
